Project Mu Rotor, Stoptech SS Lines, and Nismo Pad Installation.
Old Oct 13, 2007 | 07:56 PM
dothemath's Avatar
dothemath
Default Project Mu Rotor, Stoptech SS Lines, and Nismo Pad Installation.
Ok. It was a long day and I am tired, but I want to share my pictures with the family. I am sure I will need to make changes and deletions or additions to this initial post. So if you have any questions, comments or additional pictures you think would help make the pictorial instruction better...let me know.
And let me say this set up seems to rock after bedding my brakes. My trip to Sebring in November will confirm this I hope...but I am VERY HAPPY at first impression.
Also...use this pictures as a reference, but also read the instructions from the Stoptech site...they are very good.
Jack up the car...duh
Put jack stands under frame rails or at jacking points
Make your friend who is letting you use his garage and helping pose for a picture
Loosen brake hose fitting with 10mm flare wrench
Remove retaining clip with needle nose pliers. After removing retaining clip finish disconnecting the hard line from the oem rubber line. If you are using Stoptech lines they supply you with plugs to put over the hard line to limit/prevent additional dripping out of your brake fluid. This is important since if you do not plug the line eventually your master cylinder will drain out completely...not good.
Remove the 12mm(i think) retaining clips/bolts holding the brake line to the suspension.
Use an ice pic to carefully tap back the retaining pins after pulling out the cotar pins
Use something to press back the pads. Make sure end of brake line is in a pan so when the brake fluid drains out...
Use a breaker bar to remove the 22mm bolts that hold the caliper in place...I am currently not holding a breaker bar.
Remove brake line from caliper and stick them in a box,pan...somewhere. Also go clean and inspect your calipers.
Should have said this sooner, like as soon as the wheel is removed spray PB Blaster around studs and center of old rotor. Now take a rubber mallet and bang around the edge of the rotor and slide the loose rotor off the the studs. Empty hub.
Project Mu Rotor. The slits do not determine the rotation of the rotor. The interior vains do, so read your manual or the marking on the rotor. I know for instance that Stoptechs mounted like this would be backwards which is not good for cooling.
Install caliper...though don't torque the bolts. Though I don't have a picture, you will want to remove the top retaining bolt and rotate caliper into a vertical direction when you bleed the front brakes. It made a big difference...and tap the caliper with a rubber mallet to dislodge air bubbles too.
Install SS brake lines using 9-12 ft/lbs of torque for banjo nut...or what ever your supplier/parts requires.
Attach clip to upright and route the lines back and around suspension and reconnect with body hard line with flare wrench. Reinstall retaining clip.
Install pads...using anti squeel compound. I used CRC Disc Brake Quiet I bought a local auto parts stors. These are the oem shims I am re-using. These are old pictures from a previous pictorial I made.
hooo...ahhh
Move to the rears. You will need to bang on the back rotors more than the fronts to knock them loose. Of course, they will never come loose if your parking brake is applied/on/in use...whatever. Make sure that you remove the rubber emergency brake adjuster hole plug from old rear rotor and install on new rear rotor. I did not take a picture of this.
Ok. There are a lot less pictures for the rear...but hopefully you are getting the idea. The mounting bolts for the rear calipers are torqued to about 60ft/lbs and the fronts will be torqued to about 100ft/lbs when you do torque them. You and a friend will be bleeding the rears first, then the fronts with top rotor mounting bolt out so you can hold the caliper nearly vertical while doing the initial bleeding. Watch the level in the resevoir OFTEN! Also, G35's and 350z's with VDC will need to have the negative battery terminal disconnected. Make sure your windows are down before doing this since they drop raise a half inch as you open and close the door. After you think you are satisfied torque down the front caliper mounting bolts. Put on the wheels and drive around gingerly and then throw in a few hard stops. I then returned to the garage with the car and bled the brakes again...and then again just being **** about it. You are also trying to flush out as much of the old brake fluid from the system as you can. We pumped 2 and half bottles of Motul RBF600 dot 4 fluids through the system during the multiple bleeds.
