2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
How does "S Mode" works on MT?
Old Nov 21, 2008 | 07:33 PM
enuff4life's Avatar
enuff4life
Default How does "S Mode" works on MT?
I saw a video that does not have a sound on youtube. When the driver downshifts, the rev automatically matches without any throtle.
So my question is... If we upshift, will it also match the correct rev for next gear? and how does it work?
Old Nov 21, 2008 | 08:54 PM
whoady4shoady's Avatar
whoady4shoady
Just search. There are many other threads with this already.
Old Nov 21, 2008 | 09:37 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
You don't rev-match when you're upshifting. The process of accelerating naturally matches revs. It's for down only.
Old Nov 22, 2008 | 08:55 AM
Mike@RiversideInfiniti's Avatar
Vendor - Former Vendor
even if you granny upshift?
Will the system work on downshifts with a lightened flywheel?
Old Nov 22, 2008 | 09:02 AM
DIGItonium's Avatar
DIGItonium
https://my350z.com/forum/2009-370z/4...rev-match.html
https://my350z.com/forum/2009-370z/3...n-trannys.html
https://my350z.com/forum/2009-370z/3...1-11-08-a.html
I just posted wondering if the system can be defeated by blipping the throttle first before the computer takes over.
Old Nov 22, 2008 | 01:00 PM
TreeFiddyZee
Do WHAAAAT!?
...or you push the button to shut it off.
Old Nov 22, 2008 | 02:46 PM
Here's another gizmo by Nissan that we have to figure out how to disable.
Old Nov 22, 2008 | 05:13 PM
bruddahmatt's Avatar
bruddahmatt
Yah you know...or not.
Old Nov 23, 2008 | 08:07 AM
DIGItonium's Avatar
DIGItonium
The S-Mode switch is not an effective solution to this dilemma.
What happens if you manually blip the throttle while the computer tries to rev on its own? I'm questioning the full-proof nature of this design.
Though none of us has tried this on our own, but it's something to think about.
Old Nov 23, 2008 | 08:12 AM
PA 19103's Avatar
PA 19103
You know know if this thing defaults ON or OFF when you start your car?
Maybe let's just hope this S-Mode thing uses its own fuse, I would just unplug that fuse slot from the fuse box. Problem solved! I'll do my own rev matching, thank you Nissan.
Old Nov 23, 2008 | 08:14 AM
DIGItonium's Avatar
DIGItonium
None of us know, which is why I'm curious other than to opt out of the Sports Package (crazy?). LOL.
Old Nov 23, 2008 | 02:16 PM
bruddahmatt
Pushing the button disables the SRM system which allows you to perform your own heel and toe downshifts. So yes, this is an effective solution.
This of course is the one catch. They system defaults to on when you start the car. Not sure if there's a way to set the default to off. I know several features on Infinitis such as their Lane Departure Warning can be set so that it defaults to off (many people don't know this) so here's hoping that you can do the same with SRM. If not, someone will make a mod.
Old Nov 24, 2008 | 08:50 PM
DIGItonium's Avatar
DIGItonium
I understand the switch is an effective solution, but I'm not getting this "full-proof" design. For days where one forgets to turn it off and tries to heel-toe with the system engaged, I wonder about the likelihood of double-blipping the throttle.
Sure you can solve these dilemmas with a simple switch, but what happens when you forget?
I know I sometimes forget to turn off TCS before launching and end up bogging down the track.
Old Nov 25, 2008 | 08:00 PM
dyezak's Avatar
dyezak
So you're blaming the "problem" on your inability to remember to push a button? Yup, your mental fortitude is Nissan's problem. Might want to go in for warantee work on your attention span.
Old Nov 25, 2008 | 09:04 PM
DIGItonium's Avatar
DIGItonium
Mature. Don't get me started on your spelling either.
I'm not blaming, and I'm not saying there's a problem. I'm curious, so what good do you have to contribute to this forum with regards to your smart-*** comment?
I wonder what happens if the driver tries to rev-match while the SynchroRev system is active. Mr. Obvious says there's an S-Mode switch to press to disengage the system. Big whoop. I know that, but what happens when the driver forgets to disengage the system?
It is something to discuss and think about until the car arrives in showrooms. what the hostility is about.
Old Nov 25, 2008 | 10:46 PM
CaliTouring's Avatar
CaliTouring
LOL looks like another nissan tranny option that will void your warranty if you use it.
Old Nov 26, 2008 | 05:43 AM
bryan@Z1's Avatar
bryan@Z1
I'm still trying to figure out what "full-proof" means.....
Fool proof would be the better usage.
Old Nov 26, 2008 | 06:31 AM
DIGItonium's Avatar
DIGItonium
Ah, I subconsciously misspelled the word. I'm just curious what happens when the system is still active when you try to manually rev-match. IIRC, Edmund's reviewer notice the car revved real high when popping out of gear after hard acceleration.
Old Nov 26, 2008 | 06:43 AM
in.the.dark's Avatar
in.the.dark
DIGI,
Likely it's all accounted for in the electronic throttle programming. If you blip with S mode on, it may ignore it completely or only add the additional throttle input over what is already there. It may also set a temporary rev limit to prevent over-revving. I'm sure they thought about it. Nissan is a big company with a lot of engineers and a lot of testing is done from a quality control testing that basically asks what could go wrong in the hands of an idiot.
Old Nov 26, 2008 | 07:07 AM
DIGItonium's Avatar
DIGItonium
Originally Posted by in.the.dark
DIGI,
Understood.
I guess if it goes out of hand they will probably comment out that code and disable it (i.e., GT-R's launch control).
