LCD in 04 cubby
Old Sep 27, 2004 | 12:23 AM
eon's Avatar
eon
Question LCD in 04 cubby
has anyone been able to fit a lcd in a 04 cubby hole i have already searched but can only find lcd's fitted into the 03 models if so do u have any pics and what size did u fit and did it take a lot of modification, if not then how much does it cost to buy the whole 03 cubby hole
Old Sep 27, 2004 | 02:21 AM
stu46's Avatar
stu46
although my dash is quit modified, most 7" lcds will fit with very little mod. i test fit a clarion 7" and it fit just about perfect.
Old Sep 28, 2004 | 05:47 AM
pablosbrain's Avatar
pablosbrain
I purchased an 03 nav cubby and installed it into my 04 350z. Worked great... install was fairly simple.
Old Sep 28, 2004 | 07:37 AM
BPL's Avatar
BPL
I have a 7" Lilliput touchscreen mounted in a '04 with motorized lid. I was unable to get the OEM controller for the motorized lid working so we had to make a custom circuit. This pic shows the screen mounted (protective film still on the screen). There is a small gap below the screen where the nav controls would normally go so we made a plastic piece to cover it.
Old Sep 28, 2004 | 07:40 AM
BPL's Avatar
BPL
Here is a pic of the controller for the door. It uses a Basic Stamp 2 microcontroller.
Old Sep 28, 2004 | 02:41 PM
desiZ's Avatar
desiZ
how much did the motorized version of the door including the control circuit run you ?
looks good
Old Sep 29, 2004 | 06:01 AM
BPL's Avatar
BPL
The motorized lid was about $120 I think. The controller was around $80 but I wasn't able to get it to work. There was a wire in the circuit diagram that connects to the nav system which is why I think I had problems. The only parts I used from the OEM controller were the plastic case and ribbon cable that connects to the door. The circuit in the picture above is home made.
Old Oct 5, 2004 | 05:28 AM
SvR350z's Avatar
SvR350z
Bpl,
What head unit is that?
Does it play Satelite radio?
It looks sweet!
Old Oct 5, 2004 | 07:11 AM
leemik's Avatar
leemik
Default Re: LCD in 04 cubby
read this entire thread
https://my350z.com/forum/showthread....threadid=48290
should prolly be a sticky since this question gets asked every week
--mike
Old Oct 5, 2004 | 07:15 AM
leemik's Avatar
leemik
Originally posted by SvR350z
Bpl,
It looks sweet!
that is a sony WX7700MDX.. It's a JDM radio and not available in the US and it doesn't support satellite radio but it has an aux input
http://www.melting-pot.com/website/p...WX7700MDX.html
--mike
Old Oct 5, 2004 | 08:46 AM
SvR350z's Avatar
SvR350z
what good does the aux port do ?
im newblar at radio
Old Oct 5, 2004 | 10:25 AM
leemik's Avatar
leemik
Allows you to connect an external source to the radio.. like for instance an xbox, iPod or one of those non-integrated into the head unit XM radio receivers
--mike
Old Oct 5, 2004 | 05:10 PM
SvR350z's Avatar
SvR350z
By non-integrated into the head unit XM radio receivers
You mean plug and play deal?
Is that what you mean?
Old Oct 5, 2004 | 06:56 PM
suse's Avatar
suse
So does the motorized door work?? How hard is to make that special circut??
Old Oct 8, 2004 | 07:19 PM
BPL's Avatar
BPL
Yep, the door is fully functional and I've been using it for the past couple weeks with no problems. It's attached to battery and acc power so when the car is turned off it will close automaticly. When the car is turned on it will either open every time or it will open only if it was open when the car was turned off depending on a jumper setting. It is also connected to the power input to the LCD and will turn it on and off depending on the position of the door. The circuit took my friend and I a while to design because we're new at this stuff but I would imagine it would be pretty easy for an experienced person. I have a few extra PCBs if anyone would be interested in buying either a blank PCB or a completed circuit. Let me know.
-Bryan
Old Oct 8, 2004 | 07:23 PM
BPL's Avatar
BPL
--mike
Actually, the WX7700MDX is satelite radio ready. There is a Sony XM receiver that attaches to it using unilink which allows you to control it from the head unit. Ive heard it can be hard to find them though...
Old Oct 9, 2004 | 07:37 AM
aalzuhair's Avatar
aalzuhair
-Bryan
I'm interested in buying the same setup with the plastic part that you made
Az
Old Oct 9, 2004 | 08:26 AM
BPL's Avatar
BPL
aalzuhair,
Unfortunately, I can only supply the PCB with or without components installed. The plastic mounting bracket and the ribbon cable that connects to the door came with the OEM controller circuit which was about 80$ from the dealer. I think the problem I had was the OEM controller had one line that connects to the Nissan nav system which I obviously don't have. You would either need to get ahold of the mounting bracket somehow or figure out some other way to mount it. Sorry.
-Bryan
Old Oct 12, 2004 | 12:01 PM
zzzBaby's Avatar
zzzBaby
-Bryan
Bryan,
I PM'd you on the purchase of one of your completed ciruit boards. Let me know if you've got a Paypal account or how you like to set up the transaction.
Thanks - Corey (zzzBaby)
gamejt
Apr 16, 2003 12:30 PM
KJ-350
Mar 17, 2003 03:11 PM
christurismohk
Audio Builds
Mar 13, 2003 07:33 AM
KJ-350
Mar 8, 2003 03:30 PM
del105
Mar 2, 2003 05:28 PM
