any base 350Zs with feathering?
Old Jun 8, 2004 | 04:32 PM
ml2316's Avatar
ml2316
Default any base 350Zs with feathering?
this is a longshot. but to my knowledge i don't recall any owners of base 350Zs reporting feathering. this is probably attributable to the fact that base models are fewer in number than other trim levels, but i'm still curious.
Old Jun 8, 2004 | 04:41 PM
robcassell's Avatar
robcassell
all 350z's have tire feathering. all have same susspension, that is the reason
KrazY-2K's Avatar
KrazY-2K
Nope... no signs of feathering on mine and it's an '03 if that helps.
Old Jun 8, 2004 | 05:17 PM
mb27's Avatar
mb27
Mine is a base with 30k miles and no feathering.
Old Jun 8, 2004 | 05:26 PM
04_CS_Z33's Avatar
04_CS_Z33
Nope, but then again, I only have 1500 miles.
Old Jun 8, 2004 | 08:02 PM
gra350z's Avatar
gra350z
None here , only 2300 miles.
Old Jun 8, 2004 | 08:40 PM
rockinar's Avatar
rockinar
I just bought an 04 yesterday. What exactly is feathering?
Old Jun 8, 2004 | 08:51 PM
trash259's Avatar
trash259
No feathering 4 me. Had my car checked last week and dealer said nothing is wrong.
Old Jun 8, 2004 | 08:57 PM
ml2316's Avatar
ml2316
well i did use the word "longshot". and i'm not disagreeing with you, but nobody has actually confirmed that suspension is the problem... i.e. nobody with suspension upgrades has reported their problem is fixed (that i've read).
Old Jun 9, 2004 | 07:02 AM
Silver04Z's Avatar
Silver04Z
No feathering. I have about 3000 miles on a 2004 Z Base built in 02/04.
Old Jun 9, 2004 | 07:32 AM
yobri's Avatar
yobri
None on mine either, about 6500 miles and a build date of 3/03. The fronts are absolutely perfect still although the rear negative camber is very prominent
Old Jun 9, 2004 | 09:22 AM
Silver_Racer's Avatar
Silver_Racer
I just purchasd my Z and was concerned about the feathering. I was told by the salesman that Nissan said this in only on cars with VDC and 18" wheels. Mainly that the VDC was causing it. Anyways, I have the base model.
Old Jun 9, 2004 | 11:32 AM
stevew's Avatar
stevew
I have a base, build date 1/03, had the TSB for feathering done two months ago.
Old Jun 9, 2004 | 12:02 PM
nmilsaps's Avatar
nmilsaps
03 Base with almost 13K miles. had tire feathering fixed and new tires at 11K.
Old Jun 9, 2004 | 05:22 PM
BRONXWARRIOR's Avatar
BRONXWARRIOR
going in for the third time and third set of tires .
NCA told me if it comes back after the warranty is up they will take care of it
Old Jun 9, 2004 | 06:22 PM
NismoKid's Avatar
NismoKid
4,600 miles with 2/03 build date and no feathering. I did however get the alignment redone at 1,100 miles to correct the drifting to the right (the toe was out).
Old Jun 9, 2004 | 06:48 PM
ml2316's Avatar
ml2316
thanks for the responses. clears that up.
416blueZ
Jun 11, 2024 10:56 AM
hulkout
Apr 28, 2017 09:00 PM
WillyP28
Oct 12, 2015 04:24 PM
hardkicks
Sep 20, 2015 12:28 PM
