U haul hitch for the Z?
Old May 28, 2008 | 11:10 AM
  #101
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by first350
I installed a custom made hitch - when we did the install, Drivesolo welded the seams on the Aluminum Bumper brackets...so far, it's held up. (My tongue weight is 50 lbs when the trailer is fully loaded)
Originally Posted by dnguyent
Guys,
I installed the Curt hitch on my 2004 Z over the weekend. I purchased it through Summit Racing, and they sent me the correct unit.
The intent was to haul my road or mountain bikes, not to trailer my set of track wheels and tools. I also bought a nice Yakima hitch mount bike rack. After doing a complete and thorough install (~4 hours), I did a test drive with my 16lb road bike. I noticed that there was still a whole lot of flex in the aluminum bumper. The Yakima rack weighs 32 lbs, so I was carrying just under 50lbs and the hitch was bouncing all over the place. I parked the car, and pulled down on the hitch, and it flexed a lot. I don't think this design is good at all. The hitch may be rated for class A, but the bumper will surely fatigue without doing some torsional strengthening. If my hitch can't carry bike rack and a 16lb bike, I don't see how you guys are going to haul 400+ lbs of tires, tool, and trailer. That bumper will eventually fatigue and tear off!
ya, good point FIRST350. Tongue weight is a big thing.....its good to evenly spread out your load on your trailer so that the trailer is carring all the load and not the tongue of your trailer --- ie hitch and bumper beam...
The reason "dnguyent" was feeling the unstable bumper beam was because from the get go he had 50lbs of load on the tongue with no wheels in the "trailer" to pass load... He introduced a MOMENT into the system (system being bumper beam and brackets)
Not a good idea to use with bike hitch mounts - better to buy the trunk mounting -type of bike rack with the nylon straps that attach to the corners of the hatch - LIKE THE ONE PICTURED IN THE ATTACHED PIC BELOW. mind you i couldnt find a pic of a Z - audi will have to do..
- J
Old May 30, 2008 | 06:01 AM
  #102
JasonZ-YA's Avatar
JasonZ-YA
Default Hoppy Converter
Here is one picture of a hoppy converter used on our cars. like i mentioned before the brain (inner workings) of the POWERED hoppy converter is all the same. This one in particular has no wired end...the 4wire connection to the trailer is molded right into the brain.
To me this is not exactly ideal because that means i have to find a mount for this big bulky thing really down low to the bumper.
Would rather have an adapter 4-wire flat added to it or one that has some length of wire already on the unit so i can connect the trailer.
- Jason
Old May 30, 2008 | 07:03 AM
  #103
DriveI65's Avatar
DriveI65
Check NAPA. The shop I used got one from there that has an separate pigtail and they mounted the box on the sheetmetal behind the bumper cover. The car side connection also has a cover for when it is not used.
Old May 30, 2008 | 09:25 AM
  #104
JasonZ-YA's Avatar
JasonZ-YA
sweet.....ill next time i stop at NAPA ill check that one out that way i can post the p/n for those that need it.....
- j
Old May 30, 2008 | 10:28 AM
  #105
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Just a FYI, I would hook it up and have it mounted in the trunk near the spare tire area. And when you need it, you pull the cable out and connect it and let it hang from the hatch. So then you don't have this ugly cable hanging down below, and it isn't exposed to the elements. I did this on my G35 when I pulled my Jetski with it.
Old May 30, 2008 | 10:31 AM
  #106
JasonZ-YA's Avatar
JasonZ-YA
ha...sweet....post pics of your car pulling the jet ski..
- j
Old May 30, 2008 | 10:44 AM
  #107
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Well I will have to find the ones for my G, but here is my Jetski behind my 03 Audi A4. Look at the gas prices then.....03-04 timeframe. Haha geez.
Old May 30, 2008 | 10:47 AM
  #108
JasonZ-YA's Avatar
JasonZ-YA
sweet....good lord what i would do for those gas prices again.........this is so retarted.......
