Auto Climate Sucks for heating!
Anyone else notice the auto climate control is a big wussy when it comes to heating up the car?
I typically leave mine at 75, but now that its cold out (30 deg) when I drive the Z, the auto settings never heat up the car! I always have to kick the heat to max, and put the fan off auto to get it blowing.
I know the heater isn't hot at first, but the controls do not even TRY at all to heat up the car.. I have override it.. and then once the car is heated up.. the auto settings work fine.
Anyone else experience this?
works as designed, it doesnt want to just blow cold air out, it starts blowing as the car warms up. I like the feature, I hate having cold air circulated around the car, just makes things worse.
The auto controls work like they're supposed to. Auto climate controls don't use the fan until the air has reached an acceptable temperature (in other words, until the car has warmed-up enough that the heat is working). Having the fan blow cold air will only make the cabin feel colder. I don't really understand what you're complaining about.
If I leave it at auto.. it never heats up.. even after 10+ minutes of highway driving.... after which I cave in (because I'm freezing) and set to manual.
If I put it on manual to start with.. it heats up in about 2 minutes.
I'll put that timer in the dash computer to use tomorrow and see how long it takes for auto climate to start blowing hot air.
the heater runs off the hot oil I believe, meaning it further cools the engine just like the radiator. on a hot day if you want to keep your car from over heating turn on the heater. on this same principle, turning the heater on early will make the engine take longer to heat up. as for 8 minutes longer... well no. and the same amount of heat is produced in the long run, but untill the air hits a certain temp I dont think we car if the air is 40degrees or 50degrees.
Its 30deg outside.. probably 55 deg in the car... and the thermostat is set at 75. 75 > 55 = heater on
So the car should heat up (heater air) in the same amount of time.. but it doesn't seem to be. I don't think the car is turning on the heater. Maybe it will not turn it on in auto mode till the oil is a certain temp? Seems like extra checking for no reason.. but who knows?
in 32degree weather, a fully cooled car will be 32 degrees, meaning it will not do anything to the air to warm it up, anything it could maybe do will be negated by the fact that stagnant 32 degree air is preferable to moving 45degree air. as the air warms up it turns on the blower slowly.
but of course, some times you do just want it on, and for that, the manual mode is there. I use it sometimes for defrosting the windsheild, I move the mode selector to mix, but nothing is blowing since the car is cold, but Ill turn it up anyway. this might not be helping anything, but it makes me feel better, so I do it.
That would, I suppose, cool the engine to a small degree, but I don't believe the system worries about that too much.
Originally posted by MannishBoy
Say what? I've never seen a car that worked like that. All I've ever seen use engine coolant running through a heater core to provide heat. I doubt oil has anything to do with it.
the radiator coolant definatly heats the heater air. If you have a bad thermostat (stuck open) your heater will not work...and your car also never heats up properly
It's 30 degree right now...
A good thing to do is wake, run out the garage and crank her at least 15 min before you leave.(30 degrees in your boxers isn't that fun though) Go inside get ready and by the time you hit the Z it's all warm and cozy.
Crack the garage though if you're going to let it run that long. x_x
whoops yeah your right, radiator coolant does it. either way, radiator coolant is heated by the engine/oil/whatever else. bottom line, the heat must come from a hot engine. till then it doesnt matter.
but my Z warms up fast... 5minutes tops, and the heater is great, not that it has to work real hard to heat the small cabin, but all the same, Im very comfortable within 5 minutes, where past cars took as much as 15 minutes before I could begin to feel warmth in the air, and then it had to actually raise the temp to a cofortable level.
Guest
Posts: n/a
Originally posted by OP Z
You should always start and drive a cold car to minimize the wear.
READ your manual. For EVERY car, you should warm up the engine before you drive!!
One of the major reasons for engine wear is that oil flow at cold temperature is reduced and therefore the operation of the engine is harsh. When the oil pressure builds up, (that is the oil reaches operating temp), it flows well and thus provides better protection! (That's one of the reasons synthetic is better, since it flows better at extreme low and high temp)
Please, please DO NOT just post anything. Verify it first and then post it. It causes confusion, u know.
May be idling 15mins is too long, but hey, it's not how long you idle, it's when the car reaches operating temp matters! May be in some part of the country it's necessary to run that long to warm up the engine!!
porscheKliier, I did read the manual, and can not find the part about letting the car idle until it reaches operating temperature. The only advice given about warming up the engine is to let it idle for at least 30 seconds and then drive at moderate speed for a short distance, especially in cold weather. I know that "at least 30 seconds" is open to interpretation, but I have read in many places that leaving the engine idle for more than a minute or two to "warm up" is unnecessary, even bad for it. The consensus from the tech sources I have read is to leave the engine idle for a minute, then drive conservatively for a few minutes. Not saying it's fact, just what I've read.
i think the Z heats up really fast. But i have been told that all new cars do. (smaller water jacket, smaller coolant volume) i would say that it doesn't get real hot like other cars. in other words, it doesn't blast you with heat. when it gets below 20 degrees F the heater just can't keep fresh air very warm. Below 10, no way. the cabin will never reach 75, but it is a sports car, not an artic transport. to Nissans credit, i think the environment operation is quite elegant. i like how it gradually changes fan levels and doesn't turn on the fan until there is something brewing. (unlike Audi's) but to that end, it just never seems to simply turn down. Hot or cold, it seems like it's a struggle for it to keep up.
if only the seat warmer worked better.
koryo
koryo
Guest
Posts: n/a
I only tried to oppose 'you should start and drive to prevent wear'
I also mentioned that 15mins may be too long, but however long it takes for it to warm up. In fact, my 99 GSX manual says 'do not rev to warm up the engine'... I'd think idling and letting it warm-up should be the way, not 'drive and warm-up'
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
