Prepping for cage install - couple questions
Old Sep 13, 2010 | 05:47 AM
nkohler's Avatar
nkohler
Default Prepping for cage install - couple questions
So I am prepping for my cage build and I was wondering what people have done with the large metal speaker box/enclosure? I noticed that it is bolted down and that would not have been an issue, but I also noticed it looks tack welded in many places.
Are most of you guys removing this? Is it legal per NASA PT or SCCA T2 rules?
ALSO, I have looked at a few pictures and most of you guys are removing the black corner sections in this picture. I was unsure to remove them as I did not know if they provided any kind of rigidity.
Thanks!
Neil
Old Sep 13, 2010 | 05:57 AM
laze1's Avatar
laze1
My black cover are removed, and both OEM braces are still installed...
Thanks!
Neil
Old Sep 13, 2010 | 12:17 PM
GT-Rob's Avatar
GT-Rob
^ beauty cage! What are you using as a pump for the diff oil?
OP: I am gutted from the rear back as well, and know the bolts you talk about, but there is no way to remove that top speaker shelf without some cutting. I could a cage setup easier as you have more room to do a sharper angle (if you wanted to), but from what I have seem people go over top of it pretty easy.
Just to hijack slightly, do the black covers offer anything structural? Any reason not to remove them?
Old Sep 13, 2010 | 12:24 PM
terrasmak's Avatar
I have to leave mine in for the cage install (class rules) but am cutting the rear strut tower brace out and welding in a tubular one. I just want a little extra room for bringing stuff to the track.
Old Sep 13, 2010 | 12:32 PM
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by laze1
LAZE,
could you please pm me pics or show us more pics of your diff cooler set up, top and bottom, would like to see the floor penetrations in the AN fittings...
Ive wanted to make a hatch side fill port!
cage looks awesome too...love it!
I like the Passenger side dash mounted kill switch too...
-J
Old Sep 13, 2010 | 01:03 PM
laze1's Avatar
laze1
I believe the PO purchased a kit from bimmerworld.com...and it uses a Genises Oil Pump
http://genesisparts.com/index.cfm?tp...action=product
http://store.bimmerworld.com/differe...oler-p339.aspx
diff oil?
Old Sep 13, 2010 | 01:24 PM
laze1's Avatar
laze1
Here are the pix,
But I don' think it is installed correctly....even if the Bimmerworld pix show its mounted this way. I talked with Genesis and they suggested that the pump be at a low point in the system to prevent cavitation...(pump going dry)
So I have removed the system and will reinstall it with the pump under the ~trunk floor, and maybe all the other parts as well...if I can find a safe place for the cooler...The thing puts off some HEAT! So it makes racing in the South even HOTTER!
Note: The PO said this leaked after using it for a couple of races...i think the pump ran dry and cooked the seals...but Genisis sells a seals kit for about $40 and will also rebuild then as needed.
Also, these is used primarily for Enduro races, not so much sprint races...
Originally Posted by JasonZ-YA
LAZE,
-J
Old Sep 13, 2010 | 03:52 PM
350zDex's Avatar
350zDex
Damn very niceeee!!!!!
Old Sep 14, 2010 | 03:43 PM
Nackers's Avatar
Nackers
I know nothing about your rules. However, I know that cutting out that panel gave me tons of room and makes it look like it was a 2x2. Oh, and maybe got me 60lbs lighter? We didn't weigh it... just sayin.
Old Sep 14, 2010 | 04:15 PM
nkohler's Avatar
nkohler
Anyone familiar with NASA and/or SCCA rules know if the removal of that section will violate rules? I am thinking it will in SCCA but NASA it may not as long as you arent below minimum weight?
Guess I may have to wade through the rule books...
Old Sep 14, 2010 | 07:14 PM
dkmura's Avatar
dkmura
General & DIY Moderator
The Nissan Sport Project 350Z T2 car was built to SCCA T2 rules and has been campaigned for the past three seasons. I can categorically say that you CANNOT remove the rear shelf section. The bolt-in rear bracing has to stay as well. While I also race the Z in NASA PTB, I cannot modify it any further without exceeding SCCA prep limitations.
Old Sep 14, 2010 | 07:58 PM
nkohler's Avatar
nkohler
good to know! hmmm... guess I should just stay on the safe side
Old Sep 15, 2010 | 07:53 AM
betamotorsports's Avatar
betamotorsports
Mount the fan under the cooler and cut a hole in the floor pan to vent it down. Put a screen over the hole in the pan to keep the squirrels out. The pump doesn't need to be the low point, just make sure its below the natural fluid level in the diff. You can also mount the cooler under the car up near the trans tailshaft. That's how the press fleet 370Zs were setup.
Old Sep 16, 2010 | 03:39 AM
laze1's Avatar
laze1
mounting the pump that low is the challenge...but doable..
Old Sep 16, 2010 | 04:07 AM
JasonZ-YA's Avatar
JasonZ-YA
THIS! is so baller!...
I love it!
-J
Old Sep 16, 2010 | 05:15 AM
RandomHer0's Avatar
RandomHer0
I love this thread lol
Old Sep 16, 2010 | 05:22 AM
JasonZ-YA's Avatar
JasonZ-YA
^ ya me too...lol..
Nackers, did they mask off the entire car for paint? how was the cage painted?
Also, is this your second cage in the car??? i see mount plates off the back strut bar unused??
man, i really gotta get going on fab'n a cage..
-J
Old Sep 16, 2010 | 06:07 AM
RandomHer0's Avatar
RandomHer0
That diff cooler setup is way sick!
Old Sep 16, 2010 | 07:05 AM
betamotorsports
The pump can be in mounted in front of the diff. I've mounted one in the little pocket on the right side of the tunnel just in front of the diff.
Old Sep 16, 2010 | 05:54 PM
laze1's Avatar
laze1
I will check that space out,,,
