stuck in limp mode now
Old Jul 3, 2016 | 05:02 PM
johnmlebel's Avatar
johnmlebel
Default stuck in limp mode now
so this 03 car was a mess when i got it, wouldn't start nothing worked it was a mess. was an auto car and swapped to a 6 speed before i got it but they never finished. I now have it so it starts and runs but is in limp mode i guess. I have never worked on a newer nissan, lasts were a 90 300z and a 92 nx2000, i have a list of TPS APP codes it seems, should I go with the pedal being bad?
Old Jul 3, 2016 | 06:37 PM
Unicus's Avatar
Unicus
Did you do a full bleed out and ecu reset before you ran the test?
Here's the link I could find for relearns, there used to be a really nice one I had saved but the link died.
https://my350z.com/forum/maintenance...ml#post6008226
Old Jul 3, 2016 | 06:43 PM
johnmlebel's Avatar
johnmlebel
I tried a relearn a few times and the cel never flashes. I atlas got it to start. When i hold the pedal to th floor running it hits maybe 1800 rpm and thats it. Here is the voltage it is reading. And this is after multiple battery disconnects trying to figure out what was done to it before i got it.
Old Jul 4, 2016 | 12:37 PM
johnmlebel's Avatar
johnmlebel
throttle body doesn't respond with key on. Is that just bad then? nothing else would make it not respond right?
Old Jul 6, 2016 | 01:37 PM
johnmlebel's Avatar
johnmlebel
should the throttle body blade move when you press the accelerator pedal? will a possibly bad battery cause this?
Old Jul 10, 2016 | 08:09 AM
johnmlebel's Avatar
johnmlebel
not much help here it seems
Old Jul 10, 2016 | 05:03 PM
karlt's Avatar
karlt
You need to correct the U1000 fault before troubleshooting anything else. That fault code indicates an open or short circuit somewhere in the CAN bus wiring that connects all the computers. It could be as simple as a loose or disconnected connector. With an inoperative CAN bus, sensor readings cannot be passed from one unit to another, hence all the other fault codes.
Old Jul 10, 2016 | 05:07 PM
johnmlebel's Avatar
johnmlebel
its an auto to manual swap that i got in the middle of being done, the u1000 code will be there a while with this setup.
Old Jul 11, 2016 | 03:35 PM
karlt's Avatar
karlt
The U1000 code is probably the result of disconnecting the auto transmission's Transmission Control Module (TCM) from the CAN bus. When any module is disconnected from a CAN bus, the CAN high and CAN low pins on the harness connector need to be connected together through a 120-ohm resistor or the bus may fail. An open connector may be the reason for your various sensor faults.
Nabice
Aug 19, 2016 08:13 AM
Moncef
Tuning
Jun 9, 2016 03:43 AM
Jun 8, 2016 06:22 AM
Tanahara
May 15, 2016 07:05 PM
Karwo Z
May 4, 2016 05:50 PM
