how to upgrade sound system
Old Aug 19, 2006 | 01:36 PM
photo2u's Avatar
photo2u
Default how to upgrade sound system
Friend,
I am going to install a Kenwood dual din head unit with navigational system and a Kenwood 4 channel amp. Also I would like make all the necessary cable upgrades for possible rear camera and second monitor upgrade.
Please advice as to what parts would I need location of Kenwood amp placement, and best ways to put or pass the necessary wires or connectors.
George from Pasadena,
2006 Enthusiast Silver -Volks te 37 mercury silver Burn Orange leather seat- pop charger - s2000 antenna.Nismo Mats Soon to be install kenwood ddx6019 stereo navigational system.
Old Aug 19, 2006 | 05:37 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Do you have the Bose or the base stereo system?
Either way get the correct cable adapter from Crutchfield. I highly recommend against whacking into the stock cables and if you do the wires really ought to be soldiered into place. Having a hot iron in your dash for a dozen wires worth of connections is a sure FIRE way to burn something. The adapter is $20 what ever well spent.
The amplifiers can go into the luggage cubby behind the passenger or on a custom made plate behind where the Bose subwoofer went behind the driver.
The key is to do it right the first time - invest in some proper power and ground cable and distribution system hardware, use good RCA cables, and soldier all connections.
Depending on what year Z you have the second screen can go where the factory navigation went in the dash.
The rear view camera isn't that difficult either.
The best way to go is to invest in some quality hardware and cables for the power and ground systems, solder all connections, and have everything planned out before tearing into the job. Each of your modifications have how-to's posted at the top of the forum. Read them over and make sure you don't have any questions before begining.
Good luck and if you run into trouble there are plenty here who can help.
Old Aug 19, 2006 | 07:23 PM
photo2u's Avatar
photo2u
Dear friend,
Thank for the great information.
I just have have a question.
When you mention adapter? I got the following from a member of this site. the install kit (99-7602) and wire harness (70-7550)
Am I correct with the 70-7750 metra harness/adapter? Also, I do not have the bose,
please advice,
Old Aug 20, 2006 | 06:34 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
What year car?
The '03-'05 have a common dash, the -'06 has a slightly different dash and needs a different face plate kit. I like the Metra kit better than the American International one.
If you'll enter your data into Cruthfield's "What Fits" they'll give you a complete run down on what fits your car all for free using their on-line system.
Old Aug 20, 2006 | 09:29 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
for 06 the wiring kitis the same, but you will need the 06 350z kit, metra part number 99-7602 .
as for location of the amp, a common place is in the stock bose sub placement behind the seat, but its not just simply throw it in there you will want to build a solid platform there, and then put the amp on it, wire i tup...
again, if you havent done such a system before, it may be good to have someone help you along
b
Old Aug 20, 2006 | 10:09 AM
highside107's Avatar
highside107
b
+1 on the amp behind the driver's seat. That's a good place to start. Build a rack there, but don't get too "drill happy" as the Z's fuel tank sits right underneath it.
Old Aug 20, 2006 | 11:23 AM
photo2u's Avatar
photo2u
Friends,
Thank you for your imput. I bought the installationl kit (99-7602) and wire harness (70-7550) from a forum member mig.
To wire the amp would I need a 8 GUAGE CAR AUDIO STEREO 1000W SYSTEM AMPLIFIER AMP KIT and Grounding Terminal 1/0 - 4 Ga Ground Block Audiopipe.
Please advice,
Old Aug 20, 2006 | 11:38 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
just get a 4 guage wiring kit..., and you will need some decent rcas..
get a good 4 guage wiring kit, and then get yourself a pair of twisted pair RCA around 17feet in length...
how many amps and speakres are you running? that will determine what wiring you will need
b
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
