Brembo Swap Offset Changed?
Old Feb 6, 2009 | 11:23 PM
350Z_NOW's Avatar
350Z_NOW
Default Brembo Swap Offset Changed?
I'm curious if swapping the OEM Brembo calipers changes the offset of the non-Brembo 350Z
Old Feb 6, 2009 | 11:33 PM
aloh's Avatar
aloh
What do you mean...
By swapping to the OEM brembo setup (which have larger calipers), wheels will need a certain offset to clear them.
Old Feb 7, 2009 | 12:03 AM
350Z_NOW's Avatar
350Z_NOW
I mean the original offset of the car, not the calipers. Like if I do the Brembo swap, will my wheels stick out a bit more after the swap?
Old Feb 7, 2009 | 01:39 AM
Lone_Wolf's Avatar
Lone_Wolf
Old Feb 7, 2009 | 03:49 AM
chopperman's Avatar
chopperman
Originally Posted by IP350GT
haha that was the same thing I was saying
Old Feb 7, 2009 | 04:39 AM
Phreakdout's Avatar
Phreakdout
Think about this one for a second. The calipers and the wheels shouldn't touch each other. So the Brembos don't change the offset.
On the other hand, the Brembo caliper is larger than the base brakes. You need to make sure the new calipers clear the inside of the wheels. Depending on what wheels you have now, you may have to move to a larger diameter wheel or add a spacer to clear between the wheel spokes and the side of the caliper.
I believe there is a DIY thread on changing to the Brembos. Check that out for details.
Old Feb 7, 2009 | 06:44 AM
Wheel offset is wheel offset. It doesn't change.
Old Feb 7, 2009 | 08:40 AM
track1z's Avatar
track1z
Default I say for now on all these people should get is the following
Old Feb 7, 2009 | 10:25 AM
350Z_NOW's Avatar
350Z_NOW
For those people that was not applying help and did this... it's better if you don't reply to this thread, it only does one thing to me which is... annoying does it not? like a dog....
Old Feb 7, 2009 | 10:28 AM
0jiggy0's Avatar
0jiggy0
ITs because your asking a question like. If I put Mobil 1 in my car, will my antifreeze get hotter. Neither apply to eachother.
Old Feb 7, 2009 | 10:29 AM
350Z_NOW's Avatar
350Z_NOW
I simply meant if the brembo rotors are larger in diameter, thickness. I'm curious if it's width where the bolt pattern is could affect the offset of the wheels, I didn't ask about clearing the caliper.
For instance: If the rotors (hypothetically) are 3mm outer than the regular rotors, and my wheels are +19, It would make the wheels stick out 3mm outer which will make it look +16 for the wheels .... because of the rotors
Do you get my question now?
Old Feb 7, 2009 | 10:44 AM
aloh's Avatar
aloh
The rotors dont physically take up space on the hub bolts, the rotors hat does.
Old Feb 7, 2009 | 07:30 PM
I get it. Does the thickness of the rotor effect the position of the wheel? No. The wheel sits on the rotor hat not the rotor surface.
Old Feb 8, 2009 | 12:06 AM
350Z_NOW's Avatar
350Z_NOW
davidv thank you, you got it.
Old Feb 8, 2009 | 12:22 PM
Lone_Wolf's Avatar
Lone_Wolf
Buhahahahahahahahahahahahahahahahahahahahahahahahahahah!!!!
Old Feb 8, 2009 | 07:38 PM
350Z_NOW's Avatar
350Z_NOW
IP350GT how old are you? and why is your car A/T ? .............. before you laugh, check yourself
lapham3
Oct 7, 2022 03:15 PM
