15+ WOT runs for ecu to adjust?
Old 01-27-2005 | 11:16 PM
Z BOY's Avatar
Z BOY
Default 15+ WOT runs for ecu to adjust?
That's what AAM said the ecu needed to adjust to their plenum spacer...no wonder why dynoing my mods immediately after install showed no signif diff!
Old 01-28-2005 | 06:55 AM
FairladyZ's Avatar
FairladyZ
Not really. I bet you drove further than what 15 runs on the dyno would equal.
Old 01-28-2005 | 07:53 AM
EdgeOfSanity's Avatar
EdgeOfSanity
i thought if you reset the ecu and do like 2 wot runs it would adjust quicker.
Old 01-28-2005 | 08:36 AM
Sins4u33's Avatar
Sins4u33
Its true...these computers do learn to a certain extent....but when more tunning is required...such as adding and removing timing it is required to do a reflash. If you have simple mods such as intakes, or even to the further extent of having intake, plenum, TB, spacer, etc....you would most likely need to get a reflash. When you start adding exhaust and things and when the mods add up, it would be recommended to get a reflash...but for a simple mod or 2 i wouldn't recommend a reflash...just allow the computer to learn what you have put into it....its just as you get farther down the line with more mods you will need a reflash to get the most out of your mods...
Ben Y
AAM
Old 01-28-2005 | 08:54 AM
PhoenixINX's Avatar
PhoenixINX
Really? That's funny... I have the plenum, cats, and exhaust... (no headers) and dyno'd the same as flashed cars. I'm not reaping the benefit of a higher redline, etc... however MY Z is in NO need of a reflash.
Most importantly... we should always understand that it takes several runs to get a car to show a TRUE baseline.
EVERY 350Z/G35 I've dyno'd (which I've lost count) takes AT LEAST 4-5 runs to even get up to temp.
Make sure when you baseline, and test your mods... to get it up to temp first. Don't use your first run, and think that's the cars baseline!!
Best of luck to all!
Old 02-02-2005 | 01:58 AM
Z BOY's Avatar
Z BOY
Are you suggesting we make a hard run immediately before each pull to get the temp up?
Old 02-02-2005 | 06:08 AM
dynamic6er's Avatar
dynamic6er
Default Re: 15+ WOT runs for ecu to adjust?
Sorry about the everyone. I was over exagerating a little. Sometimes I get a little overboard. Most likely less then 5 good hard pulls to see the difference.
Old 02-02-2005 | 10:00 AM
Z BOY's Avatar
Z BOY
Default Re: Re: 15+ WOT runs for ecu to adjust?
Thanks for clarifying.
07-10-2022 07:44 AM
apex locator
07-23-2021 02:27 AM
04-22-2021 09:42 PM
10-04-2015 07:55 PM
hulkout
Tuning
09-30-2015 12:33 PM
Quick Reply: 15+ WOT runs for ecu to adjust?
