How many HRs for OEM Brembo install
Old Jul 11, 2005 | 01:55 PM
97 grn ss's Avatar
97 grn ss
Default How many HRs for OEM Brembo install
I have a set of oem brembos off a track model. how long would it take to install and bleed the system. Don't want to get scored at the dealer!
Simple bolt on right?
thanks
Jeremy
Old Jul 11, 2005 | 02:00 PM
captj3's Avatar
captj3
it should only take 2hrs.Make sure you have the rear bolts for the caliper the stock ones don't fit diffrent thread.
Old Jul 11, 2005 | 02:14 PM
97 grn ss's Avatar
97 grn ss
i probably need those two bolts for the rear. do you have a part number and do dealers usually have them in stock?
Old Jul 11, 2005 | 02:39 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
2 hrs is about right, bleeding might take another 1/2 to hour though. Make sure you have the Brembo brake lines or SS lines and the rear bolts previously mentioned.
Old Jul 11, 2005 | 02:42 PM
97 grn ss's Avatar
97 grn ss
thanks really appreciate the help. will post pics of the brembos behind CE28N volks after I get the brakes installed
jeremy
Old Jul 15, 2005 | 03:03 PM
isugoo's Avatar
isugoo
i'm going to install brembo tomorrow.
i got off from g35 coupe.
do i need to cut out dust shield or somehting to make it fit?
Old Jul 19, 2005 | 07:44 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yes, you will need to cut the rear shields
Old Jul 19, 2005 | 08:25 AM
isugoo's Avatar
isugoo
Thank you for your info.
Old Jul 28, 2005 | 08:59 AM
sas0's Avatar
sas0
The bolt part number is 08041-2351A and they run around $2.50 each. Performance Nissan has it on their web site here
My bolts got lost in transit and I need a set ASAP. Did you find a dealer that stocked them?
Thanks