Old Oct 13, 2007 | 11:28 PM
terrasmak's Avatar
Just make sure you mount the rotors on the proper sides , unlike what is shown here.
Old Oct 14, 2007 | 03:20 AM
dothemath's Avatar
dothemath
My rotors are not installed on the wrong side. The slits are however different than those on the Stoptech rotors.
Here is the stamping on the left rotor and top view.
Please refer to the manuals that you recieve with your hardware to determine proper installation.
Old Oct 14, 2007 | 07:59 AM
taurran's Avatar
taurran
Nice rotors
Old Oct 14, 2007 | 10:29 AM
dothemath's Avatar
dothemath
Originally Posted by taurran
Nice rotors
Thanks. Here are pictures with the wheels installed.
Old Oct 14, 2007 | 01:31 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Awesome! Didn't I tell you this setup would feel good? How is it feeling so far?
Old Oct 14, 2007 | 01:49 PM
dothemath's Avatar
dothemath
OHH MYYYY GAWWWD!!! I could not believe what a difference there was. The car stops NOW! The cold initial bite feels similar ot the way it did with the OEM brembo pads when the car was new four years ago...only I don't have to press the brake as far down. I learned how to heel toe in this car and during street driving a normal stop would put the brake pedal and gas pedal on the same plane. If I press the brake pedal that much now it is almost like an emergency stop! So heel toeing will be a bit more difficult on the street at normal speeds but should be much easier on the track. During my previous Sebring days the brake pedal would be below the gas pedal which was a little annoying. I am anticipating much later braking into the corners compare to my stock rotors with the Hawk HPS.
For anyone else reading...I know the HPS pads are for the street but were sufficient for my novice status and slow learning curve at Sebring since I only go every six months. The last time I went it was obvious with my increased confidence they were very inadequate.
Thank you Andi and Eddie again for all the time you spent answering my questions and the great service.
Old Oct 14, 2007 | 01:55 PM
Andy@Performance
Performance Nissan
Originally Posted by dothemath
OHH MYYYY GAWWWD!!! I could not believe what a difference there was. The car stops NOW! The cold initial bite feels similar ot the way it did with the OEM brembo pads when the car was new four years ago...only I don't have to press the brake as far down. I learned how to heel toe in this car and during street driving a normal stop would put the brake peddle and gas peddle on the same plane. If I press the brake peddle that much now it is like an emergency stop! So heel toeing will be a bit more difficult on the street at normal speeds but should be much easier on the track. During my previous Sebring days the brake peddle would be below the gas peddle which was a little annoying. I am anticipating much later braking into the corners compare to my stock rotors with the Hawk HPS.
Old Oct 15, 2007 | 04:12 AM
asianracerchick's Avatar
asianracerchick
good write up!
Old Oct 22, 2007 | 05:09 PM
dothemath's Avatar
dothemath
Originally Posted by asianracerchick
good write up!
Thank you.
Should I post this in the DIY Forum or is that not a good idea since it is basically the same as SugarspunZ's post and Michla22's posts? I don't post often as you can by my post count...this was just a big deal for me and I learned a lot Yeah...Yeah...it is not like an engine rebuild or anything
Old Oct 22, 2007 | 05:55 PM
Ruthless18x's Avatar
Ruthless18x
Very good write up! I'll use this to do mine.
Old Oct 23, 2007 | 08:08 AM
MethodRN's Avatar
MethodRN
For Sale
I'm gonna have to agree w/ OP. Here's my brakes, same rotors.
Great write up.
Old Oct 23, 2007 | 08:50 AM
sofa king's Avatar
sofa king
^ you mean, write.
how long did it take to do all 4?
