Coil-over Clunk
Old Nov 7, 2011 | 06:49 AM
JCat's Avatar
JCat
Default Coil-over Clunk
I have a Tein Basic setup.
Over hard bumps, I think the upper control arm(s) are hitting something....I get a clunk.
It looks like the fronts may be hitting the inner fender plastic liner.....
Anyone else experience clearance issues and what (if anything) can be done to solve it ?
Old Nov 7, 2011 | 07:01 AM
Junkster's Avatar
Junkster
What are your wheel specs?
I get the same thing on mine but i have 18x10.5 +15 F/R
Def not bottoming out the shocks but i am pretty slammed...i know people lower than me that dont have this issue though...hmmm
Old Nov 7, 2011 | 08:44 AM
SE5spd's Avatar
SE5spd
How low are you?
Old Nov 7, 2011 | 09:26 AM
Czarrr's Avatar
Czarrr
The clunking is from poor quality control arms.
Adam@Z1 and I had a lovely talk about it a week ago.
Lesson learned.
SPC front control arms are booboo
Also OP.
Depending on the clunking, make sure your collars are completely tightened on your coils.
Old Nov 7, 2011 | 09:33 AM
JCat's Avatar
JCat
Lesson learned.
Also OP.
SPC is what I have . Why are they "booboo" ? What is better?
What did Adam say ?
Old Nov 7, 2011 | 09:40 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
It could be a lot of things. Check all of your bushings, and check for wear marks where metal could be contacting. How low are you? Tein Basics don't allow for shock body adjustment so you may be bottoming out your shocks.
Old Nov 7, 2011 | 09:53 AM
JCat's Avatar
JCat
I have had different wheels and diffferent tires over the years, also with different offsets. The clunk is the same.
Since I baby the car as much as possible, I do not get the clunk very often....but I will check for marks and tell-tale signs tonight.
I really suspect the SPC upper controll arms of hitting something. The clearance between them and the fender liner looks tight.
Still wondering if this is a typical problem for 350Z's with the SPC kit and Tein Basic Coil Overs ??
How low is the car ? . . . . rolled fenders are 1/2" above the tires, front and back.
18" x 10.5 295/35/18
18" x 9.0 265/35/18
Offsets avg about 25mm
Old Nov 7, 2011 | 11:15 AM
Czarrr's Avatar
Czarrr
What did Adam say ?
https://my350z.com/forum/brakes-and-...ce-needed.html
fernandito7
May 3, 2011 08:51 AM
SuperRobin
Aug 23, 2004 08:25 AM
Tampa350z
Mar 16, 2004 07:55 AM
Dissolved
Dec 29, 2003 07:01 AM
