Loss of Power Assist
Old Sep 25, 2005 | 06:04 AM
Dan03Sedan's Avatar
Dan03Sedan
Default Loss of Power Assist
I've been autocrossing my 03 G35 sedan this summer and for the first time have run into a problem. After installing Hotchkiss adjustable sway bars and finally getting them adjusted right.(the car handled like a dream, no understeer and oversteer on demand via the throttle) The problem is that when going through a slalom I encountered a loss of power assist only during the most violent steering inputs. I also am running 245-40 Azenis st115 tires on 18 inch rims. I have replaced the P/S belt but it doesn't appear worn--not shiny or cracked. Fluid level seems OK too. Any ideas??
Old Sep 25, 2005 | 07:01 AM
PDX_Racer's Avatar
PDX_Racer
Overdriving the power steering.
It can happen somtimes... :shrug:
Old Sep 25, 2005 | 07:23 AM
Kolia's Avatar
Kolia
Do you have the cooler installed ?
You might want to change the fluid from time to time.
Old Sep 25, 2005 | 07:32 AM
plumpzz's Avatar
plumpzz
Yeah you might just have over heated fluid or heat soaking on ur steering
Old Sep 25, 2005 | 07:34 AM
Dan03Sedan's Avatar
Dan03Sedan
Even in the first 15 seconds of the run?
Old Sep 25, 2005 | 08:04 AM
PDX_Racer's Avatar
PDX_Racer
It's not overheating, you're just overdriving the boost. You're ahead of the pump, and either need to "deal with it" (ie. just live with it until the next straight) or slow down and let the pump catch up.
It happens to a lot of cars at autocrosses. The pumps are built big enough to handle regular driving, and autocross requires more movement in less time than they were designed for, so the pump gets behind.
Old Sep 25, 2005 | 08:06 AM
Dan03Sedan's Avatar
Dan03Sedan
Thanx for your input-- guess I'll have to work on my driving more.
Old Sep 25, 2005 | 08:07 AM
PDX_Racer's Avatar
PDX_Racer
Smoother inputs can help.
apex locator
Jul 23, 2021 02:27 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
