Zaino and Hazing/cloudy looking, Need Help!
Old Jul 3, 2005 | 04:23 PM
zand02max's Avatar
zand02max
Default Zaino and Hazing/cloudy looking, Need Help!
Okay heres the deal, Last week I used the Z-PC and orbital and the paint really stood out, and I got rid of most of the scratches/swirls. I was going to finish up this weekend to get the rest of the scratches that I didn't notice last week and do a few more applications of Z-PC. After last weeks application of Z-PC, I re-washed, dried, misted with Z-6, then applied Z-2, and misted with Z-6 in between and topped it off with Z-8. It looked great until I pulled the Z out of the garage and I noticed a lot of cloudy streaks going up and down. You really had to look but you could see them. The Z-6 and buffing would not get them out. I know what your are saying, I am applying Z-2 too thick. Well I really put it on thin and let it sit in my garage for 3 hours, buffed off, Z-6, then applied another coat. Humidity is not an issue because I live in Colorado.
Fast Forward too today. I re-applied Z-PC and it got rid of the cloudy marks and once again my paint looks clean again.
My question is this, how can I get these cloudy streaks to not appear once I apply the Z-2? I also mist my applicator pad with Z-6 to get it moist when applying Z-2. I do apply lightly and buff with a DF Towel and Z-6.
I really don't want to do the ZPC every week or once a month.
Should I apply the Z-2 with the orbital with a white polishing pad?
Old Jul 3, 2005 | 08:22 PM
cpoe52's Avatar
cpoe52
What is Z-PC?
And you are using an orbital speed drill to remove or apply Zaino?
Please clearify.
P.S. If your application is clouding, you are using too much Zaino OR...
it has not dryed.
Z6 (the detail gloss enhancer) will clear the clouding up. It's also helps to have good light. My garage is too dark sometimes, so I pull her half way in.
Old Jul 3, 2005 | 08:51 PM
zand02max's Avatar
zand02max
Originally Posted by cpoe52
What is Z-PC?
Please clearify.
it has not dryed.
I am using the random oribital on the Z-PC only. start out at Speed 2 then work my way up to 4-5. Using an light cut orange pad.
Z-PC is the new paint cleanser/swirl mark remover, works best with an oribital, awesome product.
http://www.zainostore.com/Merchant2/...ory_Code=Zaino
I let it dry for 3 hours, hmmm, not sure. I do the Z6, as well as the Z-8.
Old Jul 4, 2005 | 05:51 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Are you using ZFX with your Z-2? If so, 3 hours is too long. I'd take it off in under an hour. Also, try not to apply it (Z-2 with ZFX) in direct sunlight. It tends to streak a little if you do.
If you are NOT using any ZFX with your Z-2, then you aren't leaving on long enough. I'd go at least 8 to 10 hours without ZFX.
Finally, I tried wetting the applicator with Z-6 at the recommendation of someone else and I got streaks too. I have always just dampened the applicator with a bit of water intead of the Z-6.
Old Jul 4, 2005 | 08:28 AM
zand02max's Avatar
zand02max
No ZFX
I apply in my garage.
I'll take you advice and let it sit overnight,
Also Sal said I need to use a Large Towel, hmmm, I have always used Medium Towels.
Thanks!
Old Jul 4, 2005 | 09:56 AM
kcobean's Avatar
kcobean
Is it safe to repeatedly use the Z-PC? I assumed that was a very mild polish, but as such must have some abrasive quality to it. Will that harm your paint over time if you use it semi-monthly?
Old Jul 4, 2005 | 04:26 PM
zand02max's Avatar
zand02max
Well you guys were right, I did not let it sit long enough.
Here are a few pics, sorry for the mediocre pics!
Old Jul 4, 2005 | 04:27 PM
zand02max's Avatar
zand02max
zand02max's Avatar
zand02max
Old Jul 4, 2005 | 04:29 PM
zand02max's Avatar
zand02max
Oops.
Old Jul 4, 2005 | 04:31 PM
zand02max's Avatar
zand02max
Old Jul 4, 2005 | 04:34 PM
zand02max's Avatar
zand02max
Old Jul 4, 2005 | 05:53 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
HMMMMMMMM, Another happy Zaino Jedi we have found.
Strong with this one the power of Zaino is.
Old Jul 4, 2005 | 06:08 PM
manofsteele2003's Avatar
manofsteele2003
Nice, I'm sill waiting to use my Zaino-PC.
Air Force SP huh? I'm an Air Force Firefighter.
Old Jul 4, 2005 | 07:13 PM
zand02max's Avatar
zand02max
Yep, 3 more and I retire, . Applying for the Corpus Christi, Tx. Police Dept where I am retiring at. Nothing like a young rookie, well 39 year old rookie,
Old Jul 5, 2005 | 07:41 AM
Reggi914's Avatar
Reggi914
looks like you did an awsome job
Old Jul 13, 2005 | 05:14 PM
Edison_Chen's Avatar
Edison_Chen
How come we have to leave the Zaino w/o ZFX on for so long?
Old Jul 13, 2005 | 06:07 PM
DavesZ#3's Avatar
DavesZ#3
ZFX is an accelerator for the Z-2 & Z-5 products. It makes them cure in under an hour instead of 12 hours that it would take without ZFX.
Old Jul 13, 2005 | 06:14 PM
Edison_Chen
I've usually let it dry about.. an hr.. w/o zfx..
and 20-30 mins with ZFX
Old Jul 17, 2005 | 11:24 AM
Kevin V's Avatar
Kevin V
It sounds like you are using WAY too much polish when you apply it. If it is taking over an hour or so to dry, not using ZFX, even on humid days, then start applying less. You should be able to do the entire application with 1/4 ounce, with practice.
mcduck
Cleaning & Detailing
Nov 9, 2002 11:30 PM
MacGuru
Oct 19, 2002 03:04 PM
Dr Bonz
Oct 11, 2002 01:32 PM
z461
Oct 6, 2002 07:33 PM
