New NASA Class for 2012: Spec Z
Old Jan 29, 2013 | 10:48 AM
  #1181
Waco Racer's Avatar
Waco Racer
Originally Posted by scotts300
3.5 x 5.75" = 20sq in
2.53" dia = 5sq in
?? Yeah, that doesn't add up.
Old Jan 29, 2013 | 11:23 AM
  #1182
laze1's Avatar
laze1
Special 2013 Supplemental rules
1. All Spec Z racers located in the state of Californication may only receive a trophy less than 5.2 MM high x 2.77MM wide or have the use of the winners flag at any point during a race weekend.
2. All Spec Z racers located in the state of Californication may not have Flag Girls present at the track or other locations at any time during a race weekend...
3. All Spec Z racers located in the state of Californication will be weighed before and after every sesson, and must run a NASA provided Traqmate unit to test for horsepower at all times.
Man, you guys get it all. We don't even get trophies.
Old Jan 29, 2013 | 12:07 PM
  #1183
scotts300's Avatar
scotts300
Ha! At least the Traqmate is NASA-provided! I'll bring my own dang flag girl!
Attached Thumbnails New NASA Class for 2012: Spec Z-j-with-z-seca.jpg
Old Jan 29, 2013 | 01:27 PM
  #1184
03threefiftyz's Avatar
03threefiftyz
She's a keeper...
Old Jan 29, 2013 | 02:12 PM
  #1185
dkmura's Avatar
dkmura
General & DIY Moderator
Grrrrrrrrrrrrrrrrrrrrrr. This is going to cost me. $%^*@#$*@#
You mean the diffs? Both of us have already spent the money on Wavetracs. The Wavetrac LSD may prove to be the better and faster unit, it just needs cooling to go with it. I held onto my older NISMO diff, so it'll be the alternate/backup unit.
Old Jan 29, 2013 | 02:39 PM
  #1186
laze1's Avatar
laze1
Can she do brakes as well?
She's a keeper...
Old Jan 29, 2013 | 03:37 PM
  #1187
scotts300's Avatar
scotts300
She's a keeper...
She is! She now wears the RING.
She can and she has! She needs a Smitty Racing T-shirt. Those will be new for 2013.
Old Jan 29, 2013 | 05:03 PM
  #1188
KNS Brakes's Avatar
KNS Brakes
Vendor - Former Vendor
They must mean 2.53 radius (20.1 in^2)
Old Jan 29, 2013 | 05:05 PM
  #1189
KNS Brakes's Avatar
KNS Brakes
b) Brake rotors must be the same type, material, and dimensions as OEM. Brake rotors from
alternate companies may be used. Brake rotors may be cryogenically treated.
So slotted are OK - 2 piece are not.
Old Jan 29, 2013 | 06:28 PM
  #1190
dkmura's Avatar
dkmura
Slotted are not OK. Neither are two-piece rotors. OEM rotors are one-piece, vented or solid- but not slotted.
Old Jan 29, 2013 | 06:35 PM
  #1191
KNS Brakes's Avatar
KNS Brakes
All OEM rotors are all vented - that's irrelevant here (vented means 2 friction plates connected by cooling vanes - all 350Z's have vented rotors both front and rear)
There is no specific verbiage regarding machining rotors (either drilled or slotted). I would expect that if it were disallowed it would be specifically addressed.
Old Jan 29, 2013 | 07:43 PM
  #1192
bkleeman's Avatar
bkleeman
Well.... I'm out.
Old Jan 30, 2013 | 04:53 AM
  #1193
Waco Racer's Avatar
Waco Racer
This covers the slotted rotor question -
4 Format
Modifications, addition or removal of parts are not allowed, unless specified or approved in these rules. Additional modifications are not permitted. These rules are not intended as guidelines; rather they shall serve as the national set of rules, and must be strictly followed. Each NASA Region is responsible for ensuring that all competitors running in the corresponding regional championship conform to these rules. Replacement parts not specified by these rules must be OEM or the exact equivalent. Plainly put, if these rules do not state a modification is permitted, it’s not!
Old Jan 30, 2013 | 09:14 AM
  #1194
scotts300's Avatar
scotts300
Agreed, but rules are rules as written for now at least. Rectangular holes it is!
Old Jan 30, 2013 | 09:17 AM
  #1195
KNS Brakes's Avatar
KNS Brakes
I'm going to forward this to Jeremy at Nationals. That's silly
Old Jan 30, 2013 | 09:25 AM
  #1196
KNS Brakes's Avatar
KNS Brakes
4 Format
Nice read
Most SCCA like
Old Jan 30, 2013 | 09:29 AM
  #1197
mhoward1's Avatar
mhoward1
Just FYI,
Waco Racer here is Clifton.
Old Jan 30, 2013 | 09:44 AM
  #1198
KNS Brakes's Avatar
KNS Brakes
Originally Posted by mhoward1
Just FYI,
TY
Well he should be able to fix that then eh?
Unless they want square ducts for some reason?
-Ken
Old Jan 30, 2013 | 10:46 AM
  #1199
KNS Brakes's Avatar
KNS Brakes
Hey - Thanks for the call sir!
FYI - I was NOT just trying to push slotted rotors. In fact the opposite. I DID want to push for RULES CLARIFICATION at least as far as brakes are concerned.
I had DBA make me LOTS of blanks for other markets w/ similar needs - and I would likely consider the same here because it's the same situation. The OEM rotors are certainly good but overly expensive so it's an opportunity for a good rotor like a DBA.
And just for discussion - we also had blanks made where the OEM rotor is drilled (C6 Z06). Do you want the rules written such that for these type cars they MUST run a drilled rotor?
(The drilled OEM C6Z rotors crack pretty fast on track - and unpredictably.)
Old Jan 30, 2013 | 11:05 AM
  #1200
scotts300's Avatar
scotts300
I sure don't! With aggressive pads, I just consider the rotors a wear item similar to brake pads, and change them every couple events. I buy the cheapo blanks from Rock Auto for like 30 bucks a piece. I have tried special rotors like dba, and did not see anything in longevity but did note a lighter pocketbook.
