OK, did I do something wrong (1st time applying Zaino)
Old Jun 3, 2004 | 08:02 PM
ZDreamZ's Avatar
ZDreamZ
Default OK, did I do something wrong (1st time applying Zaino)
Ok, I put on Zaino for the first time today doing everything in the instructions= Dawn, wash, Clay, Z5 w/ ZFX, buffed off, waited 30 min and applied Z2 w/ ZFX. I wiped everything off and then drove home about 20 miles on the highway. I got to a gas station and saw all this greasy haze on the car that I'm afraid dried to the point that I can't remove it. I sprayed and wiped the whole car with Z6 detailer and it helped a bit but not by much. Should I:
A) Strip the wax and do it again? Hope I don't have to. Or
B) Apply another coat of Z5 tomorrow hoping it will remove the haze on there now?
Please get back since this has me really scared, I don't want my paint to get messed up.
Thanx
Old Jun 3, 2004 | 08:12 PM
350zMon's Avatar
350zMon
i think you didnt take it all off. need to rub a bit harder i believe. i would strip it with dish soap and then re-wax it!
Old Jun 3, 2004 | 09:06 PM
havabooz's Avatar
havabooz
you have a black car so you shoulda caught this problem earlier
its prob just that you didnt let the zaino dry enough before you tried to buff it out
go for the dawn but dont make it a habit
Old Jun 3, 2004 | 09:35 PM
mgk65's Avatar
mgk65
Dawn is not going to do anything for you.
I would suggest trying more application of Z6 and a stronger elbow.
Old Jun 3, 2004 | 09:54 PM
ZDreamZ's Avatar
ZDreamZ
well what do I do? Dawn or more wax?
Old Jun 3, 2004 | 11:52 PM
Kevin Overall's Avatar
Kevin Overall
Dawn does not remove Zaino, Dawn is not needed, sounds like you took the polish off before it was dry, just mist the paint with plain water and buff with your wiping towel or wash the car with Z-7 and it should even out the finish.
Old Jun 4, 2004 | 04:28 AM
KShep's Avatar
KShep
During the summer, or anytime there is high humidity, high dewpoints, the Z5 or Z2 will take longer to cure. If it does not "smear" but breaks clean when you pass your finger through it, it's ready to buff out. I applied Z5 last weekend and had time to mow the lawn and play with the doggie before it fully cured. About 2 hours w/ZFX.
Old Jun 4, 2004 | 07:37 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I agree with what Kevin said above. Also, make sure you are applying the polish VERY thinly. You should be able to do at the entire car once (or even twice) with only one ounce of polish. Spread it on as thin as you can. Your paint color should show through completely and only be slightly blurred by the polish. Zaino isn't applied like wax which goes on all white and swirly.
Old Jun 5, 2004 | 11:32 AM
KShep's Avatar
KShep
Default Edit: 2 Hours?
Well, I got on another layer today. Humidity is still high, but it did not take the Z2 w/zfx 2 hours to cure, even though the car was in my garage. Applied to the whole car and 20 minutes later she was ready to be buffed. Came right off, just like always.
Aplologies for posting from the Dept. of Mis-information.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Obadabot
Jun 18, 2023 11:31 PM
