developing camber and traction rods for rear, any interest?
Old Nov 20, 2003 | 09:05 AM
  #121
bosotheclown2002's Avatar
bosotheclown2002
Just keep us update-to-date since the silence is a killer.
Old Nov 29, 2003 | 10:24 PM
  #122
AmyCroft's Avatar
AmyCroft
Smile Is this correct?
Hi
Ordered a set of camber rod's only... as the 350Z I have has just Eibach Pro Springs.
Or should I have got the traction rod's also?
I need the Camber rod's quick as I will have NNA replace the front tires, and don't want the rear to be out of spec.
Of course the issue is the Bounce problem, and the Front "Eating" exspensive tires in 9,000 miles due to a Caster design flaw in the Nissan Multi-Link front suspension.
Cheers Amy -
Old Nov 30, 2003 | 08:05 AM
  #123
uro279's Avatar
uro279
what are traction rods?
also, what do you mean about caster design flaw? my caster is slightly off so i'm interested.
thanx
Old Nov 30, 2003 | 08:37 AM
  #124
bkchang79's Avatar
bkchang79
I have a G35 coupe and cannot get my rear camber back to specs with the camber rods. The best I can do without affecting the toe is 2.0. I went to Darin who works at west end alignment in gardena. Darin mentioned that the infiniti needs a adjustable bushing near the spring pocket. I still don't get the theory on how it would solve it, but that's what he told me.
Old Nov 30, 2003 | 03:06 PM
  #125
N74DV's Avatar
N74DV
here ya go folks.....
https://my350z.com/forum/showthread....threadid=50072
it's what I did to fix the toe problems you get when youre lowered and are using camber arms to get camber back into spec.
I did the mod on mine and my camber is perfect and so is the toe.... and I'm dropped about 2" in rear.
Old Nov 30, 2003 | 07:23 PM
  #126
lsdunique's Avatar
lsdunique
It is true that when lowered 2"+ that bringing the camber back to spec means the toe can't brought back even with our traction rods.
Our Z is lowered about 2.5" and we couldn't bring it back to spec.
So I did your fix with the dremel!!!
It worked great, so I wanted to say thank you!!! because now we can save our rear tires.
The fix works great.
Old Dec 2, 2003 | 04:33 PM
  #127
neur0sis's Avatar
neur0sis
lsdunique: your PM box is full! :-)
Old Dec 2, 2003 | 05:04 PM
  #128
lsdunique's Avatar
lsdunique
sorry about that, I just cleared up some room.
Hopefully I will have some pics of the front arms for you on Friday.
Old Dec 10, 2003 | 08:35 AM
  #129
bosotheclown2002
Which "Friday"?
Will you please commit to a specific date so we know whether to continue waiting on you to deliver?
Old Jan 2, 2004 | 11:26 AM
  #130
Phatmitzu's Avatar
Phatmitzu
patience people, patience.
Old Jan 3, 2004 | 07:35 PM
  #131
AmyCroft's Avatar
AmyCroft
Smile Camber adjust only
Here is the link for the Front Upper Control Arms
https://my350z.com/forum/showthread....threadid=54641
Cheers Amy -
Old Jan 3, 2004 | 07:40 PM
  #132
EnthuZ's Avatar
EnthuZ
Ummmmmm, Amy, your link takes us to BJ's arms(which are VERY nice). I think this post is looking for lsdunique's arms. And so am I.
Old Jan 3, 2004 | 07:52 PM
  #133
AmyCroft's Avatar
AmyCroft
Smile Opps - Darn
EnthuZ: All:
Sorry, thought this was BJ's link..
Old Jan 5, 2004 | 09:09 AM
  #134
Alberto's Avatar
Alberto
Cranky FI Owner
I am lowered about 1.5-1.75" with my JIC's. If I buy both the camber and traction rods will I be able to adjust toe back in or do I still have to performs N74DV's toe mod? If so then why spend $$$ on the traction bars, what do they really do for you? Can people with them post your feelings on them, thanks. I am looking to order at least camber arms early next week.
Old Jan 5, 2004 | 09:47 AM
  #135
N74DV's Avatar
N74DV
the traction bars are merely eye candy. If I were you I would purchase only the camber rod. You WILL need to do the toe mod even if you bought traction bars (like I did).
If you were to go with coilovers JIC makes a camber rod that would work in conjunction with the LSD camber rod. The JIC rod basically replaces the stock spring cup arm.
aboodi
Oct 28, 2015 02:07 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
pr_350z
Oct 1, 2015 05:03 PM
