New NASA Class for 2012: Spec Z
Old Apr 26, 2012 | 06:31 PM
  #661
Palmettogasman's Avatar
Palmettogasman
Originally Posted by Fixxxercask
Wow 3040 with driver! That's nice. Do you have any pics of your car and how gutted it is? Mine is pretty stripped down, in fact more than Spez Z will allow and I'm around 3090 at 3/4 tank of fuel. How much fuel was in the car, because fuel is heavy.
1/3 tank. Seemed light to me also so I'm going to re-weigh it at the track as well. I'm taking out the helper springs now so I'll have to corner balance again anyway.
Old Apr 27, 2012 | 01:33 AM
  #662
Fixxxercask's Avatar
Fixxxercask
Originally Posted by laze1
I am also asking for this to be removed...
k) Removal; or substitution of driver compartment panels is not permitted.
WTF does this mean??
Taking a shot in the dark here....maybe removing the floor pan and welding in a custom one for whatever reason. I know on old muscle cars they would rust or rot out and have to be replaced and you had to cut them out and weld in another.
I really have no idea. Technically everything around you is a "driver compartment panel".
Good luck!
Old Apr 27, 2012 | 09:26 AM
  #663
laze1's Avatar
laze1
You are correct...it is everything else not listed...i.e., the "Metals panels in the car"...and they don't want to remove this wording
I was asking what this was because of the guys that have removed the speaker box and other materials...and since I have my speaker box metal still installed, I am NOT gonna push it.
However, If some wants more info I WILL PURSUE IT!!!
Good luck!
Old Apr 28, 2012 | 04:52 AM
  #664
Fixxxercask
I think it will help make it easier for us to hit that 3100lb comp weight if we are able to remove that speaker box metal. Being able to remove the heater core and blower unit stuff helps now though.
Depending on how much fuel you burn in a race I know as it stands right now, I can hit 3100lbs probably around just under a 1/2 tank. Not sure if I topped off the car before a race if I would be above that when I come off track. My car has a few more things removed though that I need to put back on.
Old Apr 28, 2012 | 07:42 AM
  #665
terrasmak's Avatar
Since weight is such a big issue, is running a swirl/surge tank legal? That would allow you to run lower fuel and not starve.
Any thoughts about what I mentioned about bushings up above?
Old Apr 28, 2012 | 07:55 AM
  #666
Fixxxercask
I would have to check the rules again about fuel cells.
About the bushings, I believe the transverse arm is the compression arm.
I already have some Whiteline bushings in my car, so it would suck to have to take them out and replace with OEM or Nismo.
Because Nissan is involved though, they are going to want us to use their stuff unfortunately. I would not be opposed to running Whiteline or having the ability to run either or. They are relatively inexpensive compared to running spherical joints, too.
What other two bushings are prone to failure?
Old Apr 29, 2012 | 03:17 PM
  #667
2000atlanticgt's Avatar
2000atlanticgt
Suspension 101 post #2, transverse arm is the lower control arm, not the compression arm.
https://my350z.com/forum/8293374-post2.html
Old Apr 29, 2012 | 08:02 PM
  #668
terrasmak's Avatar
the compression arm and the rear diff bushing. Compression arm bushing you can buy from Nissan, but the diff bushing you have to replace the subframe.n
Old Apr 29, 2012 | 09:51 PM
  #669
scotts300's Avatar
scotts300
Originally Posted by Palmettogasman
Need some advice on safety equip for my spec z build after watching the video of 350z crash at a mid Ohio SCCA event. I was considering the Kirkey full containment or Sparco Pro ADV since both have the large head restraint but I was concerned that I wouldn't be able to get out the drivers side window quickly or it would impede vision on drivers side. ( I'm 5'11" about 185#) Any thoughts? Also should I get the 6 point harness? G Force seems to have a great price for one but it seems to good to be true. A kill switch is recommended in the CCR but is not mandated by our class rules that I could find. If I mount one, any thoughts on best location? Thanks for any input, this thread has been mucho helpful during my build
I have a full-containment seat, and was timed at like 2.5s getting out of the car. NASA tech DID ask for and check my kill switch. I was under the impression it was required for NASA (but not for SCCA Touring). We mounted mine on the driver's left, on the "inside" of where the OEM side mirror is so that safety crews could access it easily as well as myself.
Originally Posted by mhoward1
The g-force 6 points are good harnesses. If you can spend a little more, get the Cam latch vs the standard. It will make things much easier.
Yes, you really need a kill switch. Mount it in a place where both you and an EV worker can reach. AGREED
On almost any of the full containment seats, egress is easier than you think. The belts and any accessories will slow you down more than the seats will. A good test is to be able to exit the car in 10 seconds or less. You can exit through the door, you don't have to use the window. As far as vision goes, your H&N device will impede your side vision more than the seat will. This why proper mirror set up is so important.
10s or less is actually what was required when I went through tech. I did read awhile back that the G-force harnesses can stretch a bit more than the higher-cost ones, so that's something to keep in mind. I do realize, of course, that they pass the SFI requirement, and SCCA allows the belts for one year longer than NASA. Also note that most of the budget restraints have 3" shoulder belts, which work but are not the most comfortable when wearing a H&N restraint. I didn't realize how much nicer/more comfortable the 2' shoulder straps were until I got a set; they are MUCH easier to navigate than their 3" counterparts.
