Question....
What is that black flat metal bar that runs underneath the car called?......and for what purpose is it?......woul dit be dangerous to drive the car without it because my exhaust seems to be rattle on it like crazy and i cant stand the noise anymore so i thought if it would be ok to drive the car without it on....thanx
There should be some kind of fix for that, unless it is an uncommon exhaust cause I haven't seen any on here that did'nt have a fix. I wouldn't remove any supporting pieces of the car just for an exhaust
Well if he needs to get the resonators welded back on, I would say it is not a bolt on exhaust system cause that should have resonators and should fit great. An exhaust shop should definitely be able to do whatever you want and make sure it doesn't rub.
Performance Nissan
Performance Nissan
you want to put some shims there to push it down...
i have about 6mm's of metal in there to push it down... my car is as low as I can go, it scrapes on some things... but then again the whole bottom does over speed bumps... nothing to be harmed though...
here is a pic of where they should go.. just under the screws...
if you order something from us, put a note in the comments section and I can add some shims for $2.00
