lsd conversion help???????????????
Old Nov 11, 2005 | 02:54 AM
rx7/350z's Avatar
rx7/350z
Red face lsd conversion help???????????????
does anyone know what other parts are needed to change a 2003 base over to lsd? I have a 2003 lsd rear, what other parts do i need? do the axles fit right up? thanks for the help guys
Old Nov 11, 2005 | 05:52 AM
Gsedan35's Avatar
Gsedan35
Yes, you need the stub axles from a LSD diff they will cost you about $300, your open diff axles will not work unless your doing a Quaife lsd install. Then your going to pay about $300-400 to have it all installed by a qualified tech that has the specialized tools required to do the job. Frankly, your most cost effective way to get a oem VLSD is to buy a entire sealed pumpkin that has all the parts you need, and you can to the install yourself. Cost is a lot lower then trying to do it by parts only. $800-$900 vs $500 or so with a pumpkin. As someone that did a oem VLSD swap via parts, DO NOT do it that way, WAY too expensive!
The Nismo clutch type LSD does come with all the required parts and is vastly superior to the oem VLSD in what it does.
Old Nov 11, 2005 | 08:12 AM
g356gear's Avatar
g356gear
Agreed....I have done it both ways and it is much more cost effective to find a factory complete VLSD rear diff and swap the whole unit in.
Old Nov 12, 2005 | 02:41 AM
rx7/350z's Avatar
rx7/350z
i'm sorry ....i have a oem sealed pumpkin , not just the parts. so all i'll need is the axles??
Old Nov 12, 2005 | 02:51 AM
rx7/350z's Avatar
rx7/350z
by axle stubs do you mean the stubs or flanges off the side of the lsd with the 6 bolt pattern?
Old Nov 12, 2005 | 02:52 AM
35oZephyR's Avatar
35oZephyR
Subscribed....
No ones ever posted pics of an install on these forums have they?
Old Nov 12, 2005 | 03:10 AM
rx7/350z's Avatar
rx7/350z
no i can't find any
Old Nov 12, 2005 | 03:25 AM
rx7/350z's Avatar
rx7/350z
ok i think i know what u mean. looking at the service manual the stub axles are part of the pumpkin and the rear drive shafts are what i was calling axles. i wanted to know if i have to change those out too>>>??
Old Nov 12, 2005 | 10:32 AM
g356gear's Avatar
g356gear
Dsowe
Feb 17, 2021 10:38 AM
Vitale350z
Nov 6, 2015 10:07 AM
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
