Aftermarket components and Bose on 03 . . . Help!
on
So I have read almost every FAQ and walkthrough and have the speakers (kicker ks65 in the rear and kicker ks65.2 components up front). My struggle is how to get some wiring through the doors in the front. I tried the walkthrough of adding wires through the door jams and that just didn't happen. I know without Bose you can use the existing wiring however my touring is cursed with damn Bose so it's not as easy. Right now I have wires with no where to go!
Does anyone have a Bose wiring guide so I can try and tap into some existing wires? Or anyone have a st party's day truck up their sleeve that can help me to get this install done. . .
I have tried searching however to no avail.
HELP!?
HELP!?
HELP!?
HELP!?
https://my350z.com/forum/audio-and-v...any-ideas.html
on
Ok, Ty for the link however it doesn't answer my question. I'd like to use the existing wires for the Bose in the wiring and need to know which ones try are. Can anyone help with that? I do not want to drill new holes in the car or split into the molex I'm sure the smartest thing is to just use these already run and now not used wires.
Anyone?
Thanks again!
Anyone?
Thanks again!
on
Amazed no one could help with this.
Think I have what I need which makes sense will try tomorrow am!
http://kennydomain.co.uk/html/nissan...e_audio_4.html
Ty for all that helped guide
A lot of people have passed wire through the molex connector in the door without any problems. I don't know why it's such an issue with you. Did you even really (be honest) give it a try? All you need is a small screwdriver, a dremel with a cutting bit, some speaker wire and some silicone spray to make the wire slippery while passing it through the weatherguard tube. A pair of forceps make stringing the wire through the tube a sinch. The first door took me 20 minutes, the 2nd door took me 10. It's not rocket science.
on
Its not *that* easy. I did it too, but if you have big hands its going to be a major PITA. I can fully understand someone starting this project and then giving up on it. The Crutchfield link will allow you to tap into the factory wiring.
Unclip those zipties that attaches the wires to the body of the car and shove them out of the way. Rest is easy. I did run a 12awg wire through. A lot of empty space on the molex, there is less risk of getting to any of the wires.
Another tip, take a break when you seem to have a hard time. I used a soldering iron to start a smaller hole and then with dremel
