Need help installing my EDFC rear motors! Please Help Thanks!
Old Jul 18, 2010 | 08:28 PM
RaulAirZoom95's Avatar
RaulAirZoom95
Default Need help installing my EDFC rear motors! Please Help Thanks!
Hi i successfully installed the front edfc motors but when i tried to install the rears well i can find the rear strut top please help!!!
Old Jul 18, 2010 | 08:49 PM
gshadyz's Avatar
gshadyz
you have to drill a hole for the reas. so you can access the EDFC wire connection I can post up some pic if you like
Old Jul 18, 2010 | 08:52 PM
JasonZ-YA's Avatar
JasonZ-YA
wuold it not fit in there if you just drop the shock by removing the two nuts from the wheel well side and mount the motors, feed the wire up through the strut bar hole...etc...etc..??
-J
Old Jul 18, 2010 | 10:33 PM
RaulAirZoom95
gshadyz please post pics of the convertible lay out bro thanks Raul
Old Jul 20, 2010 | 07:26 PM
vtchang's Avatar
vtchang
You can't get to the rear strut bar from the up top.
https://my350z.com/forum/350z-roadst...extenders.html
Specifically, look at post #8 and #16. That is where you'll feed your EDFC cable through.
When I installed my rear view camera, i fed the line through the driver side of the rear firewall as there is a passage way into the sub.
Old Jul 20, 2010 | 09:42 PM
RaulAirZoom95
Thanks vtchang! for the heads up!
i was able to figure it out today i removed the rear struts and feed the lines that connect to the tein motors through the hole where the strut goes(RL-F1347 & RR-F1346). (i previously removed all the stuff in the truck) they came out through the trunk where the motors for the convertible are. i installed the rear motors on the struts (per EDFC manual) and plugged them into (RL-F1347 & RR-F1346). i then ran the edfc wire (RL-F1347) next to the oem main harness wires (on the drivers side) and followed them through to the tonneau area. For edfc wire (RR-F1346) i ran it through a whole next to the passangers side convertible motor that leads to the tonneau area. I zip tied both(RL-F1347 & RR-F1346) wires and ran them along the oem main harness wires that lead into the rear subwoofer behind the drivers seat. i installed the edfc controller in front of the shifter (plugged the front motors in, which had been previously installed) then ran the edfc wire (R Cable F1322) that plugs into the rear motors through the center console. (i removed the center console, at the rear of where the console lays there are two ovals that lead to the empty space behind the subwoofer). i ran Cable F1322 through there and plugged it into the edfc wires (RL-F1347 & RR-F1346). Last i plugged up the power wire and Green she went!!!! Whoop!!! Whoop!!!
Old Jul 20, 2010 | 09:48 PM
RaulAirZoom95
Will post pics later today!
Old Jul 21, 2010 | 04:52 AM
JasonZ-YA's Avatar
JasonZ-YA
aaahhhh, you have a roadster....my bad..LOL, I fail at reading what subforum i fell in...lol..
ya VTchangs thread is baller...
-J
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
SharX59
Sep 27, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
