Poor sound system?
Old Nov 14, 2009 | 06:11 PM
MrEnzoFerrari's Avatar
MrEnzoFerrari
Default Poor sound system?
I just bought a used 2003 Nissan 350z and was not impressed by the bose speaker system. After a while I realized that it did not sound so great because the rear speakers were not working. The subwoofer is working fine, but the is no sound from the rear speakers. I have a Pioneer DVD deck, any suggestions? Thanks.
Old Nov 14, 2009 | 06:12 PM
1GR8350Z's Avatar
1GR8350Z
Focal
Old Nov 14, 2009 | 06:30 PM
JEKL's Avatar
JEKL
Go to the Audio sub forum and search through old threads. You will see that a lot of people feel the rear speakers are worthless anyway. If the back ones are blown you might want to look into putting component ones in the doors and calling it a day.
Old Nov 14, 2009 | 06:33 PM
scrillasherv's Avatar
scrillasherv
Either they are blown, or there is a connection missing somewhere. A small wire may have popped out of the wiring harness. That's usually the case if there is absolutely no sound coming from the speaker.
Old Nov 14, 2009 | 07:15 PM
Welcome. Problem could either be the source (head unit) or the power amplifier.
Old Nov 15, 2009 | 10:55 AM
Spike100's Avatar
Spike100
If you have a Bose system and a non-Bose H/U, it’s likely that you have an adapter to allow the Pioneer H/U to work with the Bose components. The Bose setup sounds poor at best, and often sounds even worse when connected to a non-Bose H/U.
The rear speakers aren’t working because either they were connected incorrectly or not at all when the Pioneer H/U was installed. A possible explanation is the adapter connects 4 speakers total, or 2 speakers plus a SubW; or the installer simply decided not to connect the rear speakers (they are pretty bad).
You will need to pull the H/U to discover how the replacement is wired.
--Spike
EDIT: Even if you get the rear speakers working, you won't be impressed with the sound from an OEM Bose setup.
Last edited by Spike100; Nov 15, 2009 at 10:58 AM. Reason: To mention OEM Bose setup deficiency
Old Nov 15, 2009 | 01:31 PM
sdZ33's Avatar
sdZ33
Down with BOSE!
Up with HOES!
Old Nov 15, 2009 | 08:14 PM
xzotklr's Avatar
xzotklr
I currently have a 5.1 audio set-up. I can listen to MP3's, CD's & watch movies. I have the following:
Kenwood Excelon DNX8120 H/U (w/ Nav, bluetooth etc)
JL Audio 600/4 amp
JL Audio 500/1 amp
DynAudio 6.5" mid woofers & Panasonic 1.5" tweeters in the doors
DynAudio 6.5" mid woofers & tweeters behind the seats
3 JL Audio W3's in custom enclosure underneath rear strut brace
The sound is incredible!!!
Old Nov 15, 2009 | 08:22 PM
Goku350z2007's Avatar
Goku350z2007
where did you get the DynAudios from?
Old Nov 16, 2009 | 06:38 AM
xzotklr's Avatar
xzotklr
^^ Bought one pair from a fellow member and the second set from another private seller.
They are SQL quality speakers.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 29, 2015 03:58 PM
