Won’t start intermittently
Old May 8, 2020 | 08:00 PM
NzZ's Avatar
NzZ
Default Won’t start intermittently
Hi guys,
Long time Z lover. Had mine almost 17 years. Now at 54k miles my car intermittently won’t start. It intermittently won’t even crank. The battery is fine. All maintenance up to date. Had a similar issue about 3 years and 6k miles ago and replaced both crank sensors - it’s been perfect since then. Scanned with an OBD app and got pending code P000A which is cam shaft sensor bank 1. Seems strange that sensor would go bad so quickly ? Could this be another issue such as the crank position sensor?
Would love your input.
Thanks,
NzZ
Old May 9, 2020 | 05:55 AM
dkmura's Avatar
dkmura
General & DIY Moderator
P000A has quite a bit more to it. Possibilities include:
Cam position sensor replacement or
  1. N205 valve replacement.
  2. Clearing of the oil pump pickup tube filter and other oil passages.
  3. Wiring/connector replacement to or from the camshaft adjustment valve.
  4. Oil pump replacement.
  5. VCT phaser replacement.
  6. Retiming of the engine.
Never seen it myself. I'd suspect the CPS first, particularly if it's an off-brand. Pull it and check the plug and wiring while you're inspecting it.
Old May 9, 2020 | 07:30 AM
jhc's Avatar
jhc
General & Tech Moderator
I'd also be concerned about the low-tech stuff. IF you've had the battery load - tested the next obvious thing to look at is 17 year old battery cables. Oxidation can run up a cable unseen under the vinyl and cause problems . If you haven't already, I'd be inclined to change them out just for peace of mind.
Old May 9, 2020 | 09:32 AM
NzZ's Avatar
NzZ
Thanks for the tips guys. Would these other issues also cause intermittent problems? I ask bc the symptoms seem identical to the cam position sensor which I replaced with an OEM Nissan part (both banks). Just trying to troubleshoot as we know the dealer will probably want $1500 to replace a bunch of parts that aren’t related - they wanted over $750 to do the CPS a few years ago. Cost me $110 and took under half an hour lol.
NzZ
Old May 9, 2020 | 11:33 AM
Zelduh's Avatar
Zelduh
+1 for the cables. If I have to replace a cam or crank sensor, I do the others to be done with it.
Old May 9, 2020 | 01:27 PM
NzZ's Avatar
NzZ
If the cables were bad wouldn’t the car not start at all? When I turn the key to accessory mode the AC and radio turn on. But when I twist the key to start the engine there’s no cranking. Then one in maybe ten attempts it will start. Tried again today and got P000A and P0006 codes. May replace both cam sensors again but it seems strange they would go bad so quickly.
Thanks again for your input.
NzZ
Old May 10, 2020 | 08:05 AM
jhc's Avatar
jhc
Let me put it like this-
Compare the necessary amperage draw of your radio and starter.
My statement was the "possibility" of corosion, exactly the symptoms you describe. May I suggest -
Use another key if possible.
With a helper disconnect the cable from the starter and measure voltage when key is turned to "start". (Do not handle the wiring during this).
Since you have codes I would erase them. If that doesn't work, replace the parts.
Gl!
Old May 10, 2020 | 09:22 AM
bealljk's Avatar
bealljk
Originally Posted by jhc
Let me put it like this-Compare the necessary amperage draw of your radio and starter.
From a little crank/no start I just had on this red z I just picked up from Copart ... the positive terminal was connected and power was being delivered to the car and was enough to crank / activate the starter but the car would not catch/run.
The big clue, when we cranked the car, the scan tool (granted it was a snap solus) was that the scanner was going dead after the engine was cranked (ie check fuses and check battery connection). The issue was that the positive side terminal was not 100% tight/snuged-on...it had 10ft-lbs of torque on it, where it needed 35.
The lesson I learned was even though the cables appear to be fine, double check them and replace them if they are questionable.
SilverGLE
Apr 9, 2019 05:44 AM
DewsZ12
Jun 24, 2018 05:37 AM
Shawn Hancock
May 5, 2015 02:02 PM
RA11325
Aug 23, 2013 06:20 PM
team1320350z
Jul 13, 2008 02:09 PM
