RPM warning light
Old Apr 21, 2005 | 10:03 AM
1 2 NV's Avatar
1 2 NV
Default RPM warning light
I just have a quick "gee whiz" question. I know the rev limiter is 6800, but why can you adjust the warning light to go all the way up to 8000? Is it just because.......a flaw.......... an over sight, or what? I noticed it today.
Old Apr 21, 2005 | 10:07 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I dunno why, but its cool they did this, it works our good for my reflashed ecu, and for anybody that does valvetrain or headwork in the future to use.
Old Apr 21, 2005 | 10:09 AM
RED HOT Z's Avatar
RED HOT Z
cause youl break your z
Old Apr 21, 2005 | 10:20 AM
arlingtonz's Avatar
arlingtonz
ummm...i think you missed the point.
I do not know why they would do this, but I may have to agree with Alberto on this one
Old Apr 21, 2005 | 01:17 PM
510dat's Avatar
510dat
Probably some people just don't ever want to see it, so they set your shift light to 8000, and they're set. I don't know if that's right, but it sounds good.
Old Apr 21, 2005 | 01:23 PM
kcobean's Avatar
kcobean
Yep, I think it even says something in the manual about "to disable the shift light, set it to 8000." It would start blinking at 7500, so you would never see it.
Old Apr 21, 2005 | 02:31 PM
RED HOT Z's Avatar
RED HOT Z
oooo I get it
Old Apr 21, 2005 | 04:39 PM
FLZ_Boy's Avatar
FLZ_Boy
I think the rev limiter is more at 6600.
Old Apr 21, 2005 | 09:08 PM
kcobean's Avatar
kcobean
Exactly. The shift light blinks 500 prior to the set RPM, and goes solid at the set RPM. If you set the light to 8000, then it would start blinking at 7500, which you cannot reach because of the rev-limiter. Therefore the light is effectively disabled.
Old Apr 22, 2005 | 07:13 AM
altered350z's Avatar
altered350z
i think the main reason is the room for upgrade so you can still use the light with a reflashed ecu
Old Apr 22, 2005 | 08:10 AM
kcobean's Avatar
kcobean
I highly doubt it. Nissan engineered the car for safe operation. It wouldn't make sense for them to tailor the shift light programming to support something "aftermarket" that involved a) altering parameters in ECU software that has to be reverse-engineered behind Nissan's back in order to flash it in the first place, and b) changes the factory operating specs outside of Nissan's normal "safe" limits. I think allowing it to be set so high was just a cheap way of adding a disable feature without having to actually add specific logic to do so. It would be cool if that was the reasoning though. Maybe then they'd be more willing to 'open source' the ECU program for aftermarket modification in the first place.
Old Apr 22, 2005 | 10:32 AM
JThrilla's Avatar
JThrilla
yea, the reason is so that the light can be disabled. I guess I"m wondering what the point of that light is in the first place? After it comes on, that means you should shift?
Old Apr 22, 2005 | 11:00 AM
kcobean's Avatar
kcobean
Yeah, it's really meant as a driving aid. The RPMS spool alot faster in this car than in many others, so it's there as either a) a warning that you're coming up on (blinking) or have reached (steady) your shift point without you having to really focus on the tach, or b)if you choose to set it a little lower, it's a reminder to find that next gear (especially 6th) so you don't cruise around at higher RPMS than necessary.
Old Apr 22, 2005 | 11:02 AM
Reggi914's Avatar
Reggi914
Its a shift light, like a reminder. You dont have to shift, but you can. You can set it to whatever rpm you want, that way it will kind of alert you that your at the set rpm.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Justin100
Nov 29, 2015 03:58 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