Old Oct 23, 2007 | 11:50 AM
dothemath's Avatar
dothemath
My friend has done brake jobs in the past but not on a G35 coupe. He was also not telling me what to do...it was my project and he was a helper. Steve was just going to let me know if I was going to make a mistake or guide me if needed. That being said you can consider me doing this project at a noob's pace, reading directions, and I was also cleaning everything as much as possible before putting everything together. The install of the parts was probably about 6 hours. The three bleeding sessions...just to be positive the old fluid was flushed and all the bubbles were gone...and clean up brought the total time to 8 hours. I don't think I will start doing this for hire I bled the brakes just enough to move the car around to do the front and then the rears since we needed the ramps to get the jack under the front of the car. The pedal was spungy as I kind of expected so we bled the brakes again after everything was installed. After bedding the brakes in and getting the ABS to engage we bled the brakes a third time to finish flushing the system.
Thanks MethodRN and ahhh your brakes are sick!!!
Old Oct 23, 2007 | 11:54 AM
dothemath's Avatar
dothemath
Originally Posted by sofa king
^ you mean, write.
Hey...don't rag on his spelling too much. You can tell from my quoted post above that apparently this math teacher had a brain fade and couldn't spell peddle...I mean pedal I fixed it, but it did not change in the quoted response.
Old Oct 24, 2007 | 02:03 PM
Art Vandaleigh's Avatar
Art Vandaleigh
Nice setup. Let us know how this holds up at the track... i just did a track weekend at mid-ohio with brembo's and Endless SSS pads, held up good. I may consider these rotors next year.
Old Nov 14, 2007 | 04:59 PM
dothemath's Avatar
dothemath
If you look closely you can see the slots in the rotors...cool Photos by Colour Tech South Motorsports Photography.
But I give fair warning...new and improved brakes may cause an inflated level of confidence and oversteer!!!
HAAA....Anyway...The car was fine and only mildly wet my pants. Just kidding...I $h1t myself...no really...I was fine...I am still recovering...
The day was an absolute blast. The new brakes felt AWESOME. The initial bite was incredible compared to my old set up...which as stated before was only Hawk HPS pads and rubber lines so there should have been a big difference. I was able to brake later and harder with confidence. I still noticed a little fade, but it took longer to show up and was not as dramatic as with the HPS pads. I am not one to push my brakes after noticing any fade so I won't ever be the person saying I burned a set of pads in just one day. I am also still in the early stages of doing track days as this was my fifth event in 2.5 years. All this being said, any fade I did experience eased by just taking a couple of corners easy or a slow trip through the pits and heading back out. Recovery time was much less than what I ever previously experienced. My last session of the day was 45 minutes with just me in the car...my friend/passenger was just watching...and I never felt uncomfortable about the condition of my brakes. The track was pretty clear and I felt was pushing the car pretty good. These Nismo pads are still no dedicated track only pad I am sure, but I have a good amount of front pad left without any noticable pad deposit on the rotors. I did observe pad deposit on my original Brembo rotors with the HPS pads...though it never turned into the throbbing pedal "warped" rotor situation. I hope my rambling here makes some sense and answers your questions. I am happy with my new setup and would definitely do another track day with the Nismo pads. I am very happy with the rotors and ss lines.
Old Jan 16, 2008 | 09:02 AM
dothemath's Avatar
dothemath
I am still tempted to copy this pictorial in the DIY section but there are already two brake threads there. I can't believe my unintentional drifting pictures did not elicit any responses! Anyway, my brakes are doing great. They did great at the track. Cold initial bite is still good even after the track day and there is no pulsation in the pedal, no squealing... nothing but strong braking. The brakes are easy to modulate and the brake pedal travel is less than what I remembered before doing the upgrade. After installing the HPS pads during my last brake maintenance I wish I had stayed with the OEM pads. This time there is absolutely no regrets.
Oh yes...and since the Project Mu rotors are basically black chromed or whatever that treatment is called and the rears are painted in the center there is no rust forming on the rotors outside of the contact surface.
Old Jan 16, 2008 | 03:17 PM
gothchick's Avatar
gothchick
Putting this in the DIY would be a big help to everyone. Great job on your install!
Old Jan 17, 2008 | 06:52 PM
asianracerchick
nice write up and nice rotors
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
samansharif
Sep 25, 2015 12:31 PM
