StopTech ST-40 Pad Replacement
Old Jan 1, 2009 | 12:55 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Question StopTech ST-40 Pad Replacement
I'm kinda tossed up between the Axxis ULT & the PFC1038. The Ult seem like a good pad for the price but seem to wear pretty quickly & are a bit noisey under light braking. However the PFC are more expensive but I won't have to worry of swapping pads when I see the track.
Do any other ST-40/45/60 owners have any other suggestion or opinions on these pads. I need something for mainly daily use with little/no dust and/or noise.
THANKS!
Old Jan 1, 2009 | 01:02 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I'm running the Axxis pads now, I haven't tried anything else yet. Mine don't make any noise
Old Jan 1, 2009 | 03:48 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well your's might still have plenty of pad left. I think mine are getting pretty low.
Anyone else that has tried different pads?
Old Jan 1, 2009 | 04:35 PM
Chebosto's Avatar
Chebosto
i had axxis ULTs before on the ST-40s, they were great cold stop, but high dust... swapped to the ST-60s and went to hawk ceramics-- crappy cold stop, low dust. me no likes... i'd rather have the better stopping than the dusting... but if you're ok with the little dust, then try that-
for the track i'm using Hawk DTC-70.. great pad.
Old Jan 2, 2009 | 05:37 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
when you say "Crappy cold stop." Are you saying this cause they are noisey or cause you need to give extra braking distance?
Old Jan 3, 2009 | 07:44 PM
Chebosto's Avatar
Chebosto
ok. well maybe "Crappy Cold Stop" isnt the best descriptive verbage..
when compared to the Axxis pads, the Hawk Ceramics did not have the same 'cold stop' bite that i was used to, i.e. hit the brake pedal and immediately slow down (that grabby touchy feeling). for the Ceramics.. it was hit the brake pedal, and it slowed down eventually just not-as-fast. i made sure it was not air in the lines (used a power bleeder), and i properly bedded in the brake pads per stoptech instructions.
i have a set of Ferodo DS2500 that Howard@Stoptech recommended that im going to try next...
on another note, also i had great experience with the Pagid Oranges on the ST-40s, but those were at the track...
Old Jan 6, 2009 | 07:16 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks for the info!
Old Feb 12, 2009 | 07:45 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well I bit the bullet and gonna give the PFC1038 a try on the front with the Ultimates on the back.
Old Feb 20, 2009 | 06:29 PM
ADMAN's Avatar
ADMAN
I run HPS for DD. Quick swap for StopTech BBK at track when changing tires.
Old Feb 21, 2009 | 12:53 AM
drsifu's Avatar
drsifu
+1 on the Ferodo DS2500
Old Feb 21, 2009 | 07:08 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Just dropped in and bedded in the PFC1038. Give me a week or so to drive around town and hwy driving to give a review. BTW: PLENTLY of pad left on the Axxis Ultimates. But damn they are noisey.
Old Mar 8, 2009 | 01:15 PM
Konvict's Avatar
Konvict
what pads are you guys using for the ST-45 on the rear?
Old Mar 8, 2009 | 09:49 PM
QuicksilverZ33's Avatar
QuicksilverZ33
I used HP+ on the track for the ST40's but they had plenty of dust and noise...Swapped in some axxis ult's for the winter and they have a little less dust and no noise at all...
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