- j
Old Jun 5, 2008 | 05:13 AM
  #109
JasonZ-YA's Avatar
JasonZ-YA
Default Wiring Install
UPDATE:
TRAILER WIRING HARNESS:
ANY HOPPY BRAND - (AUTOZONE, ETC) WILL WORK - SO LONG AS IT IS FOR A CAR THAT HAS A SEPARATE** BLINKER AND BRAKE LIGHT LIKE THE Z DOES. GET IT?? THE DIFFERENCE IN HOPPY BRANDS IS ONLY DUE TO THE CONFIGURATION OF THE END (END WHERE TRAILER WIRES CONNECT - I BOUGHT A SEPARATE END AND ATTACHED ONE WITH TESTING LEDS ON IT).
I used a wiring light tester and verified all my colored wires did the exact function i was looking for.
I labeled in the attached pics the wiring colors for my 04 Touring Z but i dont know if the colored wires are the same for all Z's so i recommend buying a simple wire tester and double checking.
I dont have any pictures but i hot soldered all my connections and then used the ghetto electrical tape.
ALSO: FORGOT to mention, for the (WHITE) ground wire i just sanded a small area on the back trunk "firewall" if you know what i mean, and then used a short, small self tapping sheet metal screw. I positioned it low so i could see it by crawling under the car just to double check it every once in a while. just my 2 cents.
- J
Attached Thumbnails U haul hitch for the Z?-wiring1.jpg   U haul hitch for the Z?-wiringblinker2.jpg   U haul hitch for the Z?-wiring3.jpg   U haul hitch for the Z?-wiring4.jpg   U haul hitch for the Z?-blinker1.jpg
Old Jun 5, 2008 | 05:44 AM
  #110
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Just a FYI. Make sure you have a self-powered unit for these cars, not one that pulls its power from the tails. You need a self-powered unit that runs a power line from the battery back. The ECU on my G35 was freaking out when the blinker would run and cause the engine to lose power everytime the blinker blinked. It was crazy. We resolved it with a self-powered unit from U-Haul.
Originally Posted by JasonZ-YA
UPDATE:
- J
Old Jun 5, 2008 | 07:55 AM
  #111
Axelerate's Avatar
Axelerate
Mine pulls power from the back lights, you just have to swap out to LED lights on the trailer.
They pull less power and work great.
Old Jun 6, 2008 | 05:20 AM
  #112
JasonZ-YA's Avatar
JasonZ-YA
WHAT BRAND UNIT did you use at first???
Because my HOPPY brand unit works great. SO did a few others that ive talked to that have used Hoppy brand units.
I talked with Hoppy and they assured me it would work fine. their units are protected/wired so not to draw a ton of voltage.
so far that ive used mine its worked great.
- J
Old Jun 6, 2008 | 05:21 AM
  #113
JasonZ-YA's Avatar
JasonZ-YA
Also,
What brand is yours???
- J
Old Jun 6, 2008 | 01:17 PM
  #114
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
- J
Both the units were Uhaul brand. I don't know the models. I had a shop install it, and the one that runs off the tails caused problems and had to switch to the one that powers itself from the battery.
Old Jun 6, 2008 | 03:23 PM
  #115
DmanG281's Avatar
DmanG281
on the hitch Roark designed he just put a resistor inline to correct the current draw
Old Jun 6, 2008 | 03:32 PM
  #116
JasonZ-YA's Avatar
JasonZ-YA
hum...well, ill post my HOPPY brand p/n for everyone.
so far no problems, works great.
- j
Old Jun 6, 2008 | 05:02 PM
  #117
Axelerate's Avatar
Axelerate
Also,
- J
I have no idea, it came with my Roark hitch as well.
Old Jun 9, 2008 | 10:32 AM
  #118
JasonZ-YA's Avatar
JasonZ-YA
bummer...
well, at least we know the HOPPY brand works, i tried it again and no issues so far. everything works great.
UPDATE OF PICS:
- J
Attached Thumbnails U haul hitch for the Z?-img_4496.jpg   U haul hitch for the Z?-img_4495.jpg   U haul hitch for the Z?-img_4497-1.jpg
Wags
Apr 24, 2025 07:37 PM
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
C Ray Z
Northern California
Mar 4, 2004 08:29 PM
Vlad
Sep 27, 2003 09:27 AM