I'm going to PBIR Saturday to try out the new spec z suspension and was wondering what you guys think of my initial settings. Surprisingly the weight came in at 3040 with driver (185#) so if scales are correct I'll need ballast to 3100 for my 2004 z. Left was 51.7%, rear 48.7 % and cross was 50.4% (LR to RF). Hard to jack weight around since the rear is maxed out on the spring to the lowest ride height. Still waiting on rims due to possible rule changes so running my old RE11's on 18 inch LMGT4's. LSD installed as well. Due to my ltd experience (HPDE, karting and Chumpcar) I would prefer to start with a little understeer I think. Critique at will, I'm thick skinned.
Sways=full stiff front, mid rear. Dampers= initial rec's per the KW instruct manual
Toe=1/16 out front, 0 rear. Caster +8.4 LF, +8.2 RF
Camber= -1.7 LF, -1.5 RF ( any suggestions to get more?)
-2.5 LR, -2.1RR
2855 without driver and spec-legal? Wow! I'm still 60-80# heavy, but will lose some of that with changing wheels and exhaust. Any reason for the 0.4 delta in rear camber? I also think you are going to want much more front camber - whatever you can squeeze out of it. I started full soft F/R sway bars, and adjusted from there. Are you on the spec tire?
Yep, I purchased 4x RPF1s in 18x10 ET 38...still waiting on the 18x9 ET35 wheels to get here on the dayum boat from Japan...Enkei is out of everything that works for this class now...
Anybody want to sell me 2x 18x9 RPF1 ET 35 in silver?
Also, since they dropped the spacer size rule, it helps finding wheels that fit or could be used in a Square setup...
I have two you could borrow, if you're game for that expensive proposition. . .
That would be great, since I'm seeing some fuel starve with 5 or 6 gallons remaining after a high-speed/G right turn (T-hill T15)
Old Apr 30, 2012 | 01:22 AM
  #670
Fixxxercask
I do remember the diff bushing. I was going to get Whiteline ones, but they are not legal for Spec Z. Like you mentioned, it would be nice to be able to use those.
Old Apr 30, 2012 | 01:23 AM
  #671
Fixxxercask
Thanks. Those are some good drawings.
Old May 1, 2012 | 06:40 AM
  #672
idrive_MD's Avatar
idrive_MD
I'm kind of surprised they didnt just go with whiteline...if you look at the Nissan-Motorsports Catelog they actually list and suggest Whiteline products for various cars. Regardless, it is still a step in the right direction, but the rear diff was definitely an overlook. it is still a young series, so i am sure it will adapt with the trends.
Old May 1, 2012 | 07:16 AM
  #673
DFW Z33's Avatar
DFW Z33
I am salad
Hey guys, I had two questions.
1) As far as I can tell, the only LSD upgrade allowable for spec Z is the wavetrac LSD. Does this mean we arent allowed to use the Nismo LSD even though most other Nismo parts are allowed?
2) I see a lot of people complaining about this new Spec Z class (mostly on other forums) because their modified Zs are modded well above the specs of this class, and they dont want to have to remove them. Can they not still race PT/ST with the 350z now that this class has been created?
Thanks!
Old May 1, 2012 | 07:19 AM
  #674
Fixxxercask
I believe you are correct on the LSD unless you want to use a stock VLSD.
...and yes those other guys can race in PT. It just depends on their mods where they would end up....most likely PTC, PTB or PTA.
Old May 1, 2012 | 07:25 AM
  #675
mhoward1's Avatar
mhoward1
Thanks!
Correct, no other classes have been removed or the 350Z excluded, this is just a new place to run that will help keep costs down a bit, and allow all the displaced T2/T3 cars from SCCA have some fun. It will also give the 350Z a place to run up front depending on the driver and the setup vs being the underdog in most other classes.
Old May 1, 2012 | 09:10 AM
  #676
scotts300's Avatar
scotts300
Up front of the SpecZ class - yes, this is certainly possible. Up front of the mixed class they are (currently) having us race in - no way (ST2, SU, ThunderRoadster, GTS3).
Old May 1, 2012 | 09:44 AM
  #677
mhoward1's Avatar
mhoward1
Umm...if a 350Z isn't upfront in SpecZ, then we have bigger problems.
Old May 1, 2012 | 11:55 AM
  #678
scotts300's Avatar
scotts300
Old May 1, 2012 | 04:13 PM
  #679
laze1's Avatar
laze1
So, the Nissan dealer can't get the Dayum Wavetrac into a stock 2007 Open diff...can't get the C-clips in.....F HJJJHJ<NKLHB NBH K~!
Something about the stub axles are "mushroomed"...WTF????
Old May 1, 2012 | 06:38 PM
  #680
LFTFTBRKR's Avatar
LFTFTBRKR
What do they mean by "mushroomed"? Have you looked at having the grooves machined to accept the clips like Terrasmak did?
If it looks like it's going to take a while to get the Wavetrac sorted out we can swap the Carbonetics diff back in after I do AMP on the 12th.
