DIY Head Unit replacement?
Old Apr 15, 2014 | 04:08 PM
nerdhiker's Avatar
nerdhiker
Default DIY Head Unit replacement?
I just ordered a pioneer AVH-4000NEX to replace my current 6-CD Bose system in my 07 350ZR. I hear that this new Pioneer model is also going to support CarPlay soon. So, am all excited.
However, how do I do it? Are there any DIY guides to replace the stock Bose with an after marker Double Din System? Is it a hard one?
I tried to search the DIY threads, but could not find any...
Thanks!
Old Apr 15, 2014 | 04:36 PM
Spike100's Avatar
Spike100
Search the DIY threads (they are here); also search the threads hereabout installing a H/U.
Old Apr 15, 2014 | 07:00 PM
BY350z's Avatar
BY350z
Old Apr 17, 2014 | 12:45 PM
nerdhiker's Avatar
nerdhiker
Thanks! Do I need to buy anything in addition to the new Pioneer receiver? Like cables etc? Would it just fit flush in place of the existing bose system? I have steering wheel controls today - would these work just fine with the new Pioneer system too? And do I need to make a hole somewhere to have the female USB port ?
Old Apr 17, 2014 | 07:38 PM
johnx818's Avatar
johnx818
You will need:
a dash kit from Scosche, Metra, search?
since you have Bose, you need an interface module, Pac-audio makes one and I'm sure others do, too
you'll need a steering wheel control module as well to retain your steering wheel controls, also made by Pac-audio and other companies
you can make a hole for your female USB if you want to be fancy. I have mine ran into the cubby with about 6 inches of slack.
Old Apr 17, 2014 | 09:55 PM
nerdhiker's Avatar
nerdhiker
Thanks John! I was hoping it would be a straight up swap.. Now, am leaning to get this done from some AV guy..
Old Apr 18, 2014 | 08:46 AM
DarkCreep's Avatar
DarkCreep
Do it yourself. The hardest part is removing the "water fall" and even then thats easy just tedious.
I have my auxiliary coming out the eBrake and tucked by it. I have my female USB under the coin holder in the center. I have bluetooth so I never use those anyways, but theyre there.
What module are you guys talking about? I replaced my Bose with a Kenwood double DIN and used a Metra harness. The Bose works perfect and sub still thumps.
Old Apr 18, 2014 | 09:03 AM
nerdhiker's Avatar
nerdhiker
What do you mean by waterfall? Mine is a 07 Z. Hope the Metra harness works.
Old Apr 18, 2014 | 09:46 AM
05CaliZ's Avatar
05CaliZ
the center console where that houses everything from the three gauges up top all the way down to the AC controls
May 30, 2017 03:28 PM
350z82
Oct 1, 2015 06:25 PM
