My $100 like OEM fit NAVIGATION setup
Old Mar 8, 2010 | 06:11 PM
  #421
WESTINZ's Avatar
WESTINZ
o2sys thanks again for your help. I removed all of the poi's except for three surrounding states. The problem was that that the poi's were being saved in a "save file". Once I deleted that it worked perfectly. The down load on the first post was a life saver, thanks again it looks and works great.
Old Mar 13, 2010 | 09:50 AM
  #422
aduhm619's Avatar
aduhm619
GPS for sale in Chula Vista on craigslist
Old Mar 14, 2010 | 03:55 PM
  #423
VanDamme22's Avatar
VanDamme22
Yeah, but there's no power cable or antenna.
Old Mar 14, 2010 | 09:05 PM
  #424
o2sys's Avatar
o2sys
Antenna will be the tough one, the power source is easy to get.
Old Mar 18, 2010 | 12:28 PM
  #425
06blueZ's Avatar
06blueZ
been having some weird glitches with my Plenio lately. Sometimes the GPS wont connect and the triangle pointer just flashes in OCN8. Also this morning for the first time the initial turn on loading screen came up, then the screen went blank. It was still on, could tell by hearing clicking sounds when i touched the screen, but the screen was totally blank. Once I got to work, i turned the car off and then back to acc power, and the unit powered up normally, werid... I kind of wish i had hard wired in a power switch for it for issues like that, but I wired it up to work with ACC power only.
Old Mar 18, 2010 | 12:30 PM
  #426
o2sys's Avatar
o2sys
GPS connection i think it depends on your area. Sometime i dont get reception till 5 min after. Sometime its already at full bar the moment it loads.
Old Mar 22, 2010 | 07:51 PM
  #427
sdZ33's Avatar
sdZ33
Can someone help me out? I downloaded the two links provided in the first post to my computer and it saved it as .RAR files... Where do I go from there? Any help is appreciated... Thanks!
Old Mar 22, 2010 | 09:14 PM
  #428
o2sys's Avatar
o2sys
replied to your PM. Unzip the RAR and copy the files over.
Old Mar 25, 2010 | 07:35 AM
  #429
burner's Avatar
burner
Hey all,
Figured I'd follow up with this thread. I've been using the Plenio/OCN8 combo for about 8 months now, and haven't had a single issue with it. It works great. I have one complaint about the nav though...when setting a destination, it doesn't tell you which side of the road it is on, which sometimes sucks when driving on a busy road trying to find something. My 4Runners OEM nav system does this, I don't understand why it can't do that. Maybe with the next version. That is my only complaint though, reliability on the system has been excellent.
Old Apr 6, 2010 | 07:41 AM
  #430
snair2's Avatar
snair2
So basically, if I downloaded the first two links on this thread, remove the necessary POIs to free up space, then copy and paste everything to my SD Card, then pop the SD Card into the Plenio (I have the 2100 model), it will all work properly with no issues?
Old Apr 25, 2010 | 01:48 AM
  #431
gtnotoriouz's Avatar
gtnotoriouz
Are there any alternatives for this product? Is anyone selling theirs?
Old Apr 25, 2010 | 07:15 PM
  #432
o2sys's Avatar
o2sys
Yes thats pretty much it. I have the 2100 as well.
Try finding any other 7" Navi systems, doesn't HAVE to be PLENIO, its just that it happen to be a good fit for the 350Z.
Old May 10, 2010 | 11:09 AM
  #433
o2sys's Avatar
o2sys
I am planning on selling my entire setup, anyone who is interested PM~!
Old May 11, 2010 | 10:31 AM
  #434
bobos350's Avatar
bobos350
i ordered my plenio today!!
Old May 12, 2010 | 04:23 AM
  #435
Jonathan Allyn's Avatar
Jonathan Allyn
Same here. Picked up a brand new 2100 for 80$ off ebay. Was the only one there.
Old May 12, 2010 | 05:48 AM
  #436
Jonathan Allyn
Hey one question.. With the OCN8, it doesnt utilize TTS correct?
edit: NM. I answered my own question. It talks to you but does not say the names of the street. One follow up though. Does the 2100 have an audio out so I can add an external speaker to it for the voice?
Old May 12, 2010 | 07:07 AM
  #437
350Speed's Avatar
350Speed
I've been using the Plenio with OCN8 for almost 9 months. It works great. The only issue I have is the refresh feature keep turning of itself sometime. Does anybody has this issue?
Old May 25, 2010 | 10:54 AM
  #438
Asian Invasian's Avatar
Asian Invasian
When I load it up and hit the nav button it loads the nissan screen, then while its loading some init files it goes back to the default screen where I can pick games, pictures, etc.
However the navigation button is greyed out and unselectable.. anyone want to chime in?
I can't see the error as it throws it fast then reverts to the main screen..
Old May 25, 2010 | 11:12 AM
  #439
Asian Invasian
Here is what my crash log is saying:
WinCE CallStack snapshot (function names unknown - map file \SD MEMORY\OCN8\OCN8.map not found):
Old May 25, 2010 | 11:41 AM
  #440
Asian Invasian
New error now that I fixed that last part. Once I load and hit map I get this:
Error - Resetting
Error: map\usa_colorado.fbl
