Drag NHRA, IDRC, IHRA, NDRA
Anyone run 12's yet in 2007 Z?
Old Aug 1, 2007 | 05:21 PM
  #101
Zulu-6's Avatar
Zulu-6
Originally Posted by gabez33
but some of you guys are beginning to think your driving super cars...where all still within that 13sec...get real
Where are you getting that from? We are having a discussion about how to get a 07 to run a 12(high) second 1/4 mile. There are no grand delusions here to what the car is capable of, from what I've seen.
Your attack on Solo was clearly uncalled for. -nevermind, you went ahead and edited it.
Old Aug 6, 2007 | 11:02 AM
  #102
PM-Performance's Avatar
PM-Performance
for a car that runs around 13.3-13.5 stock, 12's wont be much of a problem with stickies and a few boltons.
Get an 07 with radials and exhaust, and maybe headers on a NJ track in October. I bet it will happen.
Old Aug 6, 2007 | 11:06 AM
  #103
Motormouth's Avatar
Motormouth
it doesn't even need headers... anyway I heard they are pretty sweet on the 07s!
Old Aug 6, 2007 | 12:13 PM
  #104
Gooey's Avatar
Gooey
I was at the track this past friday. Very hot humid weather 90degrees 80% humidity. Pulled couple 2.0 60's and 1 1.99 60' with my 19's on
best run of the night was only a 13.601 @ 102
The heat killed the runs
Old Aug 6, 2007 | 12:21 PM
  #105
jdifolco's Avatar
jdifolco
I have been running those same numbers this summer also. The heat and humidity is really bad. I only go to practice my 60' now.
Old Aug 6, 2007 | 12:36 PM
  #106
skaterbasist's Avatar
skaterbasist
Originally Posted by doug
Warren = VeeTec ..
he has broken stock records for Maxima's, Preludes and Z's .. not sure about his vr4 .. he might have.. but the man is amazing at the drag strip
I give VeeTec credit for being an excellent driver. But you also forgot to give credit to a bigger factor... the track itself
I dream of the day we (Californians) get an excellent 1/4 mile track @ low elevation, with a region of colder climates, and better track preparation
Old Aug 7, 2007 | 02:37 PM
  #107
JamRWS6's Avatar
JamRWS6
Originally Posted by VitViper
I could do it here with some more practice, cooler weather, DR's, a prepped track, and the clincher: a clutch that held up to a high rpm launch (mine doesn't ). Ran a 13.7 first time out with a crappy track prep and 2.15 60 ft, with a nice stench of burnt clutch every pass.
Oh well, I'll let VeeTec do it, I couldn't hold out and leave my car stock.
I think the point is a stock car on DRs.....a different clutch...isn't stock.
IMO a stock 350Z on drag radials will never make it into the 12s...the power, suspension geometry, and drivetrain isn't there in a stock Z.
BTW what is the point in beating on a stock car? FI is the way to go with a Z car to make impressive numbers.
Old Aug 8, 2007 | 11:16 AM
  #108
warmmilk's Avatar
warmmilk
nobody specifically said and aftermarket clutch, just one that doens't slip.
some of the 07's clutch have slipping issues, mine doesn't slip, and the clutch is stock
veetec ran a 13.3 on a slipping clutch, which he posted just got repaired at the dealer, apparently it was a slave cylinder issue or something, so we'll see what he runs now
i ran a 13.49 on a 2.1 60ft, i think with drag radials (especially if they are shorter than the stock tires, for shorter gearing) a 1.6-1.7 60ft is possible (not nessisarily with me driving), with that 60ft, a 12 sec run is entirely possible
i'm not gonna say it absolutly will be done, cause till people try, we won't know
just out of curiosity, what was ur best run in ur z06?
Old Aug 10, 2007 | 09:01 AM
  #109
95snoozer's Avatar
95snoozer
Originally Posted by jonb7007
Cmon.. Youd have to have at least 400whp to hit 12's.. Unless your name is Audible Mayhem or Alberto .. lol..
I ran 12.8 at 106.12 with 246 rwhp 3100 raceweight in my stang
there are alot of non posting 12 second bolton cars out there, I gurantee it. I have seen 5-6 different 350zs alone at my track that trap 105-107 with boltons and run 12.9-13.1
Old Aug 10, 2007 | 09:15 AM
  #110
95snoozer's Avatar
95snoozer
Originally Posted by jackie chan
https://my350z.com/forum/new-owners/289864-traded-03-cobra-for-2007-350z-new-owner.html
we in the mustang world thank you for taking this one off our hands
LMAO @ man who ran 12.6 at 116 thinks his Z might go 12.9 with tire and limited boltons.
