Lap times DB and track Videos
Old Oct 3, 2011 | 06:55 PM
  #301
Lightning Guy's Avatar
Lightning Guy
well I finally got video from VIR full course, it has been my unicorn to vdeo f this track. this is not my fastest but I have video.
september 10, 2011
mid 70s, dry, perfect weather
YokoHama AO48s, 285-295/30 18
same mods as ^
personal best 2:14.7 this session ~2:16-17
some poor diving early in the video, but I pulled my head out of my butt in the first few minutes.
http://www.youtube.com/watch?v=JFG1bQ62wEA
Old Oct 3, 2011 | 07:32 PM
  #302
SE5spd's Avatar
SE5spd
september 10, 2011
same mods as ^
how much power does your car make and how much does it weigh!? never seen such a gutted Z lol
BTW, what are those 3 gauges for?
Old Oct 4, 2011 | 02:35 AM
  #303
Lightning Guy
~265 whp
~2750 # + me
oil pressure, oil temp, wide band
Old Oct 4, 2011 | 10:30 AM
  #304
mhoward1's Avatar
mhoward1
Think you guys will like this one.
2:03:06 at Watkins Glen during tire testing.
http://www.vimeo.com/29955907
Old Oct 4, 2011 | 11:53 AM
  #305
SE5spd's Avatar
SE5spd
~265 whp
~2750 # + me
nice!
must be a long straight, unless I saw wrong it looked like 140+mph on that straight?
Old Oct 4, 2011 | 01:29 PM
  #306
Lightning Guy
nice!
it is a LONG straight, but my tires are a bit shorter than stock too, 295/30/18 verses 245/45/18
Stock Tire - 245/45R18
Search Tires Tire 1 - 295/30R18
Width: 9.64 in 245 mm
Section Width: 11.61 in 295 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 7.5 - 9 in
Rim Width Range: 10.5 - 11.5 in
Overall Diameter: 26.68 in 677.67 mm
Overall Diameter: 24.96 in 633.98 mm
Sidewall Height: 4.34 in 110.23 mm
Sidewall Height: 3.48 in 88.392 mm
Radius: 13.34 in 338.83 mm
Radius: 12.48 in 316.99 mm
Circumference: 83.81 in 2128.7 mm
Circumference: 78.41 in 1991.6 mm
Revs per Mile: 779.6
Revs per Mile: 833.3
Actual Speed: 60 mph 100 km/h
Speedometer1: 64.1 mph 106. km/h
Speedometer Difference: -
Speedometer Difference: 6.888% too fast
Diameter Difference: -
Diameter Difference: 6.45%
That and a 3.91:1 Final drive means I shift_ALOT
Old Oct 4, 2011 | 01:55 PM
  #307
SE5spd's Avatar
SE5spd
yeah when you hit 6th and stayed on the throttle I figured you have really short gears.
Old Oct 4, 2011 | 03:43 PM
  #308
Lightning Guy
yeah anyone with a 370Z that would like to trade ring and pinion I'd be tickled pink. The 3.74:1 would be a nice trade for my 3.91:1
I might call Mike
Old Oct 4, 2011 | 03:47 PM
  #309
SE5spd's Avatar
SE5spd
I might call Mike
just get 4.08s
Old Oct 4, 2011 | 04:30 PM
  #310
Lightning Guy
just get 4.08s
I'm already shifting enough, that would make the gears even shorter, going with the 3.74 would make the effective gear ratio closer to 3.99:1 verses the effective 4.18:1 running the 3.91:1 if my math is right. All of this due to the shorter tires, back when I ran the 295/35 tires the 3.91:1 was effectively a 4.09:1 and that was nice, but I'm digging the Yokohamas for what I do.
245/45/18 circumference = 83.81"
295/35/18 circumference = 82.05"
295/30/18 circumference = 78.41"
245/45/18 gear multiplier = 83.81/83.81 = 1.00
295/35/18 gear multiplier = 83.81/82.05 = 1.02
295/30/18 gear multiplier = 83.81/78.41 = 1.07
therefore
245/45/18 | 3.52*1.00 = 3.52:1 | 3.74*1.00 = 3.74:1 | 3.91*1.00 = 3.91:1 | 4.08*1.00 = 4.08:1
295/35/18 | 3.52*1.02 = 3.60:1 | 3.74*1.02 = 3.82:1 | 3.91*1.02 = 3.99:1 | 4.08*1.02 = 4.17:1
295/30/18 | 3.52*1.07 = 3.76:1 | 3.74*1.07 = 4.00:1 | 3.91*1.07 = 4.18:1 | 4.08*1.07 = 4.36:1
And now that I have such a tall gear, I can't find a 35 series R comp, i was awesome with Street tires, and I was pretty dayum quick with street tires, now I'm like a nissan ad shift_alot, LOL
edited: a small math error fixed
Old Oct 13, 2011 | 12:33 PM
  #311
Fixxxercask's Avatar
Fixxxercask
Track: Road America Elkhart Lake Wisconsin
Date: 10-9-11
Best Lap time: 2:34.5
Car: 2004 Nissan 350Z Base
Tires: Hoosier A6; 255/35/18 (massive for 255's )
Brakes: OEM Brembos; Carbotech XP-12's in front; XP-10's in rear
Other Modifications: Zeal Function X Coilovers, Quaiffe LSD, Hotchkis Sways with SPL spherical endlinks, Motordyne 5/16" plenum spacer, Kinetix HFC's, Motordyne 3in single exhaust, Black Enkei RPF-1's, Braille 15lb battery, Oil cooler, APR GTC-300 Wing, Homemade wood front splitter and aluminum air dam, Cusco front A-arms, SPC rear camber arms and weighed 3210lbs with me in it and about 1/2 tank of fuel.
