The 2TH PWR Track Car conversion
Old Sep 9, 2012 | 12:05 PM
  #261
Z33_Taxi's Avatar
Z33_Taxi
sub'd
nice build...even better driving
Old Sep 15, 2012 | 07:11 AM
  #262
2TH PWR's Avatar
2TH PWR
well car is back. but doesn't start so reliably with the new flywheel. The starter gears don't mesh perfectly with the flywheel gears and I get some grinding.
I'm gonna have to go like this for 2 weeks babying it and then go back to stock after.
Old Sep 15, 2012 | 08:08 AM
  #263
XChacalX's Avatar
XChacalX
which flywheel did you install ?
Old Sep 15, 2012 | 08:49 AM
  #264
2TH PWR's Avatar
2TH PWR
And oh yeah. Here is the new dyno. With new engine and headers I gained..
da da da daaa
1 peak hp over my old engine and lost 5 peak lb.ft.
So obviously my old engine was, before it totally died, a strong one. Nonetheless this engine feels so much better than my old one did. It's pretty obvious that the old engine was losing power steadily over the summer.
And at least it sounds more like a racecar inside. Has more of a wail to it.
Old Sep 15, 2012 | 08:54 AM
  #265
2TH PWR's Avatar
2TH PWR
Z1 motorsports flywheel.
So I called Z1. Same story, Z1 says APH didn't instal it right. APH says there is only one way to instal it or it won't even mate up. I kind of believe APH.
So. Long story short. That flywheel and clutch won't be on the car very long. I will throw out the flywheel (even though it feels awesome once the car is running) and sell the practically new clutch to someone at a discount.
Old Sep 15, 2012 | 11:10 AM
  #266
timmywhatsup's Avatar
timmywhatsup
Thats *********. With all the experience APH has I would be surprised if they messed up installing it. It appears there should be a marking on the flywheel so it lines up properly. I could be mistaken though. For Z1 to default the blame on the shop, I'm assuming they already know 110% the part is not faulty. I would like to know how? This seems irresponsible to me as a number of things could have been messed up during the manufacturing process. As we all know ALL parts are perfect from the factory EVERYTIME we receive them. New parts that are bogus are unheard of in the aftermarket word. Or even OEM world for that matter.
The reality is until its disassembled, and the alignment is verified, part inspected, nobody knows for sure if it was an install issue, or bummed part, and Z1 should be reserving judgement until this is verified.
Its ridiculous you have no other option but to throw the flywheel in the garbage after spending your hard earned cash on it.
I sincerely hope this is not the case and a better solution is found.
Old Sep 16, 2012 | 11:17 AM
  #267
Z33_Taxi's Avatar
Z33_Taxi
I'd have the shop document exactly how it was installed with pictures and written report. Then send that and the flywheel back to Z1 and ask for a refund or at least credit
Old Sep 17, 2012 | 08:29 AM
  #268
Sleepy79's Avatar
Sleepy79
da da da daaa
what kind of headers?
Old Sep 17, 2012 | 09:19 AM
  #269
2TH PWR's Avatar
2TH PWR
Momentum performance.
the 1 hp gain isn't really indicative of their gains. It was a different engine.
Old Sep 17, 2012 | 12:03 PM
  #270
Sleepy79's Avatar
Sleepy79
Nice. I also installed them along with, 5/16 spacer + mrev.
Hard to say what I had gained.
I do have an issue with my headers, drivers side first primary touches the engine mount (engine side). Did you notice anything like that with yours?
Old Sep 17, 2012 | 01:59 PM
  #271
2TH PWR's Avatar
2TH PWR
I didn't notice but Iwill try and take a look tonight
Old Sep 17, 2012 | 03:00 PM
  #272
Duckeee's Avatar
Duckeee
waiting to see your car back on the track with some vids of the new engine screaming.
good luck with the flywheel though. if it were me, i'd ask for a refund from Z1 and get a different flywheel. the last thing id want is another stock flywheel, or remove and re-install the same flywheel in hopes it works this time around only to find out the problem still stands and you have to do or pay for the labor all over again.
Old Sep 18, 2012 | 12:30 PM
  #273
jamestown's Avatar
jamestown
I happened to see your car at aph sometime last week and it looks awesome! I was wondering where you bought the rpf1's from (locally perhaps??)
Old Sep 18, 2012 | 03:57 PM
  #274
2TH PWR's Avatar
2TH PWR
I got them at OAKOS auto. It's pretty close to me. I'm going to need a set of wider ones.
Old Sep 19, 2012 | 03:45 PM
  #275
jamestown's Avatar
jamestown
What size are you running now? 18*9.5 square? Thinking of going to 10.5?
Old Sep 19, 2012 | 04:10 PM
  #276
2TH PWR's Avatar
2TH PWR
^ yes
Old Sep 20, 2012 | 12:09 PM
  #277
jamestown's Avatar
jamestown
^ yes
Assuming they are +15, probably just go ahead and sell your old rims to me when you take the leap
Old Sep 20, 2012 | 01:38 PM
  #278
2TH PWR's Avatar
2TH PWR
Yeah they are +15 but I will probably rock both sets.
Old Sep 20, 2012 | 03:31 PM
  #279
XChacalX's Avatar
XChacalX
wize decision , its aloways safer to bring a second set of rim/tire to the track in case something happen !! ( rain tire as an exemple !!! )
Old Sep 21, 2012 | 09:22 PM
  #280
jamestown's Avatar
jamestown
Hey 2th, did you have any vdc problems with your square setup?
