How To - Shift knob for 5AT
Old Apr 23, 2006 | 03:43 AM
  #81
evobunny's Avatar
evobunny
ok I just did mines for a 06. here a pic.. man it must have been a lot harder for 06 cause I had some trouble getting the ring back on.. the gap was small and tight and I couldnt put the ring back on good with out triming some stuff off Name:  Picture530.jpg
Old Apr 23, 2006 | 12:11 PM
  #82
sq40's Avatar
sq40
Here are some pictures of how the ring fits in without the console piece;
As you can see there are some wide pieces of plastic that go around the trim ring. The ring only goes on one way, so I put a Small mark at dead center of the ring so I know its exact position to be mounted.
I then removed the bulk of the “Tabs” around the ring, leaving only the places that it snaps in. This also removes the centering “Channels” on either side that makes the ring fit so tight. All of this cut out was needed to accommodate my Momo Boot with the Piping.
I then fit the boot over the entire area; I re-installed the console and then pressed the ring down with a few taps of a rubber mallet.
Attached Thumbnails How To - Shift knob for 5AT-ring-driver.jpg   How To - Shift knob for 5AT-ring-passenger.jpg   How To - Shift knob for 5AT-ring-driv-cut.jpg   How To - Shift knob for 5AT-ring-pass-cut.jpg   How To - Shift knob for 5AT-boot-over-all.jpg
Old Apr 23, 2006 | 12:12 PM
  #83
sq40's Avatar
sq40
Here is the finsihed Product, I choose the Aluminium Version of the **** to compliment my HU and the Silver Piped Momo Boot;
Removing the blue plastic extender makes a huge difference in how the car shifts in Manual Mode, It just a quick flick of the wrist!!
Old Apr 25, 2006 | 04:14 PM
  #84
horse110's Avatar
horse110
are the stock 06 auto ***** almost the same as 04 and 05? and will the 06 stock **** fit on my 03? i have a momo but i want to change it back to stock style later anyone selling them for reasonable price? shoot me a pm please
Old May 9, 2006 | 07:52 PM
  #85
GlacierJ's Avatar
GlacierJ
you can cut the alumium part of the shift stick to lower it even more. I will post some pic of mine later. however, for that you cant use the stock 5AT's center plastic part. so I got a 2mm thick alum strip and made a ring to fit inside to secure the boot. and to secure the stock ring back on without the center plastic part, i used the four metal clips taken off that plastic thing and fit them around the stock ring's inner extened part.
the result is amazing :]
i know this prob wont make sense unless you spend the time to play with it alittle.
Old May 28, 2006 | 03:16 AM
  #86
cdwrit3r's Avatar
cdwrit3r
Anyone knows if Nismo shift boot will fit with this installation??
Old Jun 22, 2006 | 11:55 PM
  #87
airdumbo21's Avatar
airdumbo21
is this process only made for 350z's? do u think there is a way to do this with a g35 by any chance? a while back i was roaming through some forums and because of how the g35's shifter is placed it can not b made into a boot soemthing something. I could be wrong though. Any information would be great!
Old Jun 25, 2006 | 07:53 AM
  #88
sq40's Avatar
sq40
The Momo Boot is extra thick with that Piping and it went on well, so I figure just about any boot should work.
Old Jul 25, 2006 | 09:17 PM
  #89
KhanMan's Avatar
KhanMan
Originally Posted by E K
Very similar. The 2003's have the shift button on the side, the 04+ it's in the front.
Here's mine. I didn't want to really trying make it look like a manual, but just to replace it with what I consider the best looking OEM auto **** out there.
I have a brief DIY somewhere on G35driver. **** and boot from everythingnissan.com, had to call them up. Total cost is about $100.
I want that. Anyone have a link for the diy?
Old Aug 2, 2006 | 05:51 PM
  #90
KhanMan's Avatar
KhanMan
anyone?
Old Aug 3, 2006 | 02:36 PM
  #91
Gralark's Avatar
Gralark
Originally Posted by sluggoZ
After buying the MOMO autoknob on e-bay...I did not like to the way it complimented my interior, ending up selling it in the classifieds and I used my OEM **** which in my opinion compliments the interior color scheme.
Looks good. I'm gonna do my 06 with the original **** and height as well.
Old Oct 31, 2006 | 12:04 AM
  #92
nMugen's Avatar
nMugen
my stupid shift **** isnt fitting right, it came with 3 screws and the **** itself, i have no idea how to secure this thing, it keeps coming instantly loose..
Old Oct 31, 2006 | 04:49 AM
  #93
sq40's Avatar
sq40
There should be a rubber or plastic "ring" that slides over the shaft of the stick and then the **** slides over it. If you dont have one, You can make one out of a plastic collet you can find at lowes or home depot. Look for something (Tube like) that is about 1/2 inch wide and just big enough to slide inside the **** tight. I bought one that was slighty bigger than the inside of the **** and cut a little slit out of the middle so it would fit Ultra tight.
Old Oct 31, 2006 | 09:51 AM
  #94
nMugen's Avatar
nMugen
hmm, ok ill try this thanks a lot man.
Old Nov 1, 2006 | 05:52 PM
  #95
transamnut's Avatar
transamnut
Watch how you phrase "I like how your **** sits"
Old Dec 5, 2006 | 10:26 AM
  #96
R0ME0's Avatar
R0ME0
Does anyone happen to know or could get me the inside diameter and outside diameter of that shift ring for me? And lastly is it made of metal or plastic. I am currently working on something custom. This information would be most helpful! Thanks!
Old Dec 5, 2006 | 12:44 PM
  #97
james840a's Avatar
james840a
dont know the diameter, but it is made out of plastic.
Old Dec 5, 2006 | 12:55 PM
  #98
R0ME0's Avatar
R0ME0
If someone could measure this for me I would be most thankful! Thanks!
Old Dec 15, 2006 | 09:29 AM
  #99
driftk1d's Avatar
driftk1d
coud you tell me how to make my boot look like that? mines alllll messed up...i want it to look clean like yous, pics would help
Old Feb 13, 2007 | 10:41 PM
  #100
keosh's Avatar
keosh
If u want a lower budget on this go withe the pilot looks almost exactly the same and only cost me 20.00 bucks at pepboys
