washing oem cover?
Old Feb 14, 2007 | 04:22 PM
SoulDesign's Avatar
SoulDesign
Default washing oem cover?
quick question. does anyone know the proper wahing instructions for the z's oem cover? the wind took mind to the ground today and ive lost the original paperwork that came with it. i know its as simple as washing on low or something like that but i was just wanting to make sure. thanx
Old Feb 14, 2007 | 04:34 PM
There are no instructions but...
a. Turn inside-out.
b. Wash in a front loading commercial machine. Warm water.
c. I have tried half dozen detergents. A couple of ounces of Mr. Clean works best.
d. Spin in a commercial dryer for about 10 minutes on medium heat. Remove the cover. It will still be wet.
e. Dry on the car.
f. After drying, spray the top with Scotch Guard.
Old Feb 14, 2007 | 04:37 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
a. Turn inside-out.
e. Dry on the car.
Dang what a PITA
Old Feb 14, 2007 | 08:07 PM
onedirtyz's Avatar
onedirtyz
my car is dirty
damn.. my wolf cover can't be machine washed, according to the instructions. but uh...HAND WASH a fuccin car cover...?!?!
"a simple cleaning method to remove dust, etc, is to hose off the cover while on the car."
UGH.
Old Feb 15, 2007 | 03:55 AM
zdotcom's Avatar
zdotcom
I'd hang it on a clothes line and spray it down with some laundry soap/water mix in a spray bottle then use the hose to wash it off. I then can hang to dry in a couple minutes on the line.
Old Feb 15, 2007 | 09:34 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I wash mine in a regular top loader home machine.
Set it to double rinse, arm and hammer perfume and dye free soap, outside out.
Once done I pull it out, turn it inside out and run washer again with no soap and double rinse.
Throw in dryer.
Chris
Old Feb 15, 2007 | 02:43 PM
HighwaySpeed's Avatar
HighwaySpeed
Talking
a. Turn inside-out.
e. Dry on the car.
g. Wear your favorite apron.
Old Feb 15, 2007 | 02:51 PM
VO...'s Avatar
VO...
Administrator
a. Turn inside-out.
e. Dry on the car.
I like everything except "e.".. I would think the wet cover would cause paint discoloration if left to dry in the sun.
Old Feb 15, 2007 | 03:01 PM
CaliTouring's Avatar
CaliTouring
LMFAO!
Old Mar 25, 2007 | 09:11 PM
Question
So how did the cover turn out?
Old Apr 12, 2007 | 02:22 PM
You are welcome.
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
