track rims(valve stems)-rubber vs metal
Old Jan 31, 2011 | 08:56 AM
mw9's Avatar
mw9
Default track rims(valve stems)-rubber vs metal
What are you track guys running and why. What are the benefits of each and what do you prefer?
Old Jan 31, 2011 | 09:26 AM
halfrice's Avatar
halfrice
rubber, cheap easy to replace less likely to snap when hit
Old Jan 31, 2011 | 09:28 AM
RandomHer0's Avatar
RandomHer0
Rubber, was told by my wheel guy metal tend to leak. Whether there is merit I dunno.
Old Jan 31, 2011 | 11:57 AM
racerbob4's Avatar
racerbob4
We race on Enkei RPF1's and they come with short blue aluminum valve stems. They are short enough that they can't be sheared off by contact and are a very slight weight saving.
Old Jan 31, 2011 | 01:59 PM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
I used the aluminum ones that came on my enkeis and they ended up leaking after 6 months. Plain old rubber stems for me now since we mount my wheels and tires in house.
Old Jan 31, 2011 | 05:13 PM
terrasmak's Avatar
I run the blue ones that came with my Enkei wheels, guess i will swap out when they leak.
Old Jan 31, 2011 | 11:43 PM
bbs350z's Avatar
bbs350z
yea my rpf's have the factory metal ones. no leaking yet
Old Feb 1, 2011 | 04:34 AM
RandomHer0's Avatar
RandomHer0
Guess there is merit
Old Feb 1, 2011 | 09:40 AM
jnathan68's Avatar
jnathan68
My wheel guy (race shop) recommends using the rubber ones
Old Feb 1, 2011 | 11:34 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Hmmm...I also use Enkei RPF-1s and the short blue valve stems. With the lightweight R-compound tires (Hoosier R6 or Goodyear RS) currently in use, the tires themselves consistently bleed down, not the valve stems.
Whether it's rubber or metal, the key is having a valve stem that is short enough not to get torn out in any light metal-to-metal incident. If a tires does go down, it's because of heavy contact and probably some actual wheel damage has occurred.
Old Feb 1, 2011 | 11:58 AM
ThreeFiveZero Z
It probably isnt your tires. I had the same problem, switched to rubber stems. Problem fixed.
Rev_Night
Nov 7, 2020 06:00 PM
