The Tire DB - Posts about Track and AutoX tire brands
Old Mar 25, 2009 | 06:54 AM
  #881
betamotorsports's Avatar
betamotorsports
Well... as always, it depends. The advantages you list above are true for shorter sidewall tires but they are not as great as many people make them out to be. And there are advantages for taller sidewall tires.
Tire OD affects gearing and, depending on what you're doing (road racing in this context) sometimes shorter gearing will put the car in a bad spot (engine rpm) for acceleration out of an important corner. Taller sidewalls are also more forgiving under hard braking and give a broader slip angle curve in the corners making it easier to drive at the limit. A higher horsepower RWD car will put power down better with taller rear tire sidewalls.
Old Mar 25, 2009 | 08:26 AM
  #882
s2k2nismo's Avatar
s2k2nismo
cornering was my main concern with the shorter sidewall. i was always under the impression that a taller tire (more sidewall ) would maybe flex/give more when cornering. i was thinking a stiff sidewall and short sidewall would be more prone to slide out from under you. but i see alot of the newer cars today like the (R8) use a smaller sidewall 235/30/19 and 305/30/19. so i am probably wrong in this thinking either way, i am sure the R888 are a much better improvement over the michelin PS2
Old Mar 25, 2009 | 04:54 PM
  #883
Ataru074's Avatar
Ataru074
go there.. have fun!
you are on time to buy a second set of tires and go for higher sidewall if you feel that the tires are "snapping" away...
Old Mar 28, 2009 | 09:19 AM
  #884
nkohler's Avatar
nkohler
Running 275/40/17 Hoosier R6 on all 4. Wheels are CCW classics 17x9.5F 17x10.5R.
Old Mar 31, 2009 | 08:21 AM
  #885
JohnnyHT's Avatar
JohnnyHT
Default H4LP! Wheel/Tire question...not what you think!
So yesterday I woke up to this:
Reference thread: https://my350z.com/forum/mid-atlanti...e-morning.html
...my adjuster just came out and they are cutting me a fairly large sum of money.
My question is:
What wheel/tire combonation can I buy and STILL be in BS class for autox. This is my first year and I don't want to heavily mod my vehicle and would like to learn how to use my vehicle in it's stock form...or damn close to it. Stock wheel combo + labor = $8800...
Any help will be greatly appreciated.
v/r
Johnny
Old Mar 31, 2009 | 09:41 AM
  #886
warmmilk's Avatar
warmmilk
[IMG]http://i32.photobucket.com/albums/d41/johnnyis300/1238418100741.jpg[IMG]
My question is:
v/r
Johnny
can someone steal my wheels please...
what insurance company are you with?
Old Mar 31, 2009 | 09:51 AM
  #887
Billhyco's Avatar
Billhyco
can i please have the name of your adjuster
  #888
06blueZ's Avatar
06blueZ
holy crap blessing in disguise! thats nuts, why dont you look for a set of stock wheels for sale around here and put 8k towards paying off the car or save it? thats what i would do...
Old Mar 31, 2009 | 12:13 PM
  #889
aRYip's Avatar
aRYip
oh please... someone steal my wheel and give me $8800...
Old Mar 31, 2009 | 02:11 PM
  #890
BPRacer's Avatar
BPRacer
I'll sell you my wheels and tires for only $8,500. Ya know, just to help out a fellow autocrosser... that way, you'll still have $300 to put towards other stuff!
Old Mar 31, 2009 | 02:41 PM
  #891
Ruff Z's Avatar
Ruff Z
18x8 front and 18x8.5 rear within 1/4" of stock offsets.
Old Mar 31, 2009 | 02:56 PM
  #892
El PreZidente's Avatar
El PreZidente
Which are?!?
Seriously I've searched, hard, and only found info for the pre-'06 wheels, and even then I think only the "Track" rims, not the '06+ stockers.
Old Mar 31, 2009 | 03:01 PM
  #893
DavesZ#3's Avatar
DavesZ#3
In a way, you've hit the jackpot. You ought to be able to buy a set of 06 OEM wheels with tires for way under $2K, even less if the tires are worn some. Then you could spend the rest of the money on some "show" wheels and tires, i.e. 19" Volks.
Old Mar 31, 2009 | 03:29 PM
  #894
JohnnyHT's Avatar
JohnnyHT
I've been searching for OEM Track wheels...but I haven't found any. I'm still searching.
I take it the 06 OEM wheels clear Brembos? Forgive my ignorance, please. Also, will they weigh different and if so, would it be negligible performance-wise?
Old Mar 31, 2009 | 03:36 PM
  #895
iStan's Avatar
iStan
ZR
Originally Posted by El PreZidente
Which are?!?
Track and 06+ 18*8+30 18*8.5+33
Old Mar 31, 2009 | 04:20 PM
  #896
warmmilk's Avatar
warmmilk
enkei rpf1's come in a size and offset that qualify, the size's are listed above, i'm not sure on the offsets though
Old Mar 31, 2009 | 05:01 PM
  #897
DavesZ#3's Avatar
DavesZ#3
I'm confused or maybe didn't read this whole thing properly. You have an '03 Z, apparently a Track model since it has the Brembos. Not sure why you're looking at 06 wheels.
Do what I did. I use the OEM track wheels for autocrossing with some grippy tires like the Bridgestone RE-11s (formerly RE-01s), Falken RT-615, etc. You should be able to find a set of 03-05 OEM track wheels for around $500-$600. Tires will run you about $1000 to $1200.
The rest of that money could be spent on some really good wheels and tires for the street.
Old Mar 31, 2009 | 05:09 PM
  #898
Ruff Z's Avatar
Ruff Z
Because he couldn't find a set of track wheels, and the 06 wheels are the same size and offset. Weight differences are about 5-6lbs heavier per wheel for the 06's.
Old Mar 31, 2009 | 05:16 PM
  #899
Ruff Z's Avatar
Ruff Z
After a quick search, the only wheels I found that are BS legal other then the Enkei RPF1's are these new OZ Racing wheels. OZ Alleggerita HLT They come in a crap load of colors! The Enkei's are about a half a pound lighter then the OZ's.
Old Mar 31, 2009 | 06:28 PM
  #900
JohnnyHT's Avatar
JohnnyHT
I'm trying to do the exact thing you're saying but with no results. I would like to find some OEM track wheels, hell...i'll take some that are painted, but the issue is finding them.
As of right now, I'm looking at some RPF1's and Dunlop Direzza Z1 Star Specs.
