**Steering knuckle ball joints??**
Old Nov 24, 2011 | 04:58 AM
  #161
SA Z-boi's Avatar
SA Z-boi
So did we every find out what the best replacement boot would be for these ball joints. I just got mine in and would rather replace the boots before installing. also for those that removed the entire knuckle, how difficult was this
Old Nov 24, 2011 | 09:28 AM
  #162
terrasmak's Avatar
Not hard at all, about 15 minutes worth of work.
Old Dec 9, 2011 | 10:22 AM
  #163
SA Z-boi's Avatar
SA Z-boi
Just installed my new ball joints. Be careful when putting them in bc I broke two of them. I also went with new ball joint boots which fit perfect. They were the 13009 from energy suspension. I will post pics later
Old Dec 13, 2011 | 07:13 PM
  #164
ian99rt's Avatar
ian99rt
I'm thinking of ordering one of the ebay joints as well as the Megan Roll Center ball joints to have a real comparison.
Hopefully the Megans do what they advertise and move the joint pivot lower.
Old Feb 11, 2012 | 09:28 PM
  #165
xman2yman's Avatar
xman2yman
Any updates to this?
Old Feb 11, 2012 | 11:08 PM
  #166
G35_FTMFW's Avatar
G35_FTMFW
Its incredible that no reputable company sells this for an affordable price. Amazing!
Old Feb 12, 2012 | 08:06 AM
  #167
xman2yman's Avatar
xman2yman
Yeah i haven't looked at mine, its too cold outside, butI am sure i will need to replace mine and thought might be a good idea while i am installing the coil overs.
Old Feb 13, 2012 | 09:34 PM
  #168
latin_racer's Avatar
latin_racer
How hard is it to install the boot vs buying the ebay Lower Ball Joint set?
Can you link me to the energy suspension site with part 13009. Did a search and it didn't find it. thanks!
Old Feb 14, 2012 | 04:37 PM
  #169
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
There's no "installing" the boot. You just slide that over the knuckle and get it to fit over/around the raised lip.
Old Feb 28, 2012 | 08:34 AM
  #170
latin_racer
Sounds like easier soluton vs installing a lower ball joint. Can anyone point me in the right direction to buy the correct boot? Also did anyone regrease?
Old Feb 28, 2012 | 09:54 AM
  #171
3hree5ive0ero
Retired Admin
^ One reason I'd actually the ball joint is that when you get to the ball joint, you'll see that the years of driving has actually changed the shape/orientation of the joint. Mine, for example, was no longer pointing upright but at an angle "naturally" from the weight of the car pressing on it for years.
Old Feb 28, 2012 | 10:51 AM
  #172
latin_racer
Looks like i'll take your advice as I'm sure the condition might not be good. Better to play it safe. Did you buy the Ebay Set? Any pointers or advice?
Old Feb 28, 2012 | 03:55 PM
  #173
3hree5ive0ero
Retired Admin
eBay is where I got mine and no problems so far on the streets, track, snow/ice, etc.
Old Mar 11, 2012 | 12:52 AM
  #174
350Zdj's Avatar
350Zdj
+1 on this.
My Ebay is still holding up as well. 1.xx year and about 15k miles.
Old Mar 11, 2012 | 07:30 AM
  #175
blAk mAx's Avatar
blAk mAx
Doo it
Old Mar 21, 2012 | 04:11 PM
  #176
Supreme_june22's Avatar
Supreme_june22
About those Moonface joints...
I'm looking to get them but I've heard that they only REALLY benefit those who have lowered their car 30mm or more but I'm NOT looking to lower my car too much as I need the ground clearance for a bit of daily driving and just want a more durable ball joint than stock.
FYI, I'm looking at getting Buddy Club Racing Spec coilovers so that'd drop my car a bit, along with the camber, toe arms and replacing most of the stock bushings.
Old Mar 21, 2012 | 05:04 PM
  #177
-Trav-'s Avatar
-Trav-
Doesnt the ball joint in the compression arm also need to be replaced to truly adjust roll center?
Old Mar 22, 2012 | 07:49 PM
  #178
AARONHL's Avatar
AARONHL
Ordered the $60 ball joints...not sure if I want to install them or not??? Seems like there is good luck with the Energy boots??
Old Apr 10, 2012 | 06:06 AM
  #179
SexyRob's Avatar
SexyRob
The moonface kit includes parts to adjust the compression rod geometry as well.
Old Apr 14, 2012 | 08:45 PM
  #180
AARONHL's Avatar
AARONHL
How does that part of this kit work?
