Lap times DB and track Videos
Old May 12, 2010 | 02:42 PM
  #201
scotts300's Avatar
scotts300
This is/was my source for the overall record......http://www.gmperformancedivision.com...ords_scca.aspx
Pretty drastic difference b/w the 350z and actual track record in t2.
It looks like Thunderhill keeps their own records as well, and this was updated May 09': http://www.thunderhill.com/CurrentTh...ecords3_09.pdf
T2 in an 03' Nissan 2:03.912, and it looks like that guy is really friggin' good. I'd like him to instruct for me! http://www.touringcarnews.com/index....ing&Itemid=111
It looks like he traded up to a sponsored 2005 Z also: http://sccaforums.com/forums/thread/215207.aspx
Old May 12, 2010 | 03:21 PM
  #202
03threefiftyz's Avatar
03threefiftyz
2:03's is moving when you consider t2 350z weight and power level.
Old May 13, 2010 | 08:10 AM
  #203
scotts300's Avatar
scotts300
True!
First vid is up: http://www.youtube.com/watch?v=xc9gQy5KI0w
Old May 17, 2010 | 11:31 AM
  #204
scotts300's Avatar
scotts300
2nd vid is up (see post 195) (updated)
Old Jun 26, 2010 | 03:22 AM
  #205
mhoward1's Avatar
mhoward1
Track : Carolina Motorsports Park CMP)
Date: June 20th, 2010
Best Lap time: 1:47:70
Car: FFRC
Tires: Toyo RA1's 255/45/17
brakes: Carbotech XP12
Other Modifications: none
Lap Notes (Rain, heat, etc): Hot, 100+ degrees. The track was also a little slick. I think if it was cooler I could have gotten the car into the 1:46 range.
Fast lap is lap 7:
http://www.youtube.com/watch?v=gb6btarxASs
Old Jun 27, 2010 | 09:35 AM
  #206
Ataru074's Avatar
Ataru074
Texas world speedway CCW
6/26/2010
2.02.2 I shaved 1.1 second from last time
Notes, 100 degrees, the brakes needs COOLING.. they started vibrating and the pads overcooked ( ferodo ds3000 / brembo)
I'm using nitto NT01 (brand new) hot pressures 38F 38R... need to lower the rear because the car is over-rotating.. wasn't inspiring me any confidence to push harder.. the front have more grip for sure.
oil temperature up in the 240 and water in the 220 in 2 laps... the loss of power is significant (top speed about 5mph less than spring/winter).
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/PzGAGU1OdpU&hl=en_US&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/PzGAGU1OdpU&hl=en_US&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Old Jun 27, 2010 | 01:10 PM
  #207
roger22's Avatar
roger22
Probably add 2psi to the rear if the car is oversteering not drop psi
Old Jun 29, 2010 | 04:23 AM
  #208
Lightning Guy's Avatar
Lightning Guy
Date: June 19th, 2010
Best Lap time: 1:50:82
Car: 03 350z
Tires: NT01s 275/40/17 (50+ heat cycles)
brakes: Carbotech XP10
Temp +100F
Other Modifications: massive weight reduction, HKS coilovers, APR wing, Hotchkis sways, 257 WHP.
Best Lap time: 1:52:3
Car: 03 350z
Tires: General Aclaim UDH 380 compound 285/35/18 295/35/18 (NT01s were so done the street tires were safer)
Temp +100F
Old Jun 29, 2010 | 06:33 AM
  #209
Z3305's Avatar
Z3305
Track : Putnam Park Road Course
Date : July 30, 2008
Best Lap time : 1:24.3
Car : 2005 350Z Enthusiast
Tires : Dunlop Direzza Star Specs (shaved) 255/40R17 on 8" OEM wheels all around
Brakes : Stock Rotors with Hawk HP+ pads
Other Modifications : Eibach Pro Kit springs with Koni yellows, SPL Front upper A-arms -2.8deg., Stillen intake, Stillen headers, Berk Hi-Flow cats.
Lap Notes: Northeast Corvair Club timed event, 83F during session with best time, TCS always off
Date : May 09, 2010
Best Lap time : 1:22.1 (19 of 38 laps in 1:22s)
Tires : Nitto NT-01 255/40R17 on 8" OEM wheels all around
Brakes : DBA Rotors with Hawk DTC-60 pads
Other Modifications : Eibach Pro Kit springs with Koni yellows, SPL Front upper A-arms -2.8deg., Stillen intake, Stillen headers, Berk Hi-Flow cats, reflash.
Lap Notes: 10/10th Motorsports event, 50-56F during event, TCS always off
Track : MidOhio (Club Course incl the "Bus Stop")
Date : May 24, 2010
Best Lap time : 1:46.7
Lap Notes: Three ***** Racing event, 79F during session with best time, Longacre "Hot Lap" timer, TCS always off. Discovered the DBA rear rotors BOTH cracked once I got home. Back to stock rotors for next event.