Lap Notes (Rain, heat, etc): Mid 70's and Sunny!
Sunday fun day with NASA TT. Competition was over on Saturday. My best time was a 2:34.5. The noise you hear under braking is my massively warped rotors. My lap timer for some reason has the start finish a little ways past the start finish, but it is spot on with the times. They match the transponder times. For some reason the lateral G's seem backwards too. Watch the meter during the carosel on the last couple laps. It gets way over there. Weather was beautiful and the scenery was amazing. All the trees were changing colors.
http://www.youtube.com/watch?v=12lniVxdm2U
Old Oct 20, 2011 | 07:08 AM
  #312
2TH PWR's Avatar
2TH PWR
I just found this funny. I got stuck behind a guy who refused to wave me by.
http://www.youtube.com/watch?v=__1K2wX1YLs
Old Oct 20, 2011 | 10:35 AM
  #313
Fixxxercask
Man, I do not miss HPDE at all. I used to hate that. I know you were being safe which was good, but I when that used to happen to me I would get closer and closer to let them know they need to get out of the way. Even if that guy thought you were slower in the corners, he should have let you by on the straights. He should know your is much faster in a straight line. Hopefully you had some better sessions later that day.
Old Oct 20, 2011 | 01:39 PM
  #314
2TH PWR's Avatar
2TH PWR
Yeah, like I said in the videos, I was about 23-24 seconds faster per lap. But had some sweet chases with a SUbaru Sti and Cayman R later in the day.
http://www.youtube.com/watch?v=cq03-mJFO6U
Track: Toronto Motorsports Park Cayuga
Date: 9-17-11
Best Lap time: 1:26.64
Car: 2003 Nissan 350Z Performance
Tires: Hankook RS3; 265/35/18
Brakes: OEM Non-Brembos; HP+ pads
Other Modifications: Enkei RPF1, Eibach prokit, SPC rear camber arms HKS exhaust, 5/16 plenum spacer, Osiris tune
Old Oct 20, 2011 | 04:05 PM
  #315
GT-Rob's Avatar
GT-Rob
Open lapping at TMP, what do you expect. I give them once chance to let me by and then I just take it.
Lightning: How are those mirrors attached? Are those the APR ones?
Old Oct 31, 2011 | 09:55 AM
  #316
2TH PWR's Avatar
2TH PWR
Date: 10-30-11
Best Lap time: 1:24.72 also had a 1:24.90 from start/ stop line.
Car: 2003 Nissan o350Z Performance
Brakes: OEM Non-Brembos; Stop Tech Street performanace pads
Track notes. Fairly cool. 7 celcius. which is 44 F. Left front caliper was seizing and melted the rotor and shredded the pad. Ran off the back of the second straightaway with brake failure a couple laps after this.
http://www.youtube.com/watch?v=fV2yUWRWhAo
Old Nov 18, 2011 | 07:50 AM
  #317
Rafatpanah212's Avatar
Rafatpanah212
Default 3rd Track day at Lime Rock Park
Track: Lime Rock Park (LRP) - Full course no chicane
Date: 11/14/11
Best Lap time: 1:05.16
Car: '07 350z Nismo
Tires: Bridgestone Potenza RE-11s (245/40R18 - 265/35R19)
Brakes: Stock Brembos
Other Modifications: None
Lap Notes (Rain, heat, etc): ~50 F partially cloudly
Used a bluetooth OBD-II reader, bluetooth GPS receiver and my phone to gather/save data and put it together with RaceRender2. Datalogging on a budget :-).
Video Link
Old Nov 21, 2011 | 07:54 AM
  #318
scotts300's Avatar
scotts300
Track: Sears Point (Infineon Raceway), Sonoma, CA
Date: 19 November 2011
Best Lap time: 1:54.3
Car: 2003 Performance 350Z coupe
Tires: 285 x 4 Hoosier A6
Brakes: Stoptech 332mm front kit with Raybestos ST47, Brembo rear with Raybestos ST45
Other Modifications: TCKline DA shocks, NISMO LSD, Hotchkis sways, Intake, Plenum Spacer, Pulleys, Shockwave Exhaust, ART pipes, APR GTC300 wing
Lap Notes (Rain, heat, etc): Dry and cool
Vid:
http://youtu.be/Ea5kZBpa33U
Old Nov 30, 2011 | 12:32 PM
  #319
scotts300's Avatar
scotts300
Update:
Track: Buttonwillow Raceway Configuration 13CW, Bakersfield, CA
Date: 25 November 2011 with Bob's Donuts
Best Lap time: 2:01.18
Tires: Hankook RS3, 285/35/18 x 4 on Enkei RPF1
Lap Notes (Rain, heat, etc): Dry, cool
Vid: http://youtu.be/_H15bIsS0Jg
Date: 3 April 2011 with NCRC
Best Lap time: 2:07.58
Tires: Hoosier A6, 285/30/18 x 4
Brakes: Stoptech 332mm front kit with PF97, Brembo rear with PF97
Old Nov 30, 2011 | 01:46 PM
  #320
Fixxxercask
That's an awesome pic.
I am still wanting to post vids on here from Nats. I recently realized that I will not have data for my fastest lap session.
