Dual rear calipers ebrake
Old Jun 11, 2014 | 07:09 AM
  #261
JasonZ-YA's Avatar
JasonZ-YA
^ wait, so what happened exactly....
did you crash into something and go off course or ??? or was this a result of a long hold, ie, long brake??
this hands down looks impact related..?
-J
Old Jun 11, 2014 | 07:41 AM
  #262
Skyfer_lt's Avatar
Skyfer_lt
-J
Ran too wide in a closed road course. No handbrake was use before, during the impact with the curb. However, I do have a feeling that the knukcle broke first due previous curb related impacts that include two broken track v.1 wheels lol
Old Jun 11, 2014 | 08:24 AM
  #263
JasonZ-YA's Avatar
JasonZ-YA
^ ok great ya......impact crash, all bets are off, damage is damage, none of which is a result of caliper bracket addition to the car.
See, i did a lot of calculations on the added load and stress that a bracket of your type (ie, your type is how it should be designed, not like some on here with spacers under the rotor hat) would input to the knuckle and found them all to be negligible......
glad to see the caliper held up, that's simply due to the material (steel) you built it from. it would be the stronger part in the stack up of 5000 series aluminum knuckle is made from...
-J
Old Jun 11, 2014 | 10:10 AM
  #264
VO...'s Avatar
VO...
Administrator
Impressive work and thread...
Old Sep 15, 2014 | 11:54 PM
  #265
stevo_d's Avatar
stevo_d
Can anyone Confirm the Maverick kit does or doesn't allow you to retain use of OEM Drum cable brakes, As in the UK for our Annual Vehicle inspection (MOT) We have to have a working Cable brake, Cheers
Old Sep 17, 2014 | 05:59 PM
  #266
350zjason350z's Avatar
350zjason350z
Know it all
It doesn't I emailed them awhile back asking same question.
Old Sep 23, 2014 | 02:02 AM
  #267
nismofreak1208's Avatar
nismofreak1208
Anyone willing to make dual caliper brackets that still retain the OEM brakes? I'm not confident enough to trust the shops here to fab one up. So I'm willing to pay so I can finally Mount my spare brembos
Old Sep 23, 2014 | 03:20 AM
  #268
Skyfer_lt's Avatar
Skyfer_lt
PM replied.
Old Oct 31, 2014 | 08:54 AM
  #269
OhioStyles's Avatar
OhioStyles
Originally Posted by Skyfer_lt
PM replied.
hey Skyfer, im interested as well. idk what breakthroughs happened since i last checked this thread but last i checked, both patinka and maverick kits lost the oem ebrake. pm me
Old Oct 31, 2014 | 11:34 AM
  #270
VO...'s Avatar
VO...
Administrator
Last weekend had a chance to test the strength of my caliper bracket.
Broke the cv joint on the axle, bent the camber arm into a V shape, bent and twisted the traction rod and spring bucket, bent the upper control arm and broke the knuckle. As far as I can tell the bracket is not even bent.
Old Oct 31, 2014 | 01:34 PM
  #271
Skyfer_lt's Avatar
Skyfer_lt
Since a demand is starting to appear, I will try to correct the measurements on the blueprint over the off season or mid-spring so any new caliper brackets would not require any modification for fitment. Also I might part exchange my kit for a Maverick one since I do not need the oem parking brake any more since my car has a full 6 point FIA spec cage and I don't need to pass inspection.
Old Nov 6, 2014 | 08:51 PM
  #272
nismofreak1208
I'm in if you decide to produce some sets that retain the OEM parking brake
Old Nov 7, 2014 | 01:18 PM
  #273
JasonZ-YA's Avatar
JasonZ-YA
edit..
Old Nov 24, 2014 | 06:18 AM
  #274
OhioStyles's Avatar
OhioStyles
any updates? i want to do some rad stuff soon. i got an extra caliper set and i really dont want to buy the maverick kit if theres a chance u could make a kit the keeps the ebrake.
Old Nov 25, 2014 | 05:06 AM
  #275
Skyfer_lt's Avatar
Skyfer_lt
unfortunately no, it's 8 degrees F outside so it is difficult to work on the car. Although I have come up with a better way to measure everything so it will be faster. At this point the question is not if I will make the kit but rather when I will make it. Once I have something, I will post here to let everyone know.
Old Nov 25, 2014 | 09:23 AM
  #276
OhioStyles's Avatar
OhioStyles
thanks for update Skyfer. i forgot about that whole cold weather thing haha. i'll keep myself busy with other stuff until then. please do keep us updated if ur able. dual setup is a must for some of us and waiting in line at grassroots events would be better with the regular ebrake
Old Nov 25, 2014 | 10:21 PM
  #277
nismofreak1208
Sounds good, as long as it retains the OEM parking brake, i'm happy, this way I can run a dedicated hydro without worrying about abs or anything. And, I can install it into my other Z as well for double fun
Old Feb 10, 2015 | 08:30 AM
  #278
OhioStyles's Avatar
OhioStyles
i went the maverick route. i'll figure out a way to get the parking brake back
Old Feb 10, 2015 | 12:19 PM
  #279
nismofreak1208
Patiently waiting
Old Feb 10, 2015 | 11:27 PM
  #280
JoseValencia27's Avatar
JoseValencia27
What are your brake line set-ups on the hydraulic handebrake. I also want to do something like this but I dont have the Brembo Z. Is it worth getting dual calipers for the Regular Z brakes.
