To those that installed there own cams
Old Jan 17, 2006 | 06:01 AM
  #81
JORGEOLIVEIRA's Avatar
JORGEOLIVEIRA
Builder/Framer
very easy to make this kit
Old Jan 17, 2006 | 06:19 AM
  #82
FlorendoCruz's Avatar
FlorendoCruz
yyes Jorge to the rescue. Ill wait for ur call so we can do this. Thanks a bunch guys!
Old Feb 16, 2006 | 08:27 PM
  #83
G352NV's Avatar
G352NV
Originally Posted by Jason@Performance
you are going to have to remove the heads...
you might as well get a full valve regrind kit...
since you are going to need new valve seals etc...
doing the springs, you have to remove the valves...
I dont understand the valve drop. If Im replacing just stock cams do I need to worry about this?
Old Feb 17, 2006 | 04:24 AM
  #84
arizzee's Avatar
arizzee
If replacing just the cams and not the springs, then no, not a problem.
I'm still debating if I'm going to attempt a cam install myself. I love a challenge but ...
Old Feb 17, 2006 | 05:05 AM
  #85
knight_white99's Avatar
knight_white99
Brian,
If you want to try this install yourself, maybe I can help you. I am somewhat mechanically inclined (I have done the majority of the work on my car myself), and I have lots of tools... plus the all important shop manual.
See you tomorrow at AZ Dyno Chip!
Old Feb 17, 2006 | 08:14 AM
  #86
EM-EFER's Avatar
EM-EFER
You wont have to worry about it. The only reason this was going to happen was because I was going to try and change the valve springs while the heads were on the car but found out it really wasnt worth the hassle.
Old Feb 17, 2006 | 08:24 AM
  #87
arlingtonz's Avatar
arlingtonz
So how do the cams run? have you had it out yet? butt dyno? "true" dyno? I am thinking about chaning out my cams...
Old Feb 17, 2006 | 08:50 AM
  #88
G352NV's Avatar
G352NV
Thanks guys!
Old Feb 17, 2006 | 11:44 AM
  #89
EM-EFER's Avatar
EM-EFER
Butt dyno says down lown its got way more nutts. The dyno was a 13whp gain at peak. I am getting UTEC and tuned in the next few months so I ll be in the 280 range. Right now Iam at 278whp
Old Feb 17, 2006 | 11:52 AM
  #90
arlingtonz's Avatar
arlingtonz
Very nice...congrats on the self install.
Old Feb 18, 2006 | 07:46 PM
  #91
knight_white99
Okay, new results... somewhat disappointing for all the time, money and effort.
Best HP/TQ = 279.0 hp / 257.0 ft-lb (SAE corrected on a Dynojet)
I had hoped for at least 285 hp with all those mods. Oh well... I guess either a UTEC or FI is in my future.
Old Feb 19, 2006 | 10:37 AM
  #92
G352NV's Avatar
G352NV
Sorry to hear it. Well the atleast the cams will come in handy with FI.
Old Feb 22, 2006 | 10:57 AM
  #93
virgilio7's Avatar
virgilio7
I hired a shop to do the jwt install but after the install the car seems to be pulling timing when it gets hot sometimes could be peeling tires and then it loses all the bottom power. I'm not sure if it is knock or what but i believe it's because they did a wrong install or the timing is off.I did the technosquare and with the increased rev i think i need the springs and shim kit (valves tapping really loud). Going to redo the cams install on dynamic turbo(miami,fl). Do you think this inconsistency in power is related to a bad install or the degree of the cams when installing them? could be the cold lash? cause the valves are loud as hell.
sorry to thread jack but desperate here after spending on the freaking install.
