2 front left Brembos
Old Jun 2, 2009 | 08:29 PM
Wonunder's Avatar
Wonunder
Default 2 front left Brembos
I have two front left Brembos. Is there any issues with mounting one of them upside down on the right side? I know there might be an issue with bleeding them, but any suggestions?
Old Jun 2, 2009 | 09:45 PM
piyushh's Avatar
piyushh
wtf!!
Old Jun 2, 2009 | 10:07 PM
Kwame's Avatar
Kwame
But alas that IS the issue. Physics is a **** my friend. Air rises and fluid sinks, hence a bleeder screw/cap at the bottom of the caliper will make it impossible to get ALL of the air out of your brake system. It's no fun when you go to press down on your brake pedal and the pedal falls to the floor.
Edit: Oh and I am almost positive that you will have to create some sort of adaptor to be able to mount the caliper meant for the left spindle on to the right spindle as I'm pretty sure the rotor offset will be off.
Old Jun 2, 2009 | 11:18 PM
terrasmak's Avatar
is it a staggered piston setup like others , if so , you can't run one upsidedown
Old Jun 3, 2009 | 04:30 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Old Jun 3, 2009 | 09:07 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
Unpossible, wont be able to bleed it properly and the differential piston bores will cause excessive pad taper wear on the right hand side
Old Jun 3, 2009 | 09:33 AM
intoZsunset's Avatar
intoZsunset
Do you really want to cheap out on something as crucial as brakes? Just buy the right Brembo and call it a day.
Old Jun 3, 2009 | 09:53 AM
Hexxus's Avatar
Hexxus
I cannot believe this question has been asked.
Old Jun 3, 2009 | 10:55 AM
IIQuickSilverII's Avatar
IIQuickSilverII
blah blah blah
Obadabot
Jun 18, 2023 11:31 PM
Pleask
Dec 21, 2021 03:17 PM
