where to go next AutoX Mods
Old Nov 15, 2010 | 10:15 AM
travis0260's Avatar
travis0260
Default where to go next AutoX Mods
Hey guys
I drive a 2006 350z base and I autoX on occasion. I don't really care about staying in a specific class. I basically AutoX because we don't have any tracks in SanDiego.
Mods:
VLSD from track model
Falken Azenis RT-615 255-40-18 all four
Eibach sway bars front and rear
plenum Spacer
HR Y Pipe
(just Ordered) adjustable sway bar end links
Right now the car is pretty balanced with the sway bars. I still have to be a little easy on the gas when exiting a turn. This is my daily driver so the mods need to be moderately friendly for day to day commuting. I have about 600 to spend.
Thanks
I don't think that the car has very good steering response
Old Nov 15, 2010 | 12:09 PM
terrasmak's Avatar
Front camber arms, and a trip to Autoclub Speedway. No track WTF, i stayed in NCSD over this past Time Attack weekend.
Old Nov 15, 2010 | 01:07 PM
betamotorsports's Avatar
betamotorsports
OS Giken Super Lock LSD.
And you've got at least 5 race tracks within an 8 hour drive of San Diego and 3 within a 4 hour drive.
Old Nov 17, 2010 | 07:07 AM
travis0260's Avatar
travis0260
ok, it's probably more realistic to get the camber arms for for under 600 rather than the LSD. I'll probably start with those. You guys are right about the track stuff. They're a couple pretty close tracks. I was thinking streets of willow for a fist track. let me know if you guys recommend something different.
thanks
Old Nov 17, 2010 | 07:12 AM
betamotorsports
The OSG LSD (actually, any LSD other then the VLSD you have in your car) will lower your lap and course times a lot more then camber arms will.
Old Nov 17, 2010 | 07:16 AM
JasonZ-YA's Avatar
JasonZ-YA
for autoX and front upper control arms I would recommend either SPL (camber and caster adjustable) or Kinetics Stainless steel arms (camber only).
Reason being - both can do track side camber adjustments, easy for a daily driven/autoX car.
Read post 7&8 here on that:
https://my350z.com/forum/brakes-and-...ion-101-a.html
spl install - https://my350z.com/forum/brakes-and-...hims-made.html
kinetics install - https://my350z.com/forum/brakes-and-...s-install.html
-J
Old Nov 17, 2010 | 07:19 AM
JasonZ-YA's Avatar
JasonZ-YA
however, i would save for LSD and gears if autoX is your passion...
Look into 3.7 gears at a minimum with swapping from a G35 sedan:
https://my350z.com/forum/engine-and-...z-3-538-a.html
Others to think about:
-Suspension - coilovers, or good shocks and springs
-Harness bar and harnesses - more beneficial than you think!
-compression rod bushing paired with good upper arms is good.
-translink bushing
-Solid diff bushings
- hitch and trailer to take R comps to events.
-J
Old Nov 17, 2010 | 07:57 AM
travis0260's Avatar
travis0260
Thanks for the info guys, I'll go through the links and start looking through the content.
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
