Dual rear calipers ebrake
Old Nov 23, 2012 | 11:49 AM
  #121
sportbiketed's Avatar
sportbiketed
I am very interested. Do you have an idea on what it will cost?
Old Nov 23, 2012 | 06:55 PM
  #122
Royal_T's Avatar
Royal_T
not more then $350
Old Nov 26, 2012 | 04:24 AM
  #123
SPirtle's Avatar
SPirtle
Lol sign me up for this, hello christmas to myself!
Old Nov 26, 2012 | 10:51 AM
  #124
H22dragster's Avatar
H22dragster
Put me on the list Royal T. I've been impatiently waiting...
Get these things in production so George can get back out there and kill it next season. I'm sure they'll help supplement his tire expenses.
Old Nov 27, 2012 | 07:23 AM
  #125
Royal_T's Avatar
Royal_T
You are on it sir.. And yup a perfect X-Mas gift
Yeah this would help him out a lot for next year.... You are on the list sir
Old Nov 27, 2012 | 08:43 AM
  #126
KingBaby's Avatar
KingBaby
Hardest Setting
So should I start searching for another rear brembo caliper?
I'm in if it stays at that price range!
Old Nov 27, 2012 | 08:59 AM
  #127
Royal_T's Avatar
Royal_T
Yeah it is $350.. and def get another Brembo.. I will run dual Akebono calipers
Let me know if you want to get on the list.. Thanks
Old Nov 27, 2012 | 11:35 AM
  #128
SPirtle's Avatar
SPirtle
The only way I would buy is if the factory e brake was still functional. Once it is, my wallet will be flying open. I messaged george on Zilvia and he said he would be working on making the e brake usable.
Old Nov 27, 2012 | 12:04 PM
  #129
KingBaby's Avatar
KingBaby
Hardest Setting
I'd still run it...just with a few of these in the car
Old Nov 27, 2012 | 12:53 PM
  #130
sportbiketed
You guys realize that you can buy locking hydraulic e-brakes?
Old Nov 28, 2012 | 07:51 AM
  #131
Timmy22's Avatar
Timmy22
Put me in the list!
Old Nov 28, 2012 | 01:04 PM
  #132
Royal_T's Avatar
Royal_T
Yeah we are already working on the option for you guys that want to keep the OEM E-Brake setup.
+1
Hahaha that is funny, or you can keep it in gear
Originally Posted by Timmy22
Put me in the list!
Will do
Old Dec 5, 2012 | 10:04 AM
  #133
A-Town-Z's Avatar
A-Town-Z
Interested... this kit is just brackets and hardware? I plan on running 2 iron calipers for now, so ill need those, plus the lines, and the hydro brake w/reservoir, and fluid of course. Am i missing anything? I've read through like 16 pages of all the Hydro E-brake threads and want to keep my abs. This seems like the best answer.
Old Dec 5, 2012 | 11:05 AM
  #134
JasonZ-YA's Avatar
JasonZ-YA
you will need a metric tee........I took this one from the junk yard off a 240sx, rear passenger side:
0562f264.jpg?t=1275502073
From the hydro-ebrake you can run hardline (M10x1.0 i believe it is) to the tee fitting above-then more hardline to extra brake mounts-Then-use oem or buy ss brake lines and connect the new calipers...
you can get extra brake mounts off a Z or a 240, etc...like these:
These brackets you can simply sheet metal screw them into the wheel well metal. self taping sheet metal screws - drill tiny pilot hole for best grab.
or you can go online and have custom length SS line made with the metric fittings you need. if you did, i would get at least one extra tee to brake caliper length one in-case you cut one with tire belt accidentally..
if you live in a city with a large industrial base, then look up a local hose shop and they can make you the length of hose you need.
I used bailing wire - to pre route my line in pieces, then I tube bent hardline to match my bailing wire routing to route under the car perfectly..without having a hack job of tube bending.
AGAIN - (talking drivers side)The mounting and routing of the lines is another reason i feel the 2nd caliper location should be mounted at the 1 or 2-O'clock position...
Routing the line to a caliper mounted low like the kit being posted 'may' be harder to do...
i mention this in post 105
-J
Attached Thumbnails Dual rear calipers ebrake-brake-line-bracket.jpg   Dual rear calipers ebrake-junk-yard1.jpg   Dual rear calipers ebrake-mount-for-hardline.jpg
Old Dec 5, 2012 | 11:50 AM
  #135
Citrus's Avatar
Citrus
Add me to this list if there's still some spots available.
Old Dec 5, 2012 | 12:15 PM
  #136
Royal_T's Avatar
Royal_T
You would just need to run lines from your new Hydro with its on reservoir to the new calipers.. Don't touch your current OEM Calipers
Old Dec 6, 2012 | 06:25 AM
  #137
350zfun19's Avatar
350zfun19
What makes this bracket $100 more than the 240sx one? It appears to have less material and hardware. Is it because it was harder to make/design?
Old Dec 6, 2012 | 08:09 AM
  #138
Citrus's Avatar
Citrus
Much larger market for 240sx parts most likely. You make something like that for the 240 crowd and it'll sell a **** ton. Develop and make it for the Z33 crowd and it might sell 10-20.
Old Dec 6, 2012 | 08:57 AM
  #139
sportbiketed
^This.
Old Dec 6, 2012 | 05:54 PM
  #140
Royal_T's Avatar
Royal_T
The brackets will cost a bit more than the s-chassis ones because they are more complex and take a lot longer to machine.