Old Jun 30, 2010 | 04:45 PM
  #210
Lightning Guy
just sent the V3 bumper to paint, lets see if it works
Old Jun 30, 2010 | 04:50 PM
  #211
mhoward1's Avatar
mhoward1
BTW, have some great pics for you from Roy.
Old Jun 30, 2010 | 05:01 PM
  #212
Lightning Guy
Roy DLed his camera to me before he left. I haz the same shots you do
Finally got a new camera so hopefully I can start uploading video of one of the lightest 350Zs out there. I got Danny smith to drive my Z last event, our cars are similar weighted and gripped. He showed me a fewmore things that I didn;t know. There is 1/2 second at CMP in turn 4 if one has the testicular fortitude for it I thinkz I do, I did same line on the generals (Jokes) and went into 5 at the proper angle for the braking zone (after some exit drama).
You coming to ZCON? u better
Old Jun 30, 2010 | 05:17 PM
  #213
mhoward1's Avatar
mhoward1
you and I need to talk about that because Danny is eating me alive.
Still up in the air about ZCON.
Old Jun 30, 2010 | 05:20 PM
  #214
Lightning Guy
Enter turn 4 around brake marker between 1.5 and 1 and let it drift to the braking zone at the entry to 5.
just paint the cobra green and call it the snot rocket
Old Jun 30, 2010 | 05:22 PM
  #215
Lightning Guy
besides taking it early take it shallow, use the rumble strips to "turn" the car. going throught there at 1/2 mast on power will "rotate" the car due to the difference in friction. First time he did it I was oh kewl, first time I did I was oh Krap, LOL.
Old Jul 1, 2010 | 04:54 AM
  #216
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
Lightning guy do you have any in car videos of any sessions?
Old Jul 1, 2010 | 05:10 AM
  #217
Lightning Guy
I have video somewhere from last year, RRR, VIR north, TGPR, CMP, and VIR south. I'll see if I can dig them up. My Samsung died last september and I just got a Gopro, so hopefully I'll have new videos soon.
Old Jul 3, 2010 | 04:42 AM
  #218
Lightning Guy
OK tried to keep them small for bandwidth sake
CMP last year, buddy of mine getting a taste of the track, Was having power steering issues. NT01s square 275/40/17, temp was hot 90+
TGPR last September, Z NAtionals, I decided to go harrass the GTR run group. NT01s square 275/40/17 ~80F
Mid-Ohio two years ago ZCON, someone from Nissan riding shotgun, kind of coold that day, Khumo MX 275/295
RRR last May, PCA or Darkside event, solo run group and still only two passing zones. A few notes. The silver 350Z I'm flipping off is Morris and its an HR, for the first time he didn't leave me in the straights (3.91:1 gear paid off), the Yellow C5 Z06 and Black Cobra are friends. Justin was my student that weekend and was riding shotgun. May not be my fastest laps of the weekend but was the most fun session. Hoosier Konis 275/40/17 square, HAWT!
Old Aug 18, 2010 | 01:02 PM
  #219
scotts300's Avatar
scotts300
Track: Buttonwillow Raceway http://www.buttonwillowraceway.com/
Date: 7/30/2010
Best Lap time: 2:09.39 (configuration 13B)
Car: 2003 Performance 350Z coupe
Tires: Hoosier R6, 285/30/18 295/30/18
Brakes: Stoptech 332mm front kit with PF97, Brembo rear with PF97
Other Modifications: TCKline DA shocks, NISMO LSD, Hotchkis sways, Intake, Plenum Spacer, Pulleys, Shockwave Exhaust, ART pipe
Lap Notes (Rain, heat, etc): Dry and HOT
http://www.youtube.com/watch?v=W42JqA3J5xQ
Old Sep 7, 2010 | 09:53 AM
  #220
scotts300's Avatar
scotts300
It's official: My NA 350Z is now faster at all the tracks that I've driven both the 300ZXTT and the 350Z:
Originally Posted by scotts300
Track: Laguna Seca, Monterey, CA
Date: 2 October 2007 with speedventures.com
Best Lap time: 1:47.4 (avg speed ~80mph)
Car: 300ZX TT, 16psi (~450rwhp)
Tires: Hoosier R3S05
brakes: Stoptech front, stock rear
Other Modifications: Oil cooler, etc.
Date: 6 September 2010 with NCRC
Best Lap time: 1:46.13
Tires: Kumho V710, 305/30/18 x 4
Other Modifications: TCKline DA shocks, NISMO LSD, Hotchkis sways, Intake, Plenum Spacer, Pulleys, Shockwave Exhaust, ART pipes
http://gotbluemilk.com/web100906/219...s/image13.html
Pics and vid to come.
