ST/SU Build
Old Dec 25, 2015 | 09:52 AM
  #141
Dblock55's Avatar
Dblock55
That 786lb RF corner weight is not possible unless there has been an error (on a a hill, etc)...
Interesting, I made sure to level all 4 scales before taking measurements... one thing I didn't do was unhook the sways which I know cam effects the reading... as far as drivers weight, the top reading is without me in the car v and lower reading is with me in the car.
Old Dec 25, 2015 | 09:57 AM
  #142
Dblock55's Avatar
Dblock55
Originally Posted by dkmura
Are you corner weighting your Z with a corresponding weight in the driver's seat? Your cross-weights are quite different than mine.
Also, building a NA VQ race engine is quite expensive and complex. Make that a future project and take your time in researching it. Otherwise, spend your budget on getting an UpRev cable with Osiris and Cipher loaded on it.
The rules of st3 allow for a 10/1 weight to power ratio, if I'm not making enough power I'll be uncompetitive.
Old Dec 25, 2015 | 10:37 AM
  #143
90nissanS13's Avatar
90nissanS13
https://my350z.com/forum/autocross-road/603068-valkyrie-350z-st3-conversion-update-seibon-carbon-and-motordyne.html
Here is someone to consult.
Old Dec 25, 2015 | 06:14 PM
  #144
03threefiftyz's Avatar
03threefiftyz
I lied actually....just realized my rf was in the 760 range without me (pre-cage/no splitter)
Old Dec 25, 2015 | 08:06 PM
  #145
Dblock55's Avatar
Dblock55
Do you have a corner weight print out per chance? I'd be interested to see a corner balanced z.
Old Dec 26, 2015 | 04:10 PM
  #146
03threefiftyz
I'm going to update my build thread when the car gets back from the cage shop. I'll get it on the scales again for you.
Old Dec 26, 2015 | 07:36 PM
  #147
Dblock55's Avatar
Dblock55
Sweet looking forward to it... I'll do the same before and after the cage.
Old Dec 29, 2015 | 12:50 PM
  #148
90nissanS13
Have you road tested the hatch yet?
Old Dec 29, 2015 | 06:15 PM
  #149
Dblock55's Avatar
Dblock55
Negatory, in Colorado snowboarding. Need to block off the hole in the head where the coolant lines were before I can drive it.
Old Dec 30, 2015 | 03:51 PM
  #150
90nissanS13
Very well.
I'm enjoying winter in a t-shirt and shorts.
Old Dec 30, 2015 | 07:52 PM
  #151
Dblock55's Avatar
Dblock55
Very well.
Haha
Old Jan 5, 2016 | 03:45 PM
  #152
Dblock55's Avatar
Dblock55
Finally got around to making a blockoff plate for head...
Old Jan 5, 2016 | 03:54 PM
  #153
Dblock55's Avatar
Dblock55
Wad looking to buy the z1 idler pulley delete, saw that it's free when you buy a lightweight crank pulley. Anyone running a lightweight crank pulley? If so any excess vibrations?? I'm hesitant to swap it as is usually designed to country engine resonance.
Old Jan 5, 2016 | 03:57 PM
  #154
90nissanS13
Originally Posted by Dblock55
Finally got around to making a blockoff plate for the head.
Very cool! This was for the bleed lines to the heater, correct?
Old Jan 5, 2016 | 04:15 PM
  #155
Dblock55's Avatar
Dblock55
Yup, the intake manifold and oiler cooler lines came off of there as well.
Old Jan 5, 2016 | 07:26 PM
  #156
rustyschopshop's Avatar
rustyschopshop
Glad you able to get made!! coming along nicely
Old Jan 6, 2016 | 05:35 AM
  #157
Dblock55's Avatar
Dblock55
Anyone chime in on the lw pulley?
Old Jan 6, 2016 | 11:03 AM
  #158
rustyschopshop
I was just looking at your block of plate that you made. One concern that I have over it is that it may be too thin to hold even pressure. You may need to make a thicker plate to not develope a leak over time.
Old Jan 6, 2016 | 11:40 AM
  #159
Dblock55's Avatar
Dblock55
What makes you say that? I used a 1/8" thick piece of aluminum which ive done in the past without issue. Engine coolant pressure really isnt that high, i think we put a pressure transducer into a cylinder head once and it didnt go any higher than 3 bar.
Old Jan 6, 2016 | 12:08 PM
  #160
rustyschopshop
I apologize then, I thought it was sheet metal that you had used. 1/8" plate is plenty thick. Picture was apparently deceiving. How is the rest of the cooling system working out for you?
