The 2TH PWR Track Car conversion
Old Dec 11, 2012 | 06:54 PM
  #401
2004Black350z's Avatar
2004Black350z
Exhaust Whore
What are you running cooling system wise? Thermostat etc
Also what pulleys were you thinking? Ams? Unorthodox?
Old Dec 11, 2012 | 07:35 PM
  #402
2TH PWR's Avatar
2TH PWR
I honestly don't see how it would make a difference. I just did it for 11 pounds off the front. And there's nothing in the rules that says I cant.
Old Dec 11, 2012 | 08:07 PM
  #403
2TH PWR's Avatar
2TH PWR
Not sure if I'm going to go with pulleys or not. It's not going to make a lot of power... But I guess it would save some weight.
As far as cooling it hasn't really been a problem. Its warm... but not as hot as the states would get in the middle of summer.
Old Dec 11, 2012 | 08:32 PM
  #404
GT-Rob's Avatar
GT-Rob
It actually could help. Not only with drag, but with downforce.
Here is a CFD on a rotating wheel
The numbers are Cp, with is co-efficient pressure. Cp=1-(V/Vinf)^2, where V is Volume of air.
So V/Vinf = (1-Cp)^0.5. You can ignore this for now I will make my point at the end.
in the picture, lets take a look at 150deg. At this point the air has gone around the wheel and is trying to exit and is hitting the sideskirt/body of the car, hence the pressure has increased from -19 up to -36
To find our atmospheric pressure here, V/Vinf = (1-(-36))^0.5, or 1.17. This means the air at this spot is 117% of the air outside before it came in.
When air volume is higher than the atmosphere, it is a higher pressure, and thus slower moving air. If this were to enter the bottom of the car, exactly where it would go, it would raise the overall volume of air under the car, raising the pressure, slowing it down, and causing LIFT!!
So if you can exit the air from 150-210deg, the air is a lower pressure when leaving. It is still higher than atmosphere, however it is not exiting under the car and instead into the side of the car, which is already a high pressure area (which above the car, is a good thing).
In practice, you will see a bit of this. More often is hood louvers, which can be less practical as you need pretty wide fenders to begin with, plus it tends to throw rocks at your wind shield. But this throws that high pressure air over the car, and actually creates substantial downforce.
World time attack GTR
Old Dec 12, 2012 | 02:42 AM
  #405
2004Black350z
Exhaust Whore
Gotcha. I didn't mean cooling with overheating just cooler temps make a car slightly faster. Running any kind if oil cooler? Also just realized your Canadian ay lol
Old Dec 12, 2012 | 05:37 AM
  #406
Wu-Watt's Avatar
Wu-Watt
Yup we're a buncha Canadian's here guy!
Old Dec 12, 2012 | 08:08 AM
  #407
2TH PWR's Avatar
2TH PWR
I can't believe I basically own a world time attack car now. unreal.
Old Dec 12, 2012 | 08:13 AM
  #408
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ What are the rules/limitations on a world time attack car?
Old Dec 12, 2012 | 08:18 AM
  #409
2TH PWR's Avatar
2TH PWR
oh don't feel bad. that basically happens everysingle day here in Canada.
Old Dec 12, 2012 | 08:21 AM
  #410
KingBaby's Avatar
KingBaby
Hardest Setting
Are you planning on putting anything back there! I like the idea but the door is gonna catch air now? I would of at least cut the fender then pull it toward the inner frame?
Like
Replace the asterisks with "the 370z"
In for more
Old Dec 12, 2012 | 05:39 PM
  #411
03threefiftyz's Avatar
03threefiftyz
Might as well go all out and do a ground effects car...
Under-body shaped wing w/side skirts to a big *** rear diffuser. Run a smaller rear wing....more downforce...less drag.
Because racecar.
Old Dec 12, 2012 | 06:56 PM
  #412
timmywhatsup's Avatar
timmywhatsup
Jeremy Clarkson: You have gone MAAAAD!
Awesome man!
Old Dec 13, 2012 | 07:41 AM
  #413
2TH PWR's Avatar
2TH PWR
Awesome man!
Yah man. 350z has to compete! Corvettes & rx7 s I'm scared of them.
Old Dec 13, 2012 | 07:53 AM
  #414
2TH PWR's Avatar
2TH PWR
Like
In for more
I can't view the link. Don't have an account
No it won't catch air. It's got tire and bumper in front of it pulling air forward so I'm sure it's in a vacuum.
Even if it does it will be miniscule. I'm also running with out external side view mirrors so that will more than offset any drag.
I will put a side skirt on. A big one.. I considered bending the sideskirt into the wheel well a bit to help scoop air to the out side of the car.
Old Dec 13, 2012 | 08:03 AM
  #415
JGYMotorsports's Avatar
JGYMotorsports
Vendor - Former Vendor
im loving this, def love the super gt look aswell
Old Dec 13, 2012 | 08:43 AM
  #416
2TH PWR's Avatar
2TH PWR
This is the same as redline time attack basically. Rules are very wide open in all classes
Old Dec 13, 2012 | 09:41 AM
  #417
KingBaby's Avatar
KingBaby
Hardest Setting
here's a pic of what I was talking about! using the piece you cut off and welding it to the frame...
still badass you going to these limits...
Old Dec 14, 2012 | 04:35 PM
  #418
2TH PWR's Avatar
2TH PWR
I'd say mine looks lighter but same idea!
Old Dec 29, 2012 | 03:07 PM
  #419
2TH PWR's Avatar
2TH PWR
more 2013 parts on the way. have to whoop some xchacalx 370Z butt!!!!!!! lol
Old Dec 29, 2012 | 03:38 PM
  #420
KingBaby's Avatar
KingBaby
Hardest Setting
I like the level of inspection...
