ST/SU Build
Old Mar 23, 2016 | 07:32 AM
  #241
90nissanS13's Avatar
90nissanS13
Originally Posted by Dblock55
Dunno if I want to publicize the horror that are my welds
lol okay, pm me. Maybe I could give you feedback and help you get up to speed quicker. I made some sample welds of sheet metal to .125" plate. That would simulate the baseplates to the unibody, this should be the most difficult welds you'll do on the cage.
Old Mar 27, 2016 | 11:36 AM
  #242
90nissanS13
Did you ever solve your coolant/bleed issue? If not, read this.
https://my350z.com/forum/engine-and-drivetrain/280274-z-is-overheating-after-coolant-change.html
Old Mar 27, 2016 | 08:31 PM
  #243
rustyschopshop's Avatar
rustyschopshop
https://my350z.com/forum/engine-and-...nt-change.html
His cooling system is not stock. Most of his "extra" cooling system has been removed so it is a bit different but several pages back he mentioned that he was able to get the air bleed out after exchanging his thermostat.
Old Mar 27, 2016 | 08:44 PM
  #244
90nissanS13
Yeah, I remember he removed the HVAC. I didn't recall if he resolved the bleed issue. I just put here regardless.
Old Mar 29, 2016 | 10:12 AM
  #245
Dblock55's Avatar
Dblock55
Hey bud! Sorry for not answering, ive been away on a work trip and its been pretty hectic... the system is pretty much gutted so the bleed procedure you linked isnt really applicable. Thanks though! I did manage to get the system bled after some serious black magic... i jacked the front of the car waaaaaay high , undid the top t-stat housing bolt and filled the system up until it was leaking out of the tstat housing. At this point i tightened the t-stat housing down and filled the system the rest of the way, lowered the car in stages, continuously making sure the system is full... I havent given it a proper beating since but I have had it around the block a few times and did a few WOT launches and everything seems to be OK but some track time would be the ultimate test. Got some pretty serious looks from people... maybe b/c the rear hatch is still raw fiberglass and I had no hood They were probably thinking "look at this ricer idiot...o well.
Old Mar 29, 2016 | 01:35 PM
  #246
rustyschopshop
lol, I definitely wouldn't put you in a ricer class... hahahah.
When are you planning on finishing your rear hatch? I definitely would like to see the finished product on it. Also when you get around to doing your column please post up some pics. Would like to see how it looks.
Old Mar 29, 2016 | 02:11 PM
  #247
Dblock55's Avatar
Dblock55
The hatch is primed, just need to put the wrap i bought for it. It should have been done long ago but i keep gettting side tracked, i will definitely post up some pics when its done and ill be sure to weigh it too.
Old Mar 29, 2016 | 02:58 PM
  #248
90nissanS13
Ha, good to hear on the cooling issues. I couldn't recall your solution so I thought it would be a good idea to include the tread I came across.
Sadly, most people don't understand the difference between a Race-car and a Rice-car.
Old Mar 29, 2016 | 02:59 PM
  #249
90nissanS13
Be sure to include your steering column and hatch on my thread for fab,welding and etc. I'd love to keep that one going and get other people involved.
Old Mar 29, 2016 | 05:26 PM
  #250
Dblock55's Avatar
Dblock55
Will do!!
Old Mar 31, 2016 | 01:05 PM
  #251
90nissanS13
For those of you who haven't visited my thread...Come and share.
https://my350z.com/forum/the-lounge-...and-so-on.html
Old Mar 31, 2016 | 03:24 PM
  #252
Dblock55's Avatar
Dblock55
^^^^ DO IT!!! Good thread, plus he's a nice guy
Old Mar 31, 2016 | 06:17 PM
  #253
90nissanS13
Haha, thanks man! I may have some Ak-47 parts to share soon. I've been working on some new components for improve ergonomics. It may be a future 3Gun completion rifle. Well see, I need to focus on one project at a time!
Old Apr 1, 2016 | 06:15 AM
  #254
Dblock55's Avatar
Dblock55
Story of my life... if I were a kid now, I'd surely be diagnosed with A.D.D. lol. I blame my wife for a lot of the distractions.
Old Apr 1, 2016 | 12:45 PM
  #255
90nissanS13
We'll see***
LOL
Ut Oh, I'm newly engaged. I better get my projects sorted out now.
Old Apr 3, 2016 | 01:44 PM
  #256
Dblock55's Avatar
Dblock55
So finally got back to working on the car, pulled the dash bar, steering column and wire harness out. Got to weigh a few parts while i was at it. So:
- OEM rear hatch without glass is ---------->50lbs
- My fiberglass hatch with lexan window --> 15.5lbs
- Dash bar -----------------------------------> 8lbs (not as much as I hoped)
- Upper part of steering column ------------> 10lbs
- Gutted doors --------------------------------> 36lbs each
Definitely going to back some fiberglass doors once im done with the cage... there is probably 50lbs to be saved there.
http://i1081.photobucket.com/albums/...psas8dbtgn.jpg
http://i1081.photobucket.com/albums/...ps6e6b0cne.jpg
http://i1081.photobucket.com/albums/...psyowmlbwt.jpg
Old Apr 4, 2016 | 12:33 PM
  #257
90nissanS13
The harness was so dang heavy in my 240sx. Its pretty amazing how all that copper and rubber adds up.
Old Apr 5, 2016 | 05:29 AM
  #258
Dblock55's Avatar
Dblock55
I feel like this is a commonly overlooked area for weight savings... if you gut a car there is a ton unused wiring thats just dead weight... the Z doesnt have an extremely extensive harness but when I worked at nissan and had to do a Frankenstein harness for durability testing on a dyno the CVT/engine harness alone would weigh 10+ lbs.
Old Apr 6, 2016 | 02:37 PM
  #259
90nissanS13
That's so true. Northrop Grumman actually conceptualized using conductive structural components to relay signals across the airframe, rather than wires. A weight saver for aircraft that could be in the auto industry in the future. That's how it usually trends. I.E. carbon fiber
Old Apr 6, 2016 | 05:02 PM
  #260
Dblock55's Avatar
Dblock55
I know it's not much but finally broke ground on the cage. First 2 bends on the main hoop.
