My $100 like OEM fit NAVIGATION setup
Old Jul 22, 2011 | 12:04 PM
  #501
ColecatZ's Avatar
ColecatZ
Originally Posted by MI 35th
Colecat, Ive ben messing with mine for a little while before finally installing it.
Its comes down to how you have it modded. You don't need all the states' POIs delete the states you won't ever use, which for me is everything west of illinois
If you need some help let me know. It only freezes due to older CE tech trying to run a more advanced NAV system. if you have OS 1.62 stick to a 2gb SD if you have 1.64 get a transcend 133 4gb card. either way its not a $1500 nav, although for me it works better than the OEM and looks badass in the car.
Software versions don't matter much when the screen doesn't come on...
Old Jul 23, 2011 | 01:40 PM
  #502
MI 35th's Avatar
MI 35th
OGPremierMafia
Ouch the screen doesn't even power on? Yah Id be a tad bit upset. I bought mine new off Amazon for $75 so at least get him to give you the $$ back.
Old Jul 23, 2011 | 03:24 PM
  #503
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I will sell mine, with everything included and working properly, if anybody wants it. I bought it long ago with the intention of installing it in my car but I like my cubby space too much and it never happened. It's been sitting in the garage ever since.
Old Jul 23, 2011 | 03:38 PM
  #504
MI 35th's Avatar
MI 35th
OGPremierMafia
See i lost my cubby space to custom gauge pod when I was boosted, now that the car is all motor, gauges are gone and cubby is back and I wanted NAV instead.
Old Jul 25, 2011 | 09:21 PM
  #505
po8pimp's Avatar
po8pimp
I just updated my software if interested. Not only is there OCN8, but I have installed Mio Pocket as well. Take a look. http://forums.maxima.org/6th-generat...y-4-200-a.html figured I would share.
Old Jul 25, 2011 | 10:50 PM
  #506
ASpecTL's Avatar
ASpecTL
Sorry for crappy iPhone pic but favorite mod so far! Did this a couple months ago with an 03 cubby and stock software, couldn't figure out a way for the OCN8 to work unfortunately. The software started having problems at one point and I had to go in and reset the memory card and everything has been fine since!
Old Jul 26, 2011 | 03:45 AM
  #507
MI 35th's Avatar
MI 35th
OGPremierMafia
Thanks for the that. Its up to us to keep support around for this system since the OEM support is all dried up.
I will be using mine for NAV almost exclusively and a Forward Looking Infared Camera for those late night drives to avoid Animals.
Old Jul 26, 2011 | 05:31 AM
  #508
3hree5ive0ero
Retired Admin
More info on the above bolded, please.
Old Jul 26, 2011 | 06:59 AM
  #509
MI 35th's Avatar
MI 35th
OGPremierMafia
http://www.chinavasion.com/product_i...oducts_id=3338
Mounted to the front bumper and a acdc convertor
Old Jul 26, 2011 | 08:03 AM
  #510
3hree5ive0ero
Retired Admin
Very nice. Please let us know how the install goes and its actual practicality.
Old Jul 26, 2011 | 01:02 PM
  #511
MI 35th's Avatar
MI 35th
OGPremierMafia
roger, working on it.
Old Jul 26, 2011 | 01:16 PM
  #512
po8pimp's Avatar
po8pimp
http://www.gpspassion.com/forumsen/t...19&whichpage=1 here is Mio Pocket. I have this running as my OS and have OCN8 as an app inside the OS. I will be posting a video and screen shots on my orig post and provide a link to that later. Until then you can click on this link to see what MIO Pocket is all about.
Old Jul 31, 2011 | 09:21 AM
  #513
o2sys's Avatar
o2sys
wow almost two years since I posted this. Nice to see its still a popular mod.
Old Aug 2, 2011 | 12:18 PM
  #514
tam_anh's Avatar
tam_anh
I can't find good deal on these GPS systems anymore. There is only one left on Amazon for $120 .... If i buy it, it wouldn't be $100 mod anymore. And it's used!
Old Sep 16, 2011 | 04:05 PM
  #515
sssmasss's Avatar
sssmasss
plenio 2100 has a video/audio input port. I lost the cable. anyone know where i can get that cable. i looked around and only found audio cable only for that port.
Old Sep 16, 2011 | 04:08 PM
  #516
sssmasss's Avatar
sssmasss
plenio 2100 is a discontinued product! If you must pay 120 dollars for this unit, i think u should shop around for 7 inches gps with bluetooth option. I think lots of brand have the similar dimensions and better quality.
Old Sep 18, 2011 | 06:29 PM
  #517
350Speed's Avatar
350Speed
After 2 years, I still love this mod,. However, I haven't figure out how to add a speaker so I can hear the GPS and play dvd at the same time.
Old Sep 25, 2011 | 12:14 AM
  #518
sssmasss's Avatar
sssmasss
can anyone help me. i download both file unrar the files. i copied everything in the files to my sd card.
i insert the the card into my sd slot on plenio 2100
i then turned on the gps and waited for it to boot and warning screen came up.
i went to setting
i touched the os upgrade tab
the screen pop up and asked if i want to upgrade system files
i touched the okay tap
another screen pop up and says "Can not open NK.bin file from SD memory. Please check NK.bin file."
so how do load the igo8 map to this system? thanks. the files downloaded was on the first page of this thread. thanks
Old Sep 25, 2011 | 12:39 AM
  #519
sssmasss's Avatar
sssmasss
btw second link for megaupload keep failing to download. anyone have this file please reupload this. i think the corrupted file have something to do with i cannot upgrade the system.
Old Sep 25, 2011 | 02:40 PM
  #520
sssmasss's Avatar
sssmasss
stupid me. okay i have figuired how it work. basically just insert the sd car and go to navigation function.
it doesnt work however. i got fatal error on POI. when i shut down the navigation it says error cannot exit program. and then i have to restart the plenio