Old Aug 10, 2007 | 09:25 AM
  #111
rcdash's Avatar
rcdash
why? w/ a 3.9 rear diff, should be very possible. Not that trap speed, but the time should be within reason...
Old Aug 10, 2007 | 12:21 PM
  #112
VitViper's Avatar
VitViper
I took mine into Nissan this morning for the same issue. Everytime I launch the car hard from 3500+ my clutch pedal starts sinking to the ground and the clutch smells like @ss. Replicated it for the dealership over and over again. LoL, almost amusing watching a Nissan tech watch me launch the car hard on the street.
Old Aug 10, 2007 | 01:44 PM
  #113
S8ER95Z's Avatar
S8ER95Z
See thats your problem guys...I launch my car from ~1100rpm and no clutch issues at all.
Old Aug 10, 2007 | 04:13 PM
  #114
VitViper's Avatar
VitViper
Well nissan disagrees since I'm getting a revised slave cylinder and new clutch/flywheel/pressure plate
Old Aug 11, 2007 | 12:05 AM
  #115
warmmilk's Avatar
warmmilk
damn, really? it was that easy? did u tell them u took it to the track? cause my pedal started sinking today at the track after about 4 2.0 60ft's (nothing better than a 13.5x) but on the street its fine so far. one thing that really freaked me out is when i was doing the burn out, the clutch just let go in the middle. the wheels stopped spinning and the clutch just let go, i could feel it slip, like a clutch burn out if u will, not just burning the clutch, but more like spinning it really fast against the flywheel.
anyway, did this problem progressively get worse, or was it always like that from the begining. cause mine was perfect till tonight
Old Aug 11, 2007 | 12:06 AM
  #116
warmmilk's Avatar
warmmilk
not all of us have v8's
(sorry for post whoring)
Old Aug 11, 2007 | 08:34 AM
  #117
VeeTec's Avatar
VeeTec
Mine first did it at around 1,500-2,000 miles, and I had 11,5XX when I took it in for the fix.
It didn't get better over time either. The problem is with the slave cylinder losing pressure. The amount of time it happens will depend on how much pressure loss you have. Mine would drop on the street as well, if I sat in heavy traffic, and then tried to accelerate.
So far my clutch pedal pressure has been fine since the fix, and it feels like it bites much harder now, but I will test it out soon, just to make sure.
I see a recall, in the not too distant future.
Old Aug 11, 2007 | 08:59 AM
  #118
warmmilk's Avatar
warmmilk
did the problem start "not to bad" (for lack of a better expression) and get worse, or was it always the same from when it started till when u got it fixed?
cause this happened to me at the track twice last night, and both times on some of the harder launches i was trying (must hit 1.9 60ft)
also, did it vary? like one night at the track it did it, then a different night it didn't?
Old Aug 11, 2007 | 09:59 AM
  #119
VeeTec's Avatar
VeeTec
It started off on my first hard launch attempt. After that, it varied. If I let the car cool off, it did better. Hard launches brought it on every time though.
Forget about hot lapping.
On the street, heavy stop and go traffic, and quick acceleration, will bring it on at times.
Old Aug 11, 2007 | 02:22 PM
  #120
VitViper's Avatar
VitViper
VeeTec described what mine was doing quite well.. I just didn't wait til 11xxx miles to go in since VeeTec's already got the ball rolling (along with a few other people) and Nissan was aware of the problem. It was progressively getting worse... Started around 2k miles with my first peel out attempt on the street (clutch pedal went to the floor) and then seemed fine... Seemed OK at the track, but anytime I tried launching hard the pedal only came up half way (probably why my times kind of sucked, clutch not fully engaging during the launch).
At one point on the track I let the car cool off completely... tried a hard launch... bye bye clutch pedal. And I ran a 17.3... lol
I just showed the techs when it happens... I did some 3-4k takes off and nailed the throttle and let them watch the clutch pedal sink... clutch reeked like you know what after half a dozen such show and tell attempts. I'd have to pump my pedal each time to get it back up to the top.
Like VeeTec told me... it's a sports car, if you can't drive it hard, what's the point? heh (no I didn't tell them I went to the track, I live near a country road so I have the chance to take off hard everytime I leave my driveway).
Currently my clutch engagement from idle and between shifts is mushy as #$@@#
