Base 350z Stereo Speakers
Old Apr 14, 2009 | 08:25 PM
harkroad's Avatar
harkroad
Default Base 350z Stereo Speakers
i just bought a 2007 350z base and only 2 of the door speakers work. I think. When Move the fade to the rear there is no sound. But the Fade front has sound. Doesn't that mean the speakers are broken in the rear? Are they supposed to work?
Old Apr 14, 2009 | 08:54 PM
phatz33's Avatar
phatz33
My car is like that too, the rears barely do anything. The base speakers are trash, time to upgrade!
Old Apr 14, 2009 | 09:20 PM
neosolipsism's Avatar
neosolipsism
They might work, they just suck so bad you can't hear them. I replace factory speakers on a weekly basis, and these are some of the smallest, cheapest OEM speakers I've ever seen. I doubt the Bose upgrade is much better off either. Very few OEM receivers use aggressive highpass filtering, resulting in bass-induced distortion at high volume levels.
The speakers are not hard to replace, though taking the rear panels apart may make you nervous. 6.5"s all the way around. There's even a lovely spot to install amps in the compartment underneath the rear speaker housing. Just be careful about mounting depth on the fronts or your window will bottom out on the magnet. If you search around I'm sure you can find an illustrated guide on replacing them.
If music is a concern, do yourself a favor and buy some aftermarket speakers. There's hundreds of brands, and even the flea-market gear is better than the factory ones. You should be able to pick up good name brand ones for less than $200 for all four. Of course the extremely loud ones require an amp and a bigger wallet.
Old Apr 15, 2009 | 01:25 PM
neosolipsism
Stock front speakers vs. Alp Type-R.
Old Apr 15, 2009 | 01:42 PM
harkroad's Avatar
harkroad
Yah i have installed speakers before in my Xterra. So it not a big deal. I just didnt realize they were that bad.
Old Apr 15, 2009 | 05:26 PM
Spike100's Avatar
Spike100
The best thing to with your rear speakers is fade them to “no sound.”
If you are not the original owner and not hearing any sound from the rears, I would guess that the previous owner simply disconnected these junk rear speakers (they are horrible and only pollute your sound).
--Spike
Old Apr 16, 2009 | 06:58 PM
Anthony S.'s Avatar
Anthony S.
mine do not put out much sound, and i bought my 07 new. when i took them out to put in my two subs i looked at the back of the rear speakers and found that they are 32 ohm speakers. they would have been louder if they were 8 ohm or even 4 ohm. I think they are only meant for ambient sound, not a center stage.
Old Apr 16, 2009 | 07:01 PM
zerafian's Avatar
zerafian
the bose and regular stock speakers both suck. If your looking for some decent sound upgrade...like others have said.
Old Apr 28, 2009 | 08:26 PM
erick350z's Avatar
erick350z
Default stereo question
are all 2006 350z stock stereos compatible with the steering wheel audio controls? the reason is cause i'm buying a stock stereo from a z that doesnt have the audio controls on the steering wheel and mine does have those controls on the steering wheel.
thanks,
Old May 19, 2009 | 04:28 PM
shystieone's Avatar
shystieone
if I swapped out my rear speakers for aftermarket coaxials.. say an average $40 pair of speakers. Would the speakers be louder (like the fronts) or would they be extremely low, just like the stock speakers.
Old May 20, 2009 | 04:36 PM
Spike100's Avatar
Spike100
^^ I put Infinity coaxial speakers (about $50 on ebay) in the rear speaker space. They were much better than the stock speakers. I do not have the Bose setup.
--Spike
Workshop12
Mar 23, 2020 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
416blueZ
Sep 25, 2015 10:00 AM
hardkicks
Sep 20, 2015 12:28 PM
