Not getting reception
Old Jun 20, 2009 | 09:58 AM
04SilverZ35's Avatar
04SilverZ35
Default Not getting reception
My stations are not coming in clearly. I searched the forum and people seem to say its the wiring harness. Mine seems to be done correct.
Also where the antenna goes into the hu its connected to a small black box. I have a long wire coming from it that was never hooked up, whats it for? and could this be the problem?
I tried going to the drive inn theater and had to be moved to the side of another car because I was the only car there that could not get the station. What else could be the problem. Also I think the previous owner had satellite radio hooked up at one point.
Old Jun 20, 2009 | 11:08 AM
Mazinger Z's Avatar
Mazinger Z
I have pretty bad reception after installing an HU. I've done the wiring harness 2-3 times to make sure it's right and it is. I'm thinking for some reason it's not powering up the aux. antennae amplifier that Z's have. Subscribing for some answers.
Old Jun 20, 2009 | 11:40 AM
04SilverZ35
wow. I just re-installed my factory hu. Reception is clear as day, I get every station. It has to be the harness. Time to do the harness again I think
Old Jun 20, 2009 | 04:49 PM
Mazinger Z's Avatar
Mazinger Z
If you figure it out, post results here!
Old Jun 20, 2009 | 08:15 PM
04SilverZ35
I solved the problem... Every station now comes in. Give it a try..
On the harness Unplug both the blue/white stripe wire and the solid blue wire
Plug the solid blue wire into the blue/white and the blue/white into the solid blue.
Just change the two wires and mix match solid blue with blue/white. Simple. Let me know how it works this might help a lot of people.
Old Jun 20, 2009 | 08:26 PM
Mazinger Z's Avatar
Mazinger Z
K, gonna try this tomorrow. I'm sick of listening to the same songs on my ipod!!!
Old Jun 21, 2009 | 09:25 AM
NttnbutaZthang's Avatar
NttnbutaZthang
this wont work very well if you have factory bose
Old Jun 21, 2009 | 03:20 PM
CancerJCCz's Avatar
CancerJCCz
Get XM. J/k glad you got it working.
Old Jun 21, 2009 | 05:20 PM
04SilverZ35
Ya that Ipod was getting too me. I know every song before it comes on. I just hope this works for some others as well. I know a lot of people are having problem with reception on there aftermarket hu.
Old Jun 21, 2009 | 05:49 PM
Mazinger Z's Avatar
Mazinger Z
I ripped everything out and did it again. I followed 04silverz35's method and reception was awesome! But then my ipod didn't work... so I put all the wires together and soldered that ish together. It seems to get betting better reception now and ipod works. I hope it doesn't mess up my radio...
Old Jun 21, 2009 | 06:02 PM
BlueZ33's Avatar
BlueZ33
ok i tried this, with the extra wiring harness that i had but when i soldered all of the wires i only ended up with 1 solid blue wire and 1 blue and white wire. so im confused as to how to get my local radio stations to work, bc the ipod does become a bit too mononotous bc im too lazy to put new music on it any help would be great
Old Jun 22, 2009 | 06:18 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You need to provide DC power to the RF amplifier under the antenna in the trunk.
Old Jun 22, 2009 | 09:26 AM
Mazinger Z's Avatar
Mazinger Z
Solder all the blue/bluish wires together like me? Heh...
Old Jun 22, 2009 | 02:01 PM
BlueZ33's Avatar
BlueZ33
thats what i did man, now i will admit that one or two of my stations come in a little bit more clearer but; what is this run power to the antenna in the hatch that you speak of?
Old Jun 22, 2009 | 07:46 PM
Mazinger Z's Avatar
Mazinger Z
I dunno... I'm thinking it's one of the blue/blue-white wires. I get all my stations pretty clear now so... I hope that **** doesn't fry!
Old Jul 6, 2009 | 01:05 PM
Vader007's Avatar
Vader007
This works! I just tried it today, was only getting one station, now they all come in strong!
Zrated
Jul 8, 2004 07:17 AM
dz_nuts408
Apr 21, 2004 05:47 PM
Jetpilot718
Mar 6, 2004 12:24 PM
jreiter
Mar 3, 2004 11:00 PM
alvareztony
Jul 17, 2003 09:11 AM
