Aftermarket battery...
Old Nov 26, 2005 | 09:52 PM
  #41
808_FairladyZ's Avatar
808_FairladyZ
I used 2 peices of mdf particle board, cut them to fit, and stacked them up to get a 1.5" spacer. This had closed the gap and allowed me to use the stock mounting bracket. Actully extending the power wire was harder.
Old Nov 26, 2005 | 10:51 PM
  #42
jdg345's Avatar
jdg345
Thank you! It was suggested that I not use wood as it could absorb water and create a rust-prone environment? How about cutting those rubber mats that they use for flooring in children's play areas? Would that work? Is that all we need? 1.5"?
Old Nov 26, 2005 | 11:08 PM
  #43
808_FairladyZ
You make a VERY good point about the wood. Damn i better go and look into more carefully. Actully, you don't need so big of a spacer being that the mounting threads on the brackets aren't that far off. What ever you can get that wont cause a rust problem i guess will work. To be honest though, water damage never crossed my mind because its such a tightly closed up area. Go figure?
Old Nov 26, 2005 | 11:24 PM
  #44
jdg345's Avatar
jdg345
Oh ... heh ... Ooops ... sorry ...
Maybe a bunch of washers will do it ... ?
1" worth of washers isn't enough ... Are you using the Stinger Power2 SP1000 ?
Old Nov 27, 2005 | 12:02 AM
  #45
808_FairladyZ
I'm using a Yellow Top Optima.
Old Nov 27, 2005 | 12:29 AM
  #46
jdg345's Avatar
jdg345
Dimensions?
Old Nov 27, 2005 | 03:08 AM
  #47
Z BOY's Avatar
Z BOY
lightest one i've seen:
Attached Thumbnails Aftermarket battery...-275874333undptv_ph.jpg   Aftermarket battery...-275874304fgbuvo_ph.jpg   Aftermarket battery...-275874468vzvopa_ph.jpg
Old Nov 27, 2005 | 08:38 AM
  #48
gabez33's Avatar
gabez33
Originally Posted by pingrr
I have an optima yellow top in my Eclipse (I don't know if it light weight or not). I am running two 12" L7's with two kicker 850.2 amps with no problems at all.
I would highly recomend the yellowtop.
pleaaaaaaaaaaaassse POST PICS!!!!!!!!! I got my 2 L7 subs and amps ready to go...But i dont know what kinda box or set up to do...
Old Nov 30, 2005 | 09:55 AM
  #49
gringott's Avatar
gringott
I emailed Optima and Erica at 1.800.292.4359 stated the Red 35 is recommended for the 350Z, and the Yellow D35 if you have aftermarket accessories exceeding 400 watts. Hope this helps.
File Type: pdf
File Type: pdf
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
SharX59
Sep 27, 2015 09:23 AM
